P1151 and P1152 code..anyone had them? - Forums at Modded Mustangs
post #1 of 48 Old September 13th, 2010, 02:34 AM Thread Starter
Shaun13GT/CS's Avatar
iTrader: 27 reviews
Okay I talked to a few people, but I just want to get some closure. This may be confusing, but read this.
Codes:
P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P1152 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
Okay, 2 nights ago car threw a code. Got the P1151 code (lean) cleared it. Came back.
Then I had 2 codes, the p1151 and P1152.
I bought a new o2 sensor. Put that on bank 1, and took the original bank 1 sensor (no codes for that) on bank 2. The CEL light is still on. I disconnected the battery to clear the code.
Now, in my case, I dropped the tranny. Is it DEFINATLEY the sensor? OR a ripped wire on bank 2 (driver side)? Im really lost on this right now, driving me nuts.
How hard is it to get from the wiring harness? The wires are secured. But maybe from the adapter to the wiring harness it ripped or something?
I know Ive been posting some newb questions, but Ive been really trying to get this all figured out with, its driving me crazy.
Thanks for your guy's help.
Shaun
14 Mustang GT M6 - TVS, Kooks Full Exhaust, AED Tune
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
09 Corvette Z06 - 11.7 @ 123.5 (stock)
13 Mustang GT Bolt Ons - 11.58 @ 122.13
03 Mustang GT Vortech - 11.98 @ 118.68
Shaun13GT/CS is offline
post #2 of 48 Old September 13th, 2010, 02:43 AM
86er's Avatar
if it was a ripped wire, it would be along the lines of a no signal or what not. No switching means the O2 sensor isnt sensing the rich/lean back and forth it see/reads as the car corrects itself.
could be problems with the EGR system, vacuum leaks, fuel pressure/fuel leaks, vapor recovery system
Just a truck
86er is offline
post #3 of 48 Old September 13th, 2010, 02:54 AM Thread Starter
iTrader: 27 reviews
Reps for you thanks man!
Okay so a ripped wire it out of the question.
The fuel pressure seems okay. I viewd live data and it seemed fine.
Vacuum leaks, I doubt it to be honest since I didnt touch any lines or anything but Ill check.
EGR system, how could I check that?
Vapor recovery, how do I check that? I have to get the car running right tomorrow. thanks man!
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #4 of 48 Old September 13th, 2010, 04:37 AM
86er's Avatar
EGR, will need a data logger, while cruising, you will have a % of an egr value. ONLY cruising. Idle and WOT EGR shouldnt be opening. Id have to look, but theres an accepted value, it should be at, but if you didnt get an egr flow code, prob not that. You can vacuum check the valve itself, make sure its got a good diaphram. Just hook a vacuum pump to the nipple and squeeze, should see the diaphram move up and down.
The vapor recovery is the evap, fuems from the gas tank, make sure the purge valve is working, not stuck open
Just a truck
86er is offline
post #5 of 48 Old September 13th, 2010, 04:37 AM
86er's Avatar
check the wires anyways, never hurts to double check, esp if the trans was dropped
Just a truck
86er is offline
post #6 of 48 Old September 13th, 2010, 11:31 AM
Wiser by the Minute
aluv4speed's Avatar
IDK either man b/c I get the same problems. with the code. The 1151 will pop up first and then a few days or so later the other will pop up. I have been clearing them. I do have long tubes and was told that that could be helping with the problem but my tuner said that when I come in to get tuned for my S/C once i get it in he will be able to tell me for sure.
Sucks for sure not knowing.
" Drive Fast - Take Risks "
On3 2nd gen kit, 78/68 Benita, E85, - 628/654 16psi | 677/695 18psi {Just swapped in the Edelbrock, 6061 plenum, 75mm tb, & 4" intercooler} Need new tune.
aluv4speed is offline
post #7 of 48 Old September 13th, 2010, 12:31 PM
limited's Avatar
make sure no wires were pinched between bellhousing and engine block. I think it is a wiring issue, any other problems usually set bank 1 or 2 lean or rich codes(p0171,p0172,p0174,p0175, etc)
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
limited is offline
post #8 of 48 Old September 13th, 2010, 03:48 PM Thread Starter
iTrader: 27 reviews
no wires were pinched. I purposley checked that before I bolted the tranny back up.
so Idk, when I put the new o2 sensorin,the CEL came on immidatley, so I disconnected the battery to clear it. Well see if it just had to be cleared again, if not fml.
I cant even see where the wires go up there. I can connect and disconnect the o2 sensor in that clip, but after that i cant see the wires.
Also, can I use my dads SCT tuner on my car to check the CEL Codes? My fucking screen on my tuner is broke. Im having the worst luck right now
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #9 of 48 Old September 13th, 2010, 04:29 PM
Wiser by the Minute
aluv4speed's Avatar
Same deal here -- I have the SCT and it dosn't say a whole lot except that it indicates a lean condidtion. I have my wideband in and it dosn't pull lean so IDK. I know the wiring is ok to b/c I have checked it all. Crazy lame codes
post #10 of 48 Old September 13th, 2010, 04:33 PM
stal94gt's Avatar
i would run your sct and check your bank 1 and 2 short term fuel trims. after your car warms up post what the avg when you are sitting at idle is at.
stal94gt is offline
post #11 of 48 Old September 13th, 2010, 04:39 PM Thread Starter
iTrader: 27 reviews
Okay went to autozone to check the CEL, threw 8 codes. Please help me guys, Im so lost right now here they are:
P0443 - EVAP Purge Valve Circuit Fault
P1451 - Lack of Response From Passive Anti-Theft System Module - Engine Disabled
P0135 - Upstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1
P0141 - Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1
P0155 - Upstream Heated Oxygen Sensor circuit fault - Bank No. 2
P0161 - Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 2
P1409 - EGR Vacuum Regulator circuit malfunction
What the fuck? Is it possible I ripped the wiring out from the harness? If so where about is that wiring harness?
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #12 of 48 Old September 13th, 2010, 06:56 PM Thread Starter
iTrader: 27 reviews
I replaced the fuse it got rid of every code except the P1151
Im thinking an exhaust leak is causing that.
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #13 of 48 Old September 13th, 2010, 08:01 PM
stal94gt's Avatar
do you still have your egr hooked up? i think i know whats going on. if you do when you get in boost it is leaking past your egr valve. that would explain the lean condition. the anti theft thing is a pats thing and i dont know a whole lot about that. i would just get rid of your egr crap since your sc. if you have an exhaust leak at the header it will trip a lean condition.
stal94gt is offline
post #14 of 48 Old September 13th, 2010, 08:03 PM Thread Starter
iTrader: 27 reviews
How do I get rid of the egr? Im about to go check for a leak now
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #15 of 48 Old September 13th, 2010, 08:13 PM
stal94gt's Avatar
easy way is to buy a delete kit from upr or any other company. they are about 20 bucks. it has a plate to cover the egr valve and a cap for the header. then you get rid of the dpfe, egr valve and egr vacuum regulator. another thing for your evap line your tuner can get rid of that threw a tune and you can run your gas tank vented instead of back into the intake. the evap system does not work when your in boost so that check engine will pop up every now and then.
stal94gt is offline
post #16 of 48 Old September 13th, 2010, 08:15 PM
stal94gt's Avatar
alot of people look past the fact that the oem set up for our cars is to run under constant vac and it was never made to handle boost.
stal94gt is offline
post #17 of 48 Old September 13th, 2010, 09:44 PM Thread Starter
iTrader: 27 reviews
So I fixed my driver side exhaust. It was leaking bad lol. I thought thats how the clutch sounded, yea I had a massive leak at the driver side manifold lmao.
Fixed that, car feels 10x better.
Went out for a 15 min ride, as Im coming down my street P1151 pops up AGAIN...WTF!!!
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #18 of 48 Old September 13th, 2010, 09:47 PM
stal94gt's Avatar
you really need to data log
stal94gt is offline
post #19 of 48 Old September 13th, 2010, 09:51 PM Thread Starter
iTrader: 27 reviews
I know man, my fucking scan tool broke. Fucking sucks. Somehow got water in it. That thing was amazing too. Maybe the code wasnt cleared from disconnecting the battery or something? Like it was "Pending" and it came on?
I cleared it, if it happens again idk wtf to do. Im losing my patience.
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #20 of 48 Old September 13th, 2010, 09:53 PM
stal94gt's Avatar
did you ever replace the o2
stal94gt is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/183204-p1151-p1152-code-anyone-had-them.html
P1152 Code Ford-Wiki Finder This thread Refback November 9th, 2013 03:31 PM
P1152 Code-Wiki Finder This thread Refback October 17th, 2013 02:39 PM
Ford Code P1151 and P1152-Wiki Finder This thread Refback August 7th, 2013 05:32 PM
Ford Engine Code P1152 This thread Refback September 3rd, 2012 11:50 PM
P1151 Ford Mustang This thread Refback July 19th, 2012 11:47 AM
Thread P1151 and P1152 code..anyone had them? | Forums at Modded Mustangs | BoardReader This thread Refback February 29th, 2012 07:47 PM
Thread P0171, P0172, P0174, P0175, P1130, P1131, P1132, P1150, P1151, P1152 | Taurus Car Club of America | BoardReader This thread Refback April 5th, 2011 09:38 PM
P1151 This thread Refback October 17th, 2010 03:32 PM
