2002 Mustagg GT
1/4 - We'll see soon
T56 Questions - Swap & what will work
Guys so I changed my trans fluid last night and It def shifts better. Trans was over full for sure b/c of how much came out of it. I have the TR3650 now. My 3rd gear syncros suck if I try to shift fast at any RPM over 4500, it grinds a bit so I got to granny it. Before 4500 it is ok. I know will granny 3rd which sucks.
I am either going to rebuild this one -- prob not b/c the suck. or get a T56. Questions though ---- Better to get a T-56 or Rebuild my 3650 with the D&D kit? IDK What T56 Trans 's will work? I know the 03/04 cobra will correct? I also hear the viper will? I hear that the Chevy ones have a bigger imput shaft so our throwout bering wont fit on it correct? I know I will need a new cross member & a shorter driveshaft but I really need to know what transmissions will work out of what cars so I can locate a good deal I can not afford to spend 2500 + haha. Help !!
" Drive Fast - Take Risks " LawlessRebel ![]() SOLD - My 02 Supercharged. Got a 95 5.0 for a few weeks till I sell or trade it!
Resident DJ
'01 Cobra Vert.
In my opinion I'd put the 6speed in there if you can afford it. For budget minded people I just say upgrade the internals in the 3650 and rebuild it.
T-3650 ~ T-56 swap in the works... ![]() ~Lefty
#3 | |
2002 Mustagg GT
Right on - I am trying to find a used 6 speed then maybe i'll be ok with cash. I am trying to figure out from which cars the 6 speeds will be right to swap in.
04 GT 5.4 DOHC Twin 67mm
I went with at TKO 600 before my 6 speed because it was cheaper....but one thing you have to remember is that when you switch to a T56 or a TKO or (i dont know didnt look at it) if our rebuild kit upgrades it....you will have to change your clutch to a 26 spline input shaft. that will cost some money as well.
but yes the cobra ones would work...which i would recommend because then you can get the cross over, mounts and driveshaft...cause you will need a new drive shaft.
Oh i just remembered what the D&D kit is.....if i read it correctly it is just an upgrade to the parts out of the 04 TR3650 and i can tell you...you will have the same problems....I would look into this one its a lil bit more but a lot better and still cheaper than a T56
Astro Performance is proud to announce a Upgrade for 2001-2004 Mustang 5 Speed Manual Transmissions. This Upgraded Gear Kit will support over 800+HP @ Flywheel. The Gear Kit requires use of a 2005-Up Mustang 4.6L TR-3650 1st & Rev. Mainshaft Gears. The G-Force Gear Kit features different tooth counts on the "Head Set" that change the 1st Gear Ratio to a 2.90 (Close Ratio) so that you get the most out of 1st Gear with a Low Rear End Ratio. In addition, the G-Force Gear Kit will two of the most Fuel Efficient Overdrives available: .53 or .58! The only required upgrade to install the Transmission into vehicle after G-Force Gear Kit has been installed is to upgrade to a 26 Spline Input Shaft ( 1 1/8"). The Upgrade will still allow use of Stock or Aftermarket Bellhousing, Shifter, Cross-Member, and Driveshaft! Astro is currently working on a "Road Race" Style 5th Gear Kit for this upgrade! Astro Performance will sell the Upgraded 2nd, 3rd, Input, Cluster, 1st Gear, and Rev. for $1,695.00. This Kit will work in all 2001-04 Ford Mustang 4.6L TR-3650 Cores. Please call (866) 253-0019 (866) 253-0019 for more details!
#6 | |
2002 Mustagg GT
Thanks! sounds Nice -- so I would need to get an 05 and up 1st and reverse mainshaft gears and then buy this kit? Then need to get it installed right? Prob looking at $2500 right there with the rebuild I would think. Shiz is expensive. ~ Need to figure this one out.
Promotion powertrain makes a built t-3650 for way less. It is rated for 750 hp. It is a reconditioned piece, but no different than if you rebuild yours.
http://www.promotionpowertrain.com/TRANSMISSIONS.html Last edited by Black Bullitt; August 30th, 2010 at 04:24 PM. |
Not sure if you have to buy the 05 parts...would just call and ask
I'm going On A Manhunt!
2002 true blue GT
speed of time @ 88mph
camaro/transam t56's require a different input shaft, bellhousing, and flywheel
mac lt's, mac O/R H pipe, spintech super prostreets, JLT RAI, 14"antenna, mach 1 chin spoiler, two 12" kickers.
#10 | |
2002 Mustagg GT
Will our belhousing work with it? You said diff one but which one? Same with flywheel? Thanks if you know.
#11 | |
2002 Mustagg GT
Yeah, the only down side is you still need to get a 26T clutch.
04 V6 4.9L
13.52@119.33
T56 swap
So here is my problem. I think I am producing way too much hp for my T5. I redline at 100mph in 4th gear. Since 5th is nothing more than an OD gear, my acceleration is killed when I shift. I was thinking about doing a T56 swap, but would much rather rebuild the T5 as there wouldn't be the need for "custom" fitting. Before I do anything though, I would like to know if this would solve my problem, and is it even possible for a T5 to support 800+hp at the flywheel. I haven't reached the 800+ realm yet, but that is my projected flywheel hp after all of my mods and upgrades are complete. Currently I am at about 440 flywheel hp... Oh, I have an 04 V6 3.9L with a lot of mods and upgrades so I am not lying about my hp... I am a hell of an engine mechanic but have no clue about transmissions...
1998 Mustang GT
13.046@107.49
also the shifter is in the wrong spot
98 Mustang GT 13.795 @ 98.87 N/A Main mods: PI Swap, 3.73 gears, E85 ![]() My Mark VIII and T56 swap |
2001 Cobra
14.2@102 (I suck)
I have a T56 and really like it. You really need a high gear ratio in the diff though. I have 4.10's and i can almost hit 50mph in 1st gear. However, there is only about a 500 rpm difference between each gear, including 6th. It's not a drag racing transmission, its a road racing one.
![]() 2001 Cobra with SRA swap, modded for twisties ![]() MM Cobra Club Member #76 |
#16 | |
Abyssinian of AX
'02 Saleen
19.34@42.259
![]() The HUGE gap between 4th~5th gears is the sole reason I swapped, but VERY important you get the correct model. There are several different ratio "sets" available and the #1260 will address the particular issue you mentioned here. A stock #1260 is not rated at the torque numbers you are at, so would probably be best to have one built for strength, yet with the same gears as the #1260. This ultimately depends on two things, when considering your HP/T applied to the trans. How hard you are on your ride from a dig and if you are running very sticky tires. Grip is what is hard on the trans and driveline parts, not HP/T Of course, one gets your numbers and typically wants such to make use of the it. This means, you are likely back to having a trans custom built for extra strength AND that .8 5th gear to rid yourself of the "drop-off" in RPM when you are passing the 100 MPH mark.Jazzer ![]() If your getting 440 HP out of a V6, I imagine you are running near 20 PSI on a blower
Threads Similar to: T56 Questions - Swap & what will work
| question on d&d t56 swap | jat | 5.0 Mustangs | 10 | May 5th, 2009 05:49 PM |
| hey t56 swap! | Killax15 | 99-04 | 29 | December 16th, 2008 10:40 PM |
| T56 Questions | drazga97 | 99-04 | 8 | October 6th, 2008 08:23 PM |
| T56 Swap Into A GT | drazga97 | 99-04 | 8 | November 15th, 2007 05:29 AM |
| T56 swap into 95 5.0 | blackbird | 5.0 Mustangs | 1 | December 3rd, 2006 01:30 PM |
