Whats a good turbo setup for my 2004 mach 1?
Hey, i've been lookin around and most of the turbo set-ups i've found are crazy expensive. Does anybody know of a good turbo manufacturer with decent prices? Or how hard would it be and what would i need to put together my own kit? (i searched for this before i posted and didn't find anything, hopefully you guys haven't answered this a million times).
most turbo setups for our cars are going to be pretty expensive. the HP turbo setups look like they are pretty nice and have gotten a lot of positive feedback. the more time that goes by and the more products that are released, the cheaper the units will get
one of the reason the tt kits are so high is they come with a tubular k member so you have room to run the pipes. hp performance and hellion make goo kits.
MM's nicest mod, :)
There is no such thing as a cheap turbo kit, there is so much time and money in fabricating one they have to charge as much as they do. Look around on other modular sites for used kits but you still take a risk with that. Unless you are a master welder, fabricator, have a lift, and about 200 hours at least of time just to mock up a system then i wouldn't try to make your own.
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
i think you would be better off going with a supercharger. with the turbos, you wont be able to take advantage of them becasue youve got a stock motor.
Thanks for the info guys, and your right, ill probably just end up goin with the supercharger with hopes that the gas mileage won't kill me.
the gas mileage may be better as long as your not hotrodding the shit out of it everychance you get. and as long as your not running a ton of boost
I wouldn't run much, probably about 8psi. lol, and i think i'd be fine in mpg then since i only put it through the floor every other block :wink
well thats better than every block like me
RLY SRS
You will be better off with a supercharger on the stock block...
I get pretty decent gas mileage on my car with the vortech on it...But when you get into it you can see the gas gauge move alittle bit... |
So this might seem like a stupid question but a positive displacement blower is gonna use alot more gas then a centri blower right? Like a kenne bell vs a vortech for example.
no it wont. if you stay out of boost you might only loose 1 or 2 mpg. might even gain 1 or 2
Threads Similar to: Whats a good turbo setup for my 2004 mach 1?
| whats the best exhaust setup for my 2001 v6 | xSxTxAxNxGx | V6 Mustangs | 11 | September 22nd, 2007 10:50 PM |
| 2004 mach 1 full exhaust system | noob | General Tech | 1 | June 13th, 2007 11:50 PM |
| wrecked 2004 Mach 1 | 969800gt | 99-04 | 5 | April 6th, 2007 11:47 AM |
| 2004 Mustang Mach 1 | dsavercool | Modular Mustangs | 13 | March 6th, 2007 04:12 PM |
| does this setup sound good for about 18lbs of turbo boost? | frankenstein | 5.0 Mustangs | 2 | July 17th, 2006 12:29 AM |
