Leaky injectors
If an injector was leaking would the computer compensate to pull fuel out of the bank where the leaking injector would be? Real time data shows the computer removing -25% of long fuel trim in each bank. Maybe I have clogged injectors? Any ideas?
technically yeah. It would pull. Can you stand outside youre car and smell it burning rich?
If youre long term fuel is getting yanked from the system by 25%, then youre not getting any air. Or like you said... a large amount of fuel so its adjusting for the long term fuel map and taking away alot of fuel. What kinda car are you running ? If youre running a N/A 4.6 SOHC its easy enough to yank the fuel rail and do a test on them. See how they spray. If youre injectors were clogged, in theory you wouldnt be getting enough fuel, so it would be adding more fuel in the long term because youre getting too much air for the mixture in short term.
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
It's definitly rich. when the long trim reads -25 what does the short trim read?. what is the fuel pressure? a leaking injector could cause this as could a bad maf, bad egos, or high fuel pressure.
Threads Similar to: Leaky injectors
| leaky? | patwrecked | General Tech | 2 | September 2nd, 2007 08:08 PM |
| leaky | skid6 | 5.0 Mustangs | 8 | August 2nd, 2007 11:00 PM |
| leaky sunroof | 91bluestang | 5.0 Mustangs | 8 | July 8th, 2007 10:05 PM |
| My top is leaky | Nick_Rapitis | V6 Mustangs | 4 | May 10th, 2007 03:44 AM |
| leaky trans? | locknest | V6 Mustangs | 3 | February 27th, 2007 06:42 AM |
