99 gt 460 swap
Old September 7th, 2010, 10:34 AM   #1
TheresHellToPay's Avatar
TheresHellToPay is on a distinguished road
Thumbs down
99 gt 460 swap
Well as of right now im about to sell off my current project (97 240sx with a skyline motor swap) and switch to a 99-04 mustang gt. Ive wanted one since I was a little kid and now that i'm all grown up and can actually build a car I wanna swap out a motor. My roommate just brought home a 79 camaro with a built 383 stroker, the second he started it up and I heard that cam lopeing I knew I had to get back into a muscle car.
butttt anywhoo.
I originally wanted to do the lightning swap but that is just to much cash to throw down for just an engine and having to cut a hole in a 3in cowl doesnt really work for the sleeper look that I like lol so I wanna do a 460 swap. I figure I can get a high mileage stang for around 4500-5500 and drive it till winter and start up the swap. I plan on doing the 460 and then off the side picking up a stroked 532 and building it up then just swapping it over from the 460
so my questions here are going to be:
- can I use a 95 k member and the aftermarket 460 mounts and still keep the stock 5 speed with a adapter? or am I going to have my local shop make me up some custom mounts and headers?
- will my 8.8 rear hold or am I going to have to throw in a ford 9in
- whats a good set of coilovers to hold the new front weight
- am I going to have to switch to a sump style oil set up
anything else I will need to know? I plan on using a painless wiring set up. and switch to a big break kit.
Go Go Go :] already have some offers lined up with my 240sx so Im hoping to have my car in the next few weeks.
Old September 7th, 2010, 11:15 AM   #2
dont know yet
Oakley is on a distinguished road
i know one thing the stock rear and tranny wont hold to a 460 let lone if you build a 532.
02 GT, Borla Catback and cold air intake
Old September 7th, 2010, 11:18 AM   #3
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
to much fab imo...if anything a 302 to a 347 or a 351 to a 408 would be a tab easier.
or just a 4.6 to a 5.0
Old September 7th, 2010, 11:25 AM   #4
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Well, you certainly won't be able to use the T45 that's in the GT. Bolt patterns between modular and 385 series blocks are totally different. A stock T45 wouldn't hold up to that much torque, anyway.
If you want to keep a stickshift in there, I'd look at a TKO-600. A T56 would probably hold up, and give you an extra gear, but I don't know if they've been adapted to the big-block.
Most people here will probably suggest an automatic. A built C4 would be the most ideal, but if you're on a budget, a stock C6 will work.
Personally, I think you'd have a much easier swap and make just as much power if you were to do a stroked 351W. My understanding is you can pull a 427 out of a stock Windsor block, and then you have the advantage of the much cheaper SBF aftermarket. You'll also end up with a lot less weight on the front end of the car, which will help you in whatever you're doing.
O o
/¯/______________________
\_\
Old September 7th, 2010, 11:31 AM   #5
neverfastenough1's Avatar
You can use the 8.8, not the tranny, and you can get a aftermarket k-member that will accept the bb. Assuming you are going to a carb setup, stay 85 and older on the block.
Edit: Using the 8.8 will reqire fortifying, and 9 in would probably be a better choice.
Old September 7th, 2010, 12:30 PM   #6
Thanks guys, but im def. doing the 460 swap no matter what.
Ill have to look into a built tk-600
Old September 7th, 2010, 12:33 PM   #7
Well, if you insist on the big-block, do yourself a favor and get aluminum heads. That'll shed something ridiculous, like 80 lbs.
O o
\_\
Old September 7th, 2010, 12:35 PM   #8
Willy Mo's Avatar
Willy Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really nice
there will be a lot more money needed in the suspension, trans alone to beable to hold up to the 460/532. you wanting to go carb? or fuel injection?
Old September 7th, 2010, 12:42 PM   #9
BYAHHHH!
2001 Mustang GT
13.874
I thought my car was going to have a Procharger F1c too. but Plans can change. a 460 is over kill IMO. What makes you want to such a big bore?
Old September 7th, 2010, 12:47 PM   #10
Oh, and tangent, but which skyline swap? RB20, 25, or 26?
O o
\_\
Old September 7th, 2010, 01:09 PM   #11
Post
Carb FTW
Go big or go home i want pretty much a weekend track car that I can still drive here and there for a day or so to cruise with. Im gunna start my set up with a 460 so I will go from there if im gunna build the 460 or bore up.
Rb25det R33
Old September 7th, 2010, 04:49 PM   #12
BYAHHHH!
2001 Mustang GT
13.874
Carbs suck bro lol EFI is the best type of fuel injector for cars
Old September 7th, 2010, 04:57 PM   #13
Only way I'd go carbs is if fuel injection wouldn't survive the trip or was banned per the series rules (or it was something classic and Japanese).
Megasquirt FTW.
O o
\_\
Old September 7th, 2010, 05:14 PM   #14
ive dealt with enough electronic b.s over the years. i miss simplicity. if i knew it would fit id drop a 6bt cummins in it lol carb is way easier and for something thats not out to be fuel efficent im not to worried about it. and if I have problems later on I can always F.I it
Wheres your sence of fun guys
Old September 7th, 2010, 05:27 PM   #15
Willy Mo's Avatar
now thats a damn good idea! so why not a 4bt? lol
Old September 7th, 2010, 05:29 PM   #16
BYAHHHH!
2001 Mustang GT
13.874
i like fun but also the benefits of EFI
Old September 7th, 2010, 05:46 PM   #17
even for the 4bt its still a long motor and is def. would still be a lil packed in the engine bay. ive seen the 6bt in a fox before though. but i sure wouldnt have fun cutting and modding the trans tunnel for that lol
Old September 7th, 2010, 05:48 PM   #18
Willy Mo's Avatar
well 4bt is the 6bt minus 2 cylinders. so that like minus 12 inches lol.
Old September 7th, 2010, 05:54 PM   #19
yes I know what it is, I did a 6bt swap into my 79 f350 mud truck last winter.
Old September 7th, 2010, 05:55 PM   #20
I like not having to think about the carb tune just because I'm heading up to the mountains for the weekend. More fun to just get in, turn the key, and go.
O o
\_\
Threads Similar to: 99 gt 460 swap
1970 460 or 1992 460 swap??? mtw002 Classic Mustangs 9 May 10th, 2010 02:11 PM
460 swap beheivjer 94-95 16 April 18th, 2010 12:24 PM
460 swap. 93badazzstang 5.0 Mustangs 20 November 24th, 2009 08:45 PM
5.0 to 460 swap stangfreak 5.0 Mustangs 94 September 21st, 2008 08:06 PM
460 swap 20yrnotch 5.0 Mustangs 11 February 27th, 2007 08:50 AM
