can i change rod bearings without pulling engine? - Forums at Modded Mustangs
post #1 of 8 Old August 19th, 2010, 11:32 AM Thread Starter
hooliganryder's Avatar
My car has started making a ticking noise after if gets warm.... is sounds like a rod bearing... can I change them without pulling the engine??? If I can what all is involved and how long does it take??
hooliganryder is offline
post #2 of 8 Old August 19th, 2010, 12:01 PM
I8ACMRO's Avatar
I'm gonna go ahead and say nope, you gotta pull the engine.
http://www.moddedmustangs.com/forums...-member-30498/
Originally Posted by RZNCAIN View Post
Drive the shit out of it and replace shit when it breaks. No point in having these things if we are going to drive them like a bunch of pussies!
I8ACMRO is offline
post #3 of 8 Old August 19th, 2010, 12:20 PM
It is possible, but you'd have to pull the K Member, and would be working in a cramped space, and hope nothing else is wrong while you're in there.
It takes less time to pull the engine and do it. I've started pulling the engine to do headswaps lately, it's just so much easier than working in the car.
Bullitt5339 is offline
post #4 of 8 Old August 19th, 2010, 01:08 PM
y2k02's Avatar
Yes, you can. It is easier than pulling the engine, first make sure that's your issue. Ticking could be a number of things beside rod bearings.
2002 GT~Forged Teksid~ Trick Flow
Big Cams~RR Intake ~160lbers ~E85
Twin 61mm Turbos TH400 & UCC converter
Home built Holley Dominator tuned by me
2016 Mustang GT keeping it stock
y2k02 is offline
post #5 of 8 Old August 19th, 2010, 01:54 PM
limited's Avatar
Even thou it is possible and assuming it is your rod bearings making the noise(I have my doubts) The odds of just replacing the bearings being a lasting fix is low. you need to refinish the crank journal to do it right and replace the offending rod(at least the bolts)
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
limited is offline
post #6 of 8 Old August 19th, 2010, 10:45 PM
If its a rod bearing it will rattle from start up. You sure thats your problem? Sounds more like an exhaust leak to me.
But assuming its your rod bearing, pull it. You could half ass it and pull the K-member and pan. Then pull the cap on the rod, if you knew which one it was, and put a new one in. THe motor is probably going to chew that one up in short order because the journels are probably grooved and need refinishing. Have fun trying to talk your engine biulder into making that happen. When its all said and done, you'll have 5 times the time into screwing with it and it wont be fixed right. Just pull it, or fix the exhaust leak. lol
Exodus is offline
post #7 of 8 Old August 19th, 2010, 10:52 PM
mrbigjeep's Avatar
indeed. could be a leak at the head/manifold
mrbigjeep is offline
post #8 of 8 Old August 19th, 2010, 11:26 PM
86er's Avatar
as stated it can be done, but it leaves a rod journal on the crank that could be scorn/scratched and that will just repeat the problem you have now.
Just a truck
86er is offline
Human Verification
