Exhaust oppinion from mechanic
Old April 3rd, 2007, 12:43 AM   #1
2004GT is on a distinguished road
I was recently told that the 2004 gt actually runs better with catted exhaust than it will without cats due to the backpressure difference, is this true or bs
thanks in advance
Gates
Old April 3rd, 2007, 01:25 AM   #2
DrHolliday is on a distinguished road
HP is all about getting as mush air in and out of your engine as fast as possible. Cats slow that down.
Some one correct me if I'm wrong, but you will get HP gains if you get either an O/R mid pipe, or one with high flow cats. The stock mid pipe just doesn't flow enough air.
Hope this helps,
Mustangless atm
2006 2500 HD Diesel. Built allison trans and other goodies
Old April 3rd, 2007, 01:44 AM   #3
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Re: Exhaust oppinion from mechanic
thanks in advance
Gates
since when does your car need to run off back pressure? do you have a 4 banger? lol
drop the cats and you will see an improvment
EDIT: don't think i am being a dick... i didn't mean to come across that way.. i just saw your post count and realised that you don't know me quite yet..
i am in good intentions man
Old April 3rd, 2007, 04:03 AM   #4
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
the only negative about going with an o/r mid pipe is that you will lose bottom end torque but will gain top end power. high flow cat will give the best of both worlds and will keep vehicle leagal (if that matters to you)
Old April 3rd, 2007, 06:40 AM   #5
matrixpuba is on a distinguished road
Send a message via AIM to matrixpuba Send a message via MSN to matrixpuba Send a message via Yahoo to matrixpuba
the difference in a close to stock car is only a pony or two. on a fi car the numbers are alot more.
Old April 3rd, 2007, 10:35 AM   #6
barksdaleammo is on a distinguished road
think of a motor as a human. your car comes like a human breathing through a gas mask. if you take that gas mask off itll breath real easy.
Old April 3rd, 2007, 11:53 AM   #7
thanks in advance
Gates
its all good bro, thanks for the advice. I thought it sounded strange when i was told that just double checkin
Gates
Old April 3rd, 2007, 11:54 AM   #8
thanks to all for the advice
Gates
Old April 3rd, 2007, 01:15 PM   #9
CantDrv55 is on a distinguished road
Any engine needs the correct amount of backpressure to produce torque. Modern monolithic cats arent very restrictive at all, not like the cats from the 1980's, but they, along with the size and shape of the pipe do produce a little bit of backpressure. If you remove your cats you will lose a little bit of low end power, but the car will breathe more freely at high rpm's. If your drag racing and launching at 3,500 rpm and keeping the engine up in the power band down the whole track you will see a slight improvement with the cats removed. If your autocrossing or road racing where you constantly have to slow down for corners then speed back up, i would leave the cats on.
Jon
Old April 3rd, 2007, 06:21 PM   #10
neckbonekat's Avatar
2005 Cadillac STS V8
Yeah, I'm getting my exhaust put on as I write this and I have a Bassani X that comes with O/R extentions and cats. The guy told me that the ony real difference that it makes is sound. The no cats is definitly louder than the cats.
ITEMS FOR SALE!
4.10 GEARS + BEARING KIT
Old April 3rd, 2007, 08:46 PM   #11
02steedagt is on a distinguished road
Send a message via AIM to 02steedagt
how much low end power do you really loose? i had never heard that before, but i guess it makes sense.
"America is all about speed. Hot, nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old April 3rd, 2007, 09:25 PM   #12
Bark posted a link to a site that said you lose like 2 HP on the bottom end but gain 8 hp on the top end.
Mustangless atm
Old April 3rd, 2007, 09:38 PM   #13
im going to try to post good info on here every day. just look for "barks post of wisdom"
Old April 3rd, 2007, 09:39 PM   #14
I don't know how true that is. I guess it may depend on how stock you are. I just got my car back with no cats and if anything it feels more lively than at a loss.
ITEMS FOR SALE!
Old April 5th, 2007, 10:10 PM   #15
DanishStallion is on a distinguished road
might run into problems if you go with to big of pipes cause of exhaust gases sneaking back in before valves closes up and it will go bang and shit.
not good for the car.
best way i can put it in engrish!
cats should not have any negative effects when removing them.
www.irmfclub.com
Old April 5th, 2007, 10:54 PM   #16
mjkids's Avatar
mjkids is on a distinguished road
taking the cats off is for really the sound of it on a stock engine you dont lose that much hp only if you put to big of pipes on it. the reason is that the car is tune and program to run that way with the cats on. but i dont work on car for a living
2000 ford mustang gt convertible
2004 ford lightning truck,,,,,sold
2001 ford mustang/cobra,,,,sold
2008 ford f-350 4x4 truck
1989 ford notch back 5.0
2006 custom build bobber
Old April 7th, 2007, 09:58 AM   #17
Assistant to the Manager
Smoothgrandmama's Avatar
12 GT
8.46@88 1/8
Smoothgrandmama is just really niceSmoothgrandmama is just really niceSmoothgrandmama is just really niceSmoothgrandmama is just really nice
iTrader: 6 reviews
Send a message via AIM to Smoothgrandmama Send a message via Yahoo to Smoothgrandmama
http://www.magnaflow.com/02product/dynos/ford46.jpg
Here's a dyno sheet of what magnaflows are suposed to do for You But I think they had there performance cat's on that one too
Join The MM Facebook:
Modded Mustangs Facebook
Vote For Modded Mustangs Ride of the Month
Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal, 101Fng
Threads Similar to: Exhaust oppinion from mechanic
Time to kill my mechanic? 99v6stang V6 Mustangs 5 October 31st, 2007 01:23 PM
SERIOUS need of HELP. My Mechanic can't even Figure it out** Clever Minx 5.0 Mustangs 20 September 25th, 2007 09:26 AM
Turning 16, Considering A 96 V6. Mechanic Said Needs Work vince1128 V6 Mustangs 46 August 31st, 2007 07:46 AM
Looking for a good shop/mechanic in NorCal Jeffs50 5.0 Mustangs 1 June 14th, 2007 07:29 AM
So i'm a tank mechanic jonboy 94-95 0 March 2nd, 2007 08:21 PM
