Coolant sensor bad? - Forums at Modded Mustangs
post #1 of 7 Old August 30th, 2010, 01:02 AM Thread Starter
freefallin2000's Avatar
Coolant sensor bad?
I have the code on the far right hand side of the display area. It looks like a garbage can with an X in the center. If I recall it is referring to "low coolant level", but I don't have low coolant. What else could this be? The tranny cooler we just installed is leaking at a brass fitting a bit if that makes a difference. Don't know why it would. Any ideas? Do I need a new sensor?
1999 35th Anniversary Mustang GT | Magnaflow Mufflers | Factory Cat Delete | Smoked heads/fogs | 5k HID | K&N Filter | FRPP "B" Springs | Mach 1 Grill Delete/Chin Spoiler | 18 x 9 Hyper Silver Saleens
freefallin2000 is offline
post #2 of 7 Old August 30th, 2010, 03:00 AM
86er's Avatar
we prob bumped it hard or jarred it while moving the degas tank around installing the cooler, do you have any thread sealer? prob gotta remove the large brass fitting and thread seal that and then thread seal the small brass one
Just a truck
86er is offline
post #3 of 7 Old August 30th, 2010, 07:49 AM
Compare the fitting where is screws into the rad vs. trans line fitting itself. If it is life most late model fords the fitting is a little ditterent and you will need to make it look like the factory line nut with a file.
Move the sensor, probably stuck
2000 GT Spring Edition
Damn money Pit
http://www.silverdollarraceway.com
Originally Posted by 01MGGT View Post
I am a 1/4mile guy so performance steering isn't really important.
ESABATM is offline
post #4 of 7 Old August 30th, 2010, 10:51 AM
jonwrong's Avatar
That coolant level sensor is a bitch. They are notorious for failing over time, and I think the replacement is $100. Mine would get stuck all the time and I got tired of what looked like a battery with X lighting up on the dash. I just unplugged the sensor. That keeps the check engine light off, and I check the level myself every week with the oil and heat exchanger reservoir.
Saleen Series II, MHS Stage 1 Heads & Blower Cams, 365whp/385wtq, Chicane I/C, Mosaleen Pulley, Fidanza FW, Alum Driveshaft, BBK Headers, Steeda Exhaust, TruTrac 31 Spline, 3.55s, 315s, MM FLSCs, Rear LCAs, MGW Shifter, Eibach Pro, Cobra Brakes.
jonwrong is offline
post #5 of 7 Old August 31st, 2010, 08:40 PM Thread Starter
Right, because the sensor really has not bearing on how the car performs. So your saying you just unplugged where the sensor clips in just behind the expansion tank?
post #6 of 7 Old September 1st, 2010, 12:01 AM
86er's Avatar
we had a brass fitting that threaded in fine to the fitting on the radiator, just got dumb for a second and didnt put teflon tape on the threads, all is better now
Just a truck
86er is offline
post #7 of 7 Old September 1st, 2010, 10:20 AM
jonwrong's Avatar
Exactly. There is no input from the coolant level sensor to the ECU. It's just a dummy light similar to low fuel or e-brake light. It just lets you know. Seriously, I am super meticulous about everything working, but it seems like a waste to worry about this one. Mine has been unplugged a long time with zero issues.
jonwrong is offline
Human Verification
