2001 Mustang GT
NA
Got Coil Packs Installed....BUT...
Ok.....Got them all installed....Piece of kake...Thanks for all the help guys. It was easy even though i had to take off the air intake..grrrr... She is running great but the service engine soon light is still on. Can anyone tell me how to clear that? Im gonna try disconnecting mt NEG cable, like Timber said but will it work?
Sometimes the codes will hang there until they are cleared from the computer. Disconnecting the negative cable from the battery will clear all codes held in the computer memory. It should work.If not, run up to your local autozone or whatever and they can clear it for you.Good luck
![]() ________________ JLT CAI, Accufab 70MM TB/Plenum,Xcal 2/BamaChips Tune |
Disconnect the neg battery cable and wait 10 minutes, waiting this long will clear youre cars pcm's KAM ( keep alive memory ). It will loose memory of all codes and also some of the driving conditions it knows. After you do this, let it idle for a minute or so. You'll be all set.
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
2001 Mustang GT
NA
Im such an idiot.... I did what you guys said and the light went away. Then it came back on while bringing my son to karate...DAM.. So I went to AUTOZONE they read the code and said I needed a new air intake temp. sensor, so I bought it. Went out to the car to put it in while still in the parking lot.... Opened the hood.... looked at where the old one is.....and I forgot to plug the DAM thing in when I reinstalled my air intake after, installing the coil packs.....OMFG!!!!!!.... I just pluged it back in and All set now...lol.... Thanks for all your help Casper....
2001 Mustang GT
NA
YUP.....all 22.00 of it.....
#7 | |
2001 YUGO GT
Here is a tip from a old timer, I keep a detailed log of every thing I take off or disconnect when I'm doing a mod. Pictures if it is a major mod. Learned that from working on airplanes. My wife will usually take the notes for me. Saves a lot of time and not to mention fustration!
W.P>
No problem glad everything turned out ok.
I have a large bucket i put all my parts and pieces in. I have a amazing memory and can put it back together without even thinking about it.
#10 | |
Here's another one from an old guy - go get one of the metal bowls with a magnetic base. Good place to put all the bolts you're taking off and they'll be there when you're ready to put them back on...
Threads Similar to: Got Coil Packs Installed....BUT...
| coil packs | ricks01 | Modular Mustangs | 11 | July 13th, 2008 12:40 PM |
| Ignition Coil Packs | blackhavok | 2005 - 2010 | 5 | December 5th, 2007 03:56 PM |
| Replacing coil packs on 02 gt | f4isvt | Modular Mustangs | 5 | September 3rd, 2007 09:07 PM |
| 2005-2007 Mustang GT 3V Coil Packs & Coil-on-Plug Connec | ozan169 | 2005 - 2010 | 4 | February 7th, 2007 09:03 PM |
| Help with coil packs | 99modular | 99-04 | 2 | July 23rd, 2006 09:09 PM |
