typhoon intake manifold 2000 mustang gt - Forums at Modded Mustangs
post #1 of 23 Old September 9th, 2010, 11:05 PM Thread Starter
do the professional products typhoon intake manifold hurt my low end power? or is the stock plastic one better because my car feels sluggish off the line with the typhoon intake currently installed (bought it with it on the car, the owner said it is probably holding me back alittle because its powerband is 2500 to 7000.
I have a 2000 mustang gt automatic full bolt on's. with no stall converter (I have stock torque converter), cams, or long tube headers.
would going back to the stock intake make that much of a difference?
jwhezzy2003 is offline
post #2 of 23 Old September 9th, 2010, 11:06 PM
stal94gt's Avatar
stick to stock.
stal94gt is offline
post #3 of 23 Old September 9th, 2010, 11:25 PM
KV007's Avatar
typhoon is alot heavier too huh
99 Gt Auto Fr500s,Stalker hood,Tuner, pretty stock for now. 4.10s soon
KV007 is offline
post #4 of 23 Old September 10th, 2010, 12:26 AM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
typhoon flows horribly and is made out of cast aluminum with will collect heat. The stock intake flows very well and is very good for both low end and high end. They only restrictions with the stocker is when you get upwards near 500hp. get a stock one and get rid of the slowphoon
Teksid short block, Ported 2v heads, Custom ground cams, Edelbrock Vic Jr intake, Brandon Alsept tuned
F8L GT is offline
post #5 of 23 Old September 10th, 2010, 12:29 AM
mounder27's Avatar
yes take it from me, i have this intake, i hate it...the intake is just an expensive piece of junk...
mounder27 is offline
post #6 of 23 Old September 10th, 2010, 01:24 AM
iTrader: 16 reviews
what about the elder brock intak manifold?
1_nice_03_gt is offline
post #7 of 23 Old September 10th, 2010, 01:26 AM
mounder27's Avatar
couldn't say but i have heard lots of praise from some of the shops that i have done business with
post #8 of 23 Old September 10th, 2010, 05:29 AM
02trueblueGT's Avatar
All intakes are junk for our car. And are all heavier and flow crappy. Our intakes flow pretty good and their are some guys on here running stock PI intakes with f/i and they are making great numbers. I say if you REALLY want a new intake... Go find one off of a bullitt.
TRUE BLUE CREW MEMBER #4
02trueblueGT is offline
post #9 of 23 Old September 10th, 2010, 07:25 AM
zigbigadoru's Avatar
these ones arent junk
order_page
Originally Posted by XTCNAGT View Post
That's what you get for excercising.
You think my lungs and chest hurt when I drive down the road for a triple baconator? No. You know why? Cause I'm smart.
Time for a nap.
zigbigadoru is offline
post #10 of 23 Old September 10th, 2010, 09:52 AM
slow02gt's Avatar
Send a message via AIM to slow02gt
dont know where you heard that from the bullitt intake isnt shit compared to the new edlebrock...the ones that work really well for our cars people dont want to or cant afford..but the eddy is good priced and performs great.. thats why so many people are getting it
a bunch of shit lol..
slow02gt is offline
post #11 of 23 Old September 10th, 2010, 09:55 AM
iTrader: 6 reviews
i have the typhoon on my car and its not that bad. I had mine ported, on the dyno i didnt lose anything on the low end. The only reason you should switch form the stocker is nitrous, high rev cams, or big boost. I have nitrous and plan on high rev cams so it works for me.
tripleblkmartini is offline
post #12 of 23 Old September 10th, 2010, 02:34 PM
stal94gt's Avatar
i agree for the most part on what your saying. the thing that sucks is even the stock intake will break over time so it is a liability as well. on a stock motor the oem ford intake with aluminum crossover is the best. the whole "its heavy" crap really should not be the reason not to buy a intake. if your set up will perform better with an aftermarket intake than the extra couple of pounds will be worth it. hell my whole s/c set up easily added about 70 extra pounds to my car but the gains were worth it. but for now i would save the money and run an oem one.
stal94gt is offline
post #13 of 23 Old September 10th, 2010, 02:53 PM
slow02gt's Avatar
that metal shit doesnt stop nitrous back fires.. you can blow a metal 1 just like you can a stock plastic intake.. so..unless you a reving to 7k on top of 175 shot or something its still a waste... i was running 150shot and spinning it to 6500rpms just fine..stock motor
slow02gt is offline
post #14 of 23 Old September 10th, 2010, 03:11 PM
iTrader: 6 reviews
True, but a back fire in an aluminum is less likely to crack or break. Its more about peace of mind for me. Besides i got a great deal on it.
post #15 of 23 Old September 10th, 2010, 07:09 PM
iTrader: 16 reviews
so if i were to get an elder brock would my car require a dyno tune? i know to at least get the most out of it
post #16 of 23 Old September 10th, 2010, 07:18 PM
86er's Avatar
really, care to elaborate?
Yes people make good numbers on a blower motor, Id hope so, 10psi and if you arent high 3's or low 4's you should kick yourself in the face.
The edlebrock/trickflow/RR/Fox Lake/Sullivan/Logan, all serve for a purpose.
96% of the cars in this section will never go past a stock motor with bolt ons.
Take a care with even stock compression,ported heads/decent cams, all the bolt ons, and swap between a stock and even the edlebrock intake, watch the curve change. Youll give up some power on the lower side, but from mid curve to the top of the curve, you will have nice gains. The intakes wouldnt have been made if they werent working/doing something right, too many dollars wasted in R&D to produce an intake that just fails. Well Prof. Prod. just copy cats, so they dont have to have R&D
Just a truck
86er is offline
post #17 of 23 Old September 10th, 2010, 07:19 PM
Stark77's Avatar
Edelbrock.
2001 GT-4R75W, 3.73's,aluminum DS,Mac LT Headers, Mac O/R Prochamber, JLT CAI,Steeda UDP's, PP upper plenum and TB,GMS UCA & LCA.Currently running 50HP jets on a wet kit. Nitto Drag Radials. 265rwhp/299 rwtq N/A
13.1 @ 103 N/A, 1.82 60ft
Stark77 is offline
post #18 of 23 Old September 10th, 2010, 08:11 PM
Baker Jr.
iTrader: 5 reviews
Send a message via AIM to bandity2k00
I got a brand new typhoon for 300 bucks and using it on my build so i guess we will see if its really that bad.
RagTop GT -D1SC 24LBS BOOST, MMR 900, STAGE 2 HEADS, HP292 CAMS, EDDY INTAKE WITH 6061 PLENUM, BUILT C4 AUTO, 3800 STALL, WITH TRANS BRAKE, MOSER REAR.
bandity2k00 is offline
post #19 of 23 Old September 10th, 2010, 09:51 PM
Blake96GT's Avatar
agreeed
Blake96GT is offline
post #20 of 23 Old September 11th, 2010, 12:12 AM
yellow04GT's Avatar
I like my P51 just wish it was a 1/4 inch shorter so it didn'n rub on my hood. I am putting way too much money into my engine build to buy the hood I want.
yellow04GT is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/182729-typhoon-intake-manifold-2000-mustang-gt.html
Thread typhoon intake manifold 2000 mustang gt | Forums at Modded Mustangs | BoardReader This thread Refback May 30th, 2011 03:21 AM
