Benefits of EGR delete and how to? - Forums at Modded Mustangs
post #1 of 24 Old September 21st, 2010, 01:27 AM Thread Starter
BaznastyDave's Avatar
iTrader: 5 reviews
Whats the benefits of a EGR delete and how is it done? Looked into the how to section but its not in there.
305/333 WHP/WTQ with CMS Stage II cams
440/552 WHP/WTQ on Nitrous
7.86 N/A
7.15 on Nitrous
BaznastyDave is offline
post #2 of 24 Old September 21st, 2010, 01:28 AM
XXGREGXX's Avatar
XXGREGXX is offline
post #3 of 24 Old September 21st, 2010, 02:14 AM
86er's Avatar
cosmetics is the only real gain. EGR only works while cruising or under the lightest of throttle applications. Might notice a 1-2 mpg drop.
BUT, if you want to remove it, you need a block off plate for the plenum, a cap for the manifold port. Cap the vacuum lines and unbolt the egr valve and dpfe sensor.
Just a truck
86er is offline
post #4 of 24 Old September 21st, 2010, 02:19 AM
Hooo Ha Ha
sharkbait's Avatar
iTrader: 10 reviews
Looks so much better without the EGR
853rwhp @ 23psi
75mm Turbo 5.4 swap E85
#turbo2v
10.11 @ 138mph STOCK LONGBLOCK
9.11 @ 149mph - New Longblock /w Powerglide
www.JPCracing.com 410-729-0005 ext. 11
PM me if you need any parts or advice!
sharkbait is offline
post #5 of 24 Old September 21st, 2010, 02:21 AM
Back from the Dead
nuStang's Avatar
But you also get a few hp freed up right?
MM+Clevage Club Member #2
nuStang is offline
post #6 of 24 Old September 21st, 2010, 05:50 AM
The Mean Green
MATT02GT's Avatar
Cleans up the engine bay and also will help keep the intakes cleaner since its not running the unburnt gasses back into the upper plenum. Doubt you will feel any seat of the pants gains. Dont forget you will need to have the egr stuff turned off with a tune also to avoid the check engine light.
Bolt on list in Garage...... MM Insomniac Crew
MATT02GT is offline
post #7 of 24 Old September 21st, 2010, 07:29 AM
04BorlaBee's Avatar
Send a message via Skype™ to 04BorlaBee
Any before after pictures of the engine bay? And do you need to have it turned off by the tune solely to prevent the check engine light? I want to do it but won't be able to get up to the dyno anytime soon
CHECK THIS OUT ---> www.indyrpm.com
04BorlaBee is offline
post #8 of 24 Old September 21st, 2010, 09:14 AM
Wiser by the Minute
aluv4speed's Avatar
You will need it turned off by a tune or handheld to prevent the CEL I believe only b/c the sensors. You can have your tuner email you your existing tune with the egr turned off. I don't think there is a HP gain but you have to figure everything counts. No more exhaust gasses going back in the intake. I have a delete but I can't get to my bolt right now b/c of my long tubes and not knowing what size bolt it is n don't have the right size long wrench. sucks. haha
" Drive Fast - Take Risks "
On3 2nd gen kit, 78/68 Benita, E85, - 628/654 16psi | 677/695 18psi {Just swapped in the Edelbrock, 6061 plenum, 75mm tb, & 4" intercooler} Need new tune.
aluv4speed is offline
post #9 of 24 Old September 23rd, 2010, 07:45 PM
KevinJ99GT's Avatar
Anyone know what size the egr tube going to the manifold is? Looks like its gonna be a pain to get to.
- full bolt on's, hitech stage 2's, zex 100 shot
KevinJ99GT is offline
post #10 of 24 Old September 23rd, 2010, 07:50 PM
ran260gt's Avatar
22mm oil pan plug from autozone is what I have in the manifold, but its a bitch (understatement) to get the tube out of the manifold took me about 2hours before I got it off, you can also use a cap but I dont know the size !
...Mods in garage
ran260gt is offline
post #11 of 24 Old September 23rd, 2010, 07:55 PM
KevinJ99GT's Avatar
I heard a 5/8" flare cap will work, but crawling under there and seeing how hard the tube is to get to, keeps making me put it off. Plus im not sure which vacuum lines to block off.
post #12 of 24 Old September 23rd, 2010, 08:15 PM
pumm3l's Avatar
the threads on my header where the EGR tube connect to got cross threaded and I had to snip it off and weld it shut so rather than trying to remove it and redo it correctly I said screw it and just did the delete. Ford actually makes a kit that comes with a cap for the header and the plate + gasket and screws for the plenum. I orderd it from tousley ford.
Here's a photo of it, it comes satin I obviously painted it
99 GT - 462 rwhp / 405 rwtq
L&M Engines tuned - SStang.com
pumm3l is offline
post #13 of 24 Old September 23rd, 2010, 09:04 PM
stal94gt's Avatar
there really is no need to get rid of the egr system. it does look nicer getting rid of it but it does serve some purpose. most people dont belive this but it cools down cylander head temps. the valve closes once you go wide open throttle. if you are sc it is worth getting rid of cause they do tend to leak boost. i capped the header bung by cutting the pipe so i could slide it off the nut, then i just replaced the pipe with a penny so it would close the hole. then you need a block plate like pictured above for the intake plenum
stal94gt is offline
post #14 of 24 Old September 23rd, 2010, 09:05 PM
Mustang46's Avatar
As far as the delete for the intake, it wouldn't be hard at all to make. But the Cap to put on the Header/exhaust manifold is where I would like to know what is the size and thread spacing is in order to get one. It looks to be standard pipe thread but I am not sure. Does any one know?
Mustang46 is offline
post #15 of 24 Old September 23rd, 2010, 09:22 PM
Send a message via AIM to hardhitter
I assume you're not trying to pass emissions testing
Vortech V2 Si
hardhitter is offline
post #16 of 24 Old September 23rd, 2010, 10:16 PM
Mustang46's Avatar
if you shut it off with a tuner there shouldn't be any reason it will fail emission testing. Here in Ohio they just hook up the car to a scanner and test the system. If the computer doesn't throw anything back, then your good. I don't know how they do it in other states, but here they won't use the wand in the exhaust unless it's an OBD I setup. Also they won't check for converters here unless the car is loud.
For now they quit doing the e-check here in SW Ohio but I wouldn't doubt that they bring it back in a few years.
post #17 of 24 Old September 23rd, 2010, 10:17 PM
ran260gt's Avatar
It pays to know people !
...Mods in garage
ran260gt is offline
post #18 of 24 Old September 23rd, 2010, 10:26 PM
ajm
Based off of some research and what ive heard from others komatsu thread is what they are. NPT seals by taper, these seal by the flare at the end of the fitting, similar to an AN line.
ajm is offline
post #19 of 24 Old September 23rd, 2010, 10:51 PM
pumm3l's Avatar
Yes it depends what state you live in, My car is exempt, I put about 2-3k on it a year. However, my egr is shut off in the tune and in PA it passes emissions just fine since all they do is check for codes.
pumm3l is offline
post #20 of 24 Old September 23rd, 2010, 10:55 PM
BYAHHHH!
Scott2001GT's Avatar
iTrader: 5 reviews
That is what I was thinkin. You wont get passed on emmisions no matter then tune. Inless you know someone.
Leave it and spend your time on something else.
Powered by Ford
Boosted by Precision Turbo and Engine
Thanks to: Wagon Wheel Performance & STL Mustangs
Scott2001GT is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/184370-benefits-egr-delete-how.html
can you disable egr system 3.9 2004 mustang engine - Web Search Results This thread Refback April 14th, 2014 08:06 AM
