Rear wheel wobble. HELP!!!!! - Forums at Modded Mustangs
post #1 of 15 Old August 2nd, 2010, 09:45 PM Thread Starter
Abe02GT's Avatar
Today I was informed by a passerby that my driver side rear wheel was wobbling. I went to the nearest tire place and had them tighten the lugs(which were loose) but the damn wheel is still wobbling. I dont know what else it could be.The tire is fine. Anybody had this issue before?
Check my garage for pics and mods!
Originally Posted by svtkidd23
if my gears were a vagina.. id beat it up!
Abe02GT is offline
post #2 of 15 Old August 2nd, 2010, 09:59 PM
mrbigjeep's Avatar
bearings?
bent axle could do the same but not sure how likely that would be.
mrbigjeep is offline
post #3 of 15 Old August 2nd, 2010, 10:07 PM
if you were running around with really loose lug nuts i would think it'd be pretty easy to bend an axle. especially if you did some really spirited driving or hit some large pot holes.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, 10 lbs, lee blankenship tune 430/405
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
mustanginky is offline
post #4 of 15 Old August 2nd, 2010, 10:16 PM Thread Starter
Abe02GT's Avatar
Originally Posted by mrbigjeep View Post
bearings?
Jesus lord I hope its not a bent axle! I dont drive the car hard at all and I crawl over the slightest bumps. Now im nervous about driving. All I can think about is my wheel flying off and me spinning out of control into a firey green ball of death. And my huge 315 wheel/tire pin balling off of some poor dudes ride. OK I should calm down.....im cool.
Abe02GT is offline
post #5 of 15 Old August 2nd, 2010, 10:19 PM Thread Starter
Abe02GT's Avatar
How easy would this be to fix? What am I looking at money wise to fix said problem?
Abe02GT is offline
post #6 of 15 Old August 2nd, 2010, 10:19 PM
Billy Weston
C MY 4D's Avatar
iTrader: 8 reviews
if they were loose are you sure it didn't wallow out the rims?
TT Build in progress.......
C MY 4D is offline
post #7 of 15 Old August 2nd, 2010, 10:22 PM Thread Starter
Abe02GT's Avatar
Im not sure what you mean by wallow. Please explain. I appreciate everyones feedback. Thanks.
Abe02GT is offline
post #8 of 15 Old August 2nd, 2010, 10:29 PM
Billy Weston
C MY 4D's Avatar
iTrader: 8 reviews
well have have you ever drilled a hole and wallowed it out buy moving the drill bit around in different angles? same concept.
C MY 4D is offline
post #9 of 15 Old August 2nd, 2010, 10:29 PM
Nossit's Avatar
Send a message via AIM to Nossit
If its a bent axle all you have to do is pop off the rear end cover, take off the wheel, take out the ABS sensor, pull the C-clip out take out and slide the other in and do all the previous in reverse. When I broke an axle I called autozone and they had the full axle replacement kit for 120 bucks for one axle. I just went ahead and upgraded to 31 splines which I would recommend if you drag it.
Oh yea and take off the brake.
Its a very easy process to replace just the axle though.
1999 Mustang GT - K&N drop in, Mac Prochamber, Mac CB, 555r's, 31 spline Strange axles, and 4.10's
Nossit is offline
post #10 of 15 Old August 2nd, 2010, 11:22 PM
1996blacksgt's Avatar
maybe bent wheel?
1996 ford mustang gt 4.6 auto cervini's ram air hood, CDC side exit exhaust....more to come
1996blacksgt is offline
post #11 of 15 Old August 4th, 2010, 12:27 AM Thread Starter
Abe02GT's Avatar
UPDATE: I got it fixed this morning. 3 of my 5 studs/lugs were trashed to hell. Took it to a reputable shop and the guy only charged me for 2 new studs since Discount Tire broke one of mine in the process. No wobble, no wallow(that word makes me giggle for some reason), no bent axle, no messed up wheel bearing. Thanks for the help peoples. Rock on!
Abe02GT is offline
post #12 of 15 Old August 4th, 2010, 06:10 PM
00redgt's Avatar
iTrader: 5 reviews
Send a message via Yahoo to 00redgt
good deal,glad you got it fixed with no big problems
00redgt is offline
post #13 of 15 Old August 4th, 2010, 09:27 PM
FoxHoss's Avatar
Send a message via AIM to FoxHoss
good deal, usually when you run loose lug nuts the bolt holes on the wheels will wallow or "egg". kind of an oval shape alowing the wheel to shift slightly even when the lugs are tightened.
Regardless, thats great news!
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
02' GT ~ Twin Screwed 469hp/493tq
FoxHoss is offline
post #14 of 15 Old September 1st, 2010, 06:22 PM
torque on wheels
How much torque should i apply when installing my wheels? I have a torque wrench, and have it set on 90 now. Too much? Too little? What is recommended?
sikorski04 is offline
post #15 of 15 Old September 1st, 2010, 07:10 PM
FoxHoss's Avatar
average rule of thumb for alloy wheels is 95ftlbs
FoxHoss is offline
Human Verification
