Clutch Pedal
k my clutch pedal seems to be vibrating when i slow down and have in neutral.....but it stops making the vibrating noise when i put my foot behind it and pull it up...and take my foot away....any clue.....?
throw out bearing? mine made noises when it went though, this loud whinning. it went away when i took my foot off the clutch, or pulled up on it.
Im gonna say throwout bearing as well. Its not uncommon. Also you could have a bent fork. Fingers may be bent. You might never know until you rip it down.
Throwout bearing usually makes squeeling noise when you push the clutch down, and will vibrate the pedal. Mine never went away when pulling up on it though. Only when i pushed down on it and put pressure on the bearing.
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
clutch pedal
I had two bent forks and had the same symptom. Both cars got new forks and the problem went away.
john |
well we took it all down and found nothing wrong with the bearing....or the or the fork....and now i feel kind of dumb....cause after we put the tranny back on ....we went to look at the clutch pedal and found out that the thing freaken loose....what is that.....but i really apreciate...all the advise.....though this site freaken rocks.....
#6 | |
You cant really tell by looking at youre throw out bearing if its bad. I would have DEFFINATLY changed it if it were out of the car! But oh well.
i definetly would have done the clutch and tob while everything was out in the open, then again its not often i have access to the tranny like that. if your stuff is loose a clutch quadrant kit and firewall adjuster would be a good upgrade.
well i took both of ya's advice....but i cant believe that my clutch pedal was loose....i kind trips me out though.....im still thinking of what set up to use for my flywheel and clutch....have suggestions......?
suggestions...
I got the ford motorsport 03 aluminum flywheel and clutch kit and the aluminum driveshaft. I am extremely happy with this setup. I have gotten twenty seven hwy. and twenty one city when driving like a q-tip. The reduced parasitic drag makes the car feel like it accelerates faster. The shaft puts out a little noise but it really isn't a bother. A good excuse for exhaust stuff.
john |
that does sound like a good setup.....what do ya think about clutch master and exedy.....
Threads Similar to: Clutch Pedal
| clutch pedal problem HELP!!! | mustangman36578 | 99-04 | 9 | August 7th, 2007 04:38 PM |
| Squeeky clutch pedal... | 1FastFox | 2005 - 2010 | 5 | June 4th, 2007 07:38 PM |
| clutch pedal | xxrals22xx | V6 Mustangs | 12 | March 4th, 2007 01:07 AM |
| Clutch Pedal | 06dkkiser | V6 Mustangs | 5 | December 5th, 2006 07:50 PM |
| clutch pedal assembly... | 97TunedMustang | V6 Mustangs | 3 | May 25th, 2006 08:57 PM |
