best cam - Forums at Modded Mustangs
post #1 of 83 Old August 29th, 2010, 05:22 PM Thread Starter
best cam
i have 2000 mustang gt stock block and heads. I have full bolt on's minus the longtube headers. What is the best cam to this date to use going N/A?
remember i have a stock block and heads. I heard about hitech stage 2 cams but is their any other cam that my be better or are those the best for $600.
jwhezzy2003 is offline
post #2 of 83 Old August 29th, 2010, 05:50 PM
BakerFX4's Avatar
iTrader: 15 reviews
U heard hitech because a bunch of peeps ride their dick and are slow. I've seen the hp292 blower cams make more power n/a than those cams. Just sayn
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
BakerFX4 is offline
post #3 of 83 Old August 29th, 2010, 05:55 PM
I don't know best to date. I know a lot of n/a guys running the comp 270's and have had good results with them. They sound damn good. Try american muscle they generally have good reviews on products.
Kennebell 2.1 at 10lbs.
04Kennebell is offline
post #4 of 83 Old August 29th, 2010, 06:14 PM
ajm
. Theres plenty out there that are just as good and better than the hitechs. Might wanna look into valve springs as well.
ajm is offline
post #5 of 83 Old August 29th, 2010, 07:22 PM
tbirdscwd's Avatar
iTrader: -1 reviews
CMS Stage 2 N/A cams.......nuff said.
Fun: 2004 Mustang GT
DD: 1994 Ram 2500 Cummins 4x4
Borla "Stinger" Exhaust Vids
tbirdscwd is offline
post #6 of 83 Old August 29th, 2010, 07:29 PM
silver03gt's Avatar
Id go with Comp Cams or Crower.
Military Crew - United States Navy - Second Class Petty Officer
My 2v build - MMR 1000 rotating assembly, Stage 3 heads/cams, 76mm turbo. Shooting for 700+rwhp.
silver03gt is offline
post #7 of 83 Old August 29th, 2010, 07:37 PM
Baker Jr.
iTrader: 5 reviews
Send a message via AIM to bandity2k00
HP cams are the ticket
RagTop GT -D1SC 24LBS BOOST, MMR 900, STAGE 2 HEADS, HP292 CAMS, EDDY INTAKE WITH 6061 PLENUM, BUILT C4 AUTO, 3800 STALL, WITH TRANS BRAKE, MOSER REAR.
bandity2k00 is offline
post #8 of 83 Old August 29th, 2010, 07:42 PM
I8ACMRO's Avatar
Everything is better then HiTechs.
I would personally go w/ CMS, Crower, or Houston Performance (HP). Also, Modular Head Shop (MHS) is somewhere else to look at.
http://www.moddedmustangs.com/forums...-member-30498/
Originally Posted by RZNCAIN View Post
Drive the shit out of it and replace shit when it breaks. No point in having these things if we are going to drive them like a bunch of pussies!
I8ACMRO is offline
post #9 of 83 Old August 29th, 2010, 07:51 PM
Ha there is literally too many to choose from. If only there were an extensive list showing the gains of each one. I too am wanting Cams soon and know that Hitechs are a waste.
1/8mile 8.71@80mph on street tires.
therat1989 is offline
post #10 of 83 Old August 29th, 2010, 08:23 PM
tbirdscwd's Avatar
iTrader: -1 reviews
CMS/VT cams are what a lot of the fastest N/A 2v mustangs run. I wouldn't really go any other way unless you got a great deal on the cams....and since new cams are less than $600, you would have to get them basically for free to sacrifice in performance IMO.
post #11 of 83 Old August 29th, 2010, 08:27 PM
BakerFX4's Avatar
iTrader: 15 reviews
HP 292's are 450 bucks.
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
BakerFX4 is offline
post #12 of 83 Old August 29th, 2010, 08:33 PM
tbirdscwd's Avatar
iTrader: -1 reviews
Do you know of any N/A 2v mustang worth noting that runs those cams? Seriously. I have heard of the cams, but have never seen any results as to why someone should go with them over products that have proven themselves time and time again.
post #13 of 83 Old August 29th, 2010, 08:44 PM
I8ACMRO's Avatar
Jesus tbird, you sound like all the other nut-huggers that are on HiTechs. CMS isn't the best either. It all comes down to the tune, NOT necessarily the cams...
I8ACMRO is offline
post #14 of 83 Old August 29th, 2010, 09:01 PM
tbirdscwd's Avatar
iTrader: -1 reviews
There is no "best cam" obviously. Honestly all the cams that are in the "stage 2" realm will produce withing a few peak hp of each other especially on stock heads. But peak hp is not all that is important. For a street driven car it is a better idea (IMO) to select a cam that is a balance between streetability, and peformance at the track.
And BTW, tuning will also only cover up a cam's deficiencies to a point. If a cam makes shit for power and torque down low, there is not much tuning is gonna do to improve this.
post #15 of 83 Old August 29th, 2010, 09:01 PM
Baker Jr.
iTrader: 5 reviews
I just did a All stock 99 GT with k&n intake and bbk x pipe and slp cat back with some HP cams made 293rwhp on a dyno jet.
My car made 415rwhp with 9lbs of boost and so conservative where it burns my eyes. In the 10s with my air fuel ratio
post #16 of 83 Old August 29th, 2010, 09:04 PM
tbirdscwd's Avatar
iTrader: -1 reviews
Oh, and baker.....Steve over at Houston Performance has a wicked 2v running SVO heads. I haven't heard of anything he is running on the PI heads. But then again, I haven't done too much research into HP
post #17 of 83 Old August 29th, 2010, 09:29 PM
Send a message via AIM to Hawaiianbro
HP, MHS, Comp, Crower, CMS are great companies to look at but the thing to as in choosing cams is the specs.
Where do you want to go being N/A do you want power up hi, mid, or low?
Also do you want more hp or more tq gains?
Also talk with the companies or performance shops as well look at the specs of cams.
Cause some cams can get you an equal gain in hp and tq gains which may not be as much to those where you could lose some tq gain more hp or lose alot of tq down low but gain alot of hp and or vise versa.
B&M Short Shifter / Ford Heavy Duty Clutch / 3.73 gears / Nitto Drag Radials / Steeda CAI / Diablo Tuned / Mac LT Headers / Lethal Cated Xpipe / Pypes Exhaust / Smoked headlights and Tail lights / GT floor mats / PP 70mm TB / Accufab Plenum
Hawaiianbro is offline
post #18 of 83 Old August 29th, 2010, 09:58 PM
BakerFX4's Avatar
iTrader: 15 reviews
Steve is a IDIOT and i dont give a damn what he says. The only good thing about that shop is their cams. They oughta give me commission as hard as i have pushed their cams and sold for them. Steve is an idiot and their tuner, Chris, is even more retarded for thinking he is a tuner.
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
BakerFX4 is offline
post #19 of 83 Old August 29th, 2010, 10:20 PM
Applehead281's Avatar
I have to agree with baker on this one, i used to be on the hitech wagon as well, but the hp292's are the way to go and if u want to go FI later you will already have your setup
The usual bolt on's..
Applehead281 is offline
post #20 of 83 Old August 29th, 2010, 10:23 PM
BakerFX4's Avatar
iTrader: 15 reviews
im not trying to say they are the BEST... just saying its not even a N/A cam and it produces better than those. Unix also got rediculous gains from installing them prior to being supercharged. They are a good grind. The hi techs just seem to be referenced to yet nobody with them is producing alot of power. Those cams with ported heads still have a hard time producing what Bandits example produced without the ported heads. Just trying to help peeps go faster. Not talking down on the hi techs or anything. I also like the cms cams pretty descent as they have done better than hi techs for sure.
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
BakerFX4 is offline
Human Verification
