Hooo Ha Ha
Cylinder 4 wont fire.
Alright.
I just swapped my 4.6 out and put the 5.4 in. The problem im having is cylinder 4 wont fire. Things we checked- Spark plug Wire Coil Injector Injector signal We checked to see it was actually sparking I took it apart and check the gasket No obstruction of air Compression test Leak down test Vacum check Checked the followers and the cam and both are in good condition No smoke and its no coolants getting in there. Any ideas?
![]() 410rwhp 520rwtq @ 12.9 psi |
2001 Mustang GT
is the gap correct on the plug?
Car is for sale: http://nashville.craigslist.org/cto/2510060805.html http://www.autotrader.com/fyc/vdp.js...id=AT-121bdd21
99 limited edition vert
need more info for people to get a better idea, Like what was the compression? what % of leak?, did you check for cracked runner or other sort of vaccum leak?( overall vacuum reading not good enough to rule one out) how did you check spark and injector? swapped with another cyl? plug wires in correct spot on coil? correct KV to plug? etc
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
1997 Mustang GT
Is the injector actually getting gas? Are for sure your getting a good consistant spark? I ask the same things above, how did you determine the plug, wires, and injector was good?
1997 GT Cobra R Hood, Cobra Front bumper, MSD plug wires, Tailights, Projector headlights, 18x9 chrome bullet wheels in front and 18x10s in back, Tunable Induction Cold air intake, flowmaster mufflers. 4.10 Gears. |
Hooo Ha Ha
Compression was 170
Idk what leak down was but it was "good" on the gauge. We pulled the plug and sat it on the motor and cranked it and spark was good. We checked injector signal with some diodes they have for that flash when the injecot gets power We swapped injecotrs to and from that cylinder Vacum is 21-26hg We swapped out the coil pack Wire and plug We made sure the plug is at .56 Intakes is a brand new HPS intake Gaskets have been re checked
got the stock manifold? if so put it on and see results. I am thinking you might have a vacuum leak at that cyl. is the miss just at idle or thru out the rpm range? does it set a p0304 code?
I never seen a Good range(which is what?) on a leakdown tester, would have been nice to know % and where the leak was going( all motors have some sort of leak)
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com Last edited by limited; August 17th, 2010 at 04:14 PM. |
1997 Mustang GT
And fuel to the injector? I'm stumped........
Is the tune for a 7 cyclinder?
1997 GT Cobra R Hood, Cobra Front bumper, MSD plug wires, Tailights, Projector headlights, 18x9 chrome bullet wheels in front and 18x10s in back, Tunable Induction Cold air intake, flowmaster mufflers. 4.10 Gears. Last edited by bbrewer03; August 17th, 2010 at 04:13 PM. Reason: SP * FUEL |
#8 | |
Hooo Ha Ha
Also we thought that but its an aluminum intake manifold so it cant crack and i inspected it and there wasnt an holes. Its not really like a miss. More of a cylinder death lol. Like it wont fire at all. It dosnt fire at idle or under load.
#9 | |
somehow you are not getting fuel. The injectors are a ground side circuit, go back and make sure nothings wrong with the harness
Just a truck 5.4 3v: 264hp 317ft lbs rock stock The "search" button, its not just for porn piecing together the next project faster than your first sexual experience Last edited by 86er; August 17th, 2010 at 06:12 PM. |
You said you made sure it sparks right? Did you take a screw driver and put it in the ignition plug and hold it close to a ground to see if its firing? Did you test the injectors? Take the rails off the motor, with the fuel line and injectors connected, then rest the injectors in the top of a water bottle, make sure your fuel pump is on, and then turn the key to the on position, see if it pressurizes and shoots fuel out of each injector. If you have fuel, and you have spark, there is literally no reason it won't fire. If all other cylinders on that side are firing it can't be that your timing is that far off.
![]() 99' Rio Red Mustang GT: --My Garage-- Check garage. Vortech V-1 intercooled running 9lbs of boost Life= eat, lift, eat, eat, eat, sleep, repeat
12.85 @ 114
yeah how sure are you that you are getting fuel? Because you are sure you are getting spark?Any of the valves stuck open?
![]() MODS: Vortech V1 T-Trim @ 7.5 PSI (tuned down) Comp Cam Stage 2's + more 432 rwhp / 396 rwtq 02/27/2011 NEW VIDEOS! **It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math ![]() C2H5OH on the horizon |
Threads Similar to: Cylinder 4 wont fire.
| help, two miss fire codes wont go away | 02gtvortech | 99-04 | 7 | July 5th, 2010 02:28 PM |
| Cylinder 1 Miss Fire | scxc15 | 99-04 | 19 | February 21st, 2009 06:14 PM |
| 86 GT wont fire | alabamastanger | 5.0 Mustangs | 3 | March 15th, 2008 06:17 PM |
| MY FORD LASER JUST STOPPED FOR NO REASON - WONT FIRE -HELP | molly | New Members Introductions | 3 | September 6th, 2007 10:56 AM |
