my car bogs down at WOT but not 1/4 throttle??? - Forums at Modded Mustangs
post #1 of 25 Old August 11th, 2010, 06:21 AM Thread Starter
Broke4.6's Avatar
sooo ive beent trying to figure out this idle issue with my car and still havent came up with anything...and now the car is having this issue...if slowly rev the motor it goes all the way up to rev limiter...if you got WOT it stops at 3500-4000rpms and seriously sounds like a 2 step under water and just bogs baaaaad!! what could it be?
seriously...dont anyone say anything about coilpacks or injectors...cause really...theres NO PROBLEM there..ive replaced them more than 6 times with new ones in hopes of finding my idle issue!! no problem there
01 GT - 32v swap - Bassani - Spec - Mac
Broke4.6 is offline
post #2 of 25 Old August 11th, 2010, 09:49 AM
All Homo All The Time
Nightmare69's Avatar
fuel filter?
BLACK STANG CREW MEMBER #30
Nightmare69 is offline
post #3 of 25 Old August 11th, 2010, 10:02 AM
Willy Mo's Avatar
clean your MAF? fuel pressure regulator?
Willy Mo is offline
post #4 of 25 Old August 11th, 2010, 11:17 AM
andrewskaggs's Avatar
iTrader: 5 reviews
Is this on the stock tune?
SLP :: SCT :: Eaton :: Maximum Motorsports :: Baseline Suspensions :: Strange Engineering
MM Bracket Racing Crew
BAMA Performance Drag Team #1
Project Thread :: YouTube Channel
andrewskaggs is offline
post #5 of 25 Old August 11th, 2010, 11:36 AM
there could be several things wrong. MAF, fuel filter, fuel pump may be acting up, or your ECM going bad. or if you have a chip the chip could be loose. hope its not the ecm cause that is expensive but they can cause some wierd problems. or haha mine would do that when i had water in my fuel. have you tried a bottel of HEAT
steweod is offline
post #6 of 25 Old August 11th, 2010, 11:38 AM
Willy Mo's Avatar
yeah I would to easy things first. try cleanign you MAF with electrical parts cleaner. check your fuel pressure at the rail and compare to factory specs, change fuel filter (if avent already). an pray its not the ECM
Willy Mo is offline
post #7 of 25 Old August 11th, 2010, 02:18 PM Thread Starter
Broke4.6's Avatar
brand new injectors,fuel filter and fuel pump are in this car...no tune or anything like that are on the car! ima try cleanin the maf but uhh...could it be the ecm...like maybe thats my problem on why the car doesnt idle right< wish there was a way of knowing
Broke4.6 is offline
post #8 of 25 Old August 11th, 2010, 02:24 PM
Willy Mo's Avatar
IAC? for the idleing issue? and i would find/borrow another ECM and plug it in and see how it runs. that would be an easy test.
Willy Mo is offline
post #9 of 25 Old August 11th, 2010, 02:25 PM
Willy Mo's Avatar
another thought. my friend had problems with his car idleing. and he drilled a small hoe in the throttle blade. fixed the "not idling issue"
Willy Mo is offline
post #10 of 25 Old August 11th, 2010, 02:29 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
you cant just swap ECMs in these cars. Its not that simple. I say since you have a new pump, and filter that it could be the FPDM
Teksid short block, Ported 2v heads, Custom ground cams, Edelbrock Vic Jr intake, Brandon Alsept tuned
F8L GT is offline
post #11 of 25 Old August 11th, 2010, 02:34 PM Thread Starter
Broke4.6's Avatar
is that the one under the pass side fender??
i appreciate your guys input...just wish i could have someone look at it and figure the problem out...im honestly tired of throughing different parts at it hoping it'll fix it
thats a good idea...but the car idles fine just on 7 cylinders lol
Broke4.6 is offline
post #12 of 25 Old August 11th, 2010, 03:50 PM
Willy Mo's Avatar
so you have a dead cylinder. It takes 3 things to make compustion, air/fuel mixture, spark, and compression. so if you ruled out spark and fuel then check your compression.
Willy Mo is offline
post #13 of 25 Old August 11th, 2010, 03:51 PM
Willy Mo's Avatar
I know its PITA to get to the ECM. but why cant you? if you found one from a car with the same options whay couldnt you swap it and see if its teh problem?
Willy Mo is offline
post #14 of 25 Old August 11th, 2010, 03:52 PM
Willy Mo's Avatar
what do you do to make it only run on 7 cylinders?
Willy Mo is offline
post #15 of 25 Old August 12th, 2010, 03:19 AM Thread Starter
Broke4.6's Avatar
i dont do anything to it to make it run that way...you replace the plug and it does it on its own!!
ive already checked compression..its 200 accross the board on every cylinder! soooo thats ruledout too lol
Broke4.6 is offline
post #16 of 25 Old August 12th, 2010, 03:24 AM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
PATS, the instrument cluster, key and ecu are all linked together. U can just swap out one and expect it to start
F8L GT is offline
post #17 of 25 Old August 12th, 2010, 04:09 AM
86er's Avatar
all ford modules have to be programed into a car/truck using the IDS system.
Just a truck
86er is offline
post #18 of 25 Old August 12th, 2010, 04:17 AM
yeah i found that our when i swaped my ecu and i highly recomend just calling a local locksmith to come out and do the programing and not take it to the dealer ship cause they will rape you on charges....also have you tried hooking a volt meter to the coil of the dead cylinder to see if it is even getting power
steweod is offline
post #19 of 25 Old August 12th, 2010, 04:22 AM Thread Starter
Broke4.6's Avatar
lol..yes ive tried a volts meter...everythings getting power!
put a fuel pressure gauge on it today....its drops baad as soon as it see's any RPM...so its somewhere in my fuel system..gona drop the tank this wknd and inspect for any pin holes in the system!
Broke4.6 is offline
post #20 of 25 Old August 12th, 2010, 05:03 AM
good luck i hope it is something simple like a pinched line or somthing
steweod is offline
Human Verification
