How to Cut/Remove springs Mustang GT
LinkBack (4) Thread Tools
Old September 21st, 2010, 10:29 PM   4 links from elsewhere to this Post. Click to view. #1
maxgst's Avatar
maxgst has a spectacular aura aboutmaxgst has a spectacular aura aboutmaxgst has a spectacular aura about
Since all the write ups I found on removing/installing springs are on Cobras, I decided to do one on an actual Mustang
1) loosen wheel nuts
2) Jack side you wanna do first up
3) Remove wheel
4) Unscrew both brake bolts
5) Move brake out of the way behind the shock over the spring is a good spot)
6) place another jack under the A arm, right under the bottom of the spring.
jack A-arm up just a little bit to release pressure on the Upper control arm.
7) Remove bolt on Upper control arm.
8) Remove ABS line out of the way by unscrewing the bolt that holds it to the shock mount.
9) Now remove the large two bolts that hold the shock to the A-arm
10) SLOWLY lower the A-arm by lowering the jack as much as you can. If needed, raise the car even more on the original jack to allow the A-arm more travel.
11) Now remove spring. It may be stuck to the A-arm if the ISOS have rusted, so use a pry bar to release it, and pull it out.
Now its time to cut the spring. Use a grinder (can be purchased at Home Depot or Lowe's) Cut no more than 2 coils. between 1-1.5 coils for the front springs is recommended.
Reinstall ISOS if wanted.
12) place spring back in place and start jacking the A-arm up. Make sure the bolt on the control arm lines up where it needs to go
Now reinstall the bolts on the shock, control arm and place brake back in place.
That's it your done.
Now let it sit for around two weeks and if you like the stance go get an Alignment.
Hope this helps some people out.
.............................2000 GT Vert.............................
How To Cut/Remove springs
Old September 21st, 2010, 10:30 PM   #2
WonfastGT's Avatar
2000 GT
WonfastGT is on a distinguished road
Send a message via AIM to WonfastGT
Nice W/UP Think im gonna tackle mine
Old September 21st, 2010, 10:33 PM   #3
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
The Complete How To Cut Your Stock Springs Thread - SVTPerformance
this is a sticky but nice write up non the less!
Old September 21st, 2010, 10:33 PM   #4
maxgst's Avatar
yeah its pretty straight forward. I thought it was gonna be much harder
Old September 21st, 2010, 10:35 PM   #5
maxgst's Avatar
Yes, I saw it, but I didn't think it was clear enough, plus thats a cobra, so I do not know if there would be any differences.
Old September 21st, 2010, 10:35 PM   #6
BYAHHHH!
2001 Mustang GT
13.874
yeah I thought about that too having a GT.
Old September 22nd, 2010, 12:27 AM   #7
Pittbull's Avatar
2001 Mustang GT
If you're not first you're last
Pittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to behold
iTrader: 6 reviews
Send a message via AIM to Pittbull
Shweet! Gunnna do this as soon as I find someone wth a grinder..
Stock Rear Springs FOR SALE! PM Me
Stock 99-04 GT Exhaust Manifolds FOR SALE! PM Me
Old September 22nd, 2010, 12:30 AM   #8
nope one of the best free mods IMO, and very simple to do. (if you have a grinder or can borrow one)
Old September 22nd, 2010, 12:42 AM   #9
'69 Mustang Coupe
Big_B_96 is on a distinguished road
its brake. not break dammit. lol
I'm Blake. Above are the things I say
Old September 22nd, 2010, 12:46 AM   #10
Pittbull's Avatar
2001 Mustang GT
iTrader: 6 reviews
How bout I just mail u my springs and u cut them??
Old September 22nd, 2010, 12:56 AM   #11
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
pay shipping both ways and ill do it for you
Old September 22nd, 2010, 01:13 AM   #12
lol i have my hands full w/ my car and apparently 2 more GTs next week
Old September 22nd, 2010, 02:01 AM   #13
Chapman's Avatar
Chapman is on a distinguished road
OP - About how long did it take for you to do everything?
Old September 22nd, 2010, 02:29 AM   #14
it takes me about an 1 to 1 1/2 hours to do it
Old September 22nd, 2010, 02:18 PM   #15
BaznastyDave's Avatar
2004 Mustang
BaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to all
Subscribe and reps
305/333 WHP/WTQ with CMS Stage II cams
440/552 WHP/WTQ on Spray
7.86 @ 89.1mph, 1.61 60 foot N/A
7.20 @ 98.8MPH 1.55 60 foot on spray
Stock Longblock with Cams
Old September 22nd, 2010, 03:17 PM   #16
maxgst's Avatar
the first time it took me about 2 hours to do one side and 40 mins to do the other. The second time around I had the spring out in 20 mins, and back in in 15.
Sorry about the whole break brake thing, English is my second language.
Old September 22nd, 2010, 03:18 PM   #17
maxgst's Avatar
Originally Posted by BaznastyDave View Post
Subscribe and reps
thanks dude.
Old September 22nd, 2010, 04:39 PM   #18
All Homo All The Time
Nightmare69's Avatar
2003 Mustang GT
Whatever you run plus 5 seconds
Nightmare69 will become famous soon enoughNightmare69 will become famous soon enough
got any before and after pics of the car's stance?
BLACK STANG CREW MEMBER #30
Old September 22nd, 2010, 04:44 PM   #19
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
i can give ya a hand with that if needed
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old September 22nd, 2010, 05:30 PM   #20
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
With all the pot holes around Rockford, are u sure u want to lower ur car? LOL
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/184500-how-cut-remove-springs-mustang-gt.html
Lowering by cutting springs - (1999-2004) New Edge Mustang V6 & V8 GT Tech This thread Refback December 9th, 2011 02:32 AM
Lowering by cutting springs - (1999-2004) New Edge Mustang V6 & V8 GT Tech This thread Refback October 17th, 2011 02:15 PM
Lowering by cutting springs - (1999-2004) New Edge Mustang V6 & V8 GT Tech This thread Refback August 13th, 2011 11:23 PM
MAD Crew Forum • View topic - whos cut their springs This thread Refback January 21st, 2011 11:33 PM
Threads Similar to: How to Cut/Remove springs Mustang GT
01 GT cut springs wicked01 General Tech 11 June 14th, 2011 08:25 PM
just cut my springs... maxgst 99-04 72 September 22nd, 2010 11:32 PM
cut springs Mustang02gt 99-04 58 April 2nd, 2010 09:59 AM
Installed cut springs tango7 Pictures 22 November 1st, 2009 05:51 PM
Those who cut their springs! trueblue02GT 99-04 83 October 23rd, 2009 02:13 AM
