torque converter
im thinking of running a stallion torque converter witha 4.10 gear set up. is this smart or do i need to get higher gears.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
what is the stall speed? in most cases that is very close to what everoyne runs in their autos.
they build it for your car depending upon what you have done to it. im looking a 2000 stall.
mm's nitrous mod
2000 mustang gt
a 2k stall isnt much higher than stock, i recommend at least a 2600. if i were setting one up i would get a 2800-3k with 4.10's.most stall converters are flash stall's and wont notice any difference in normal driving conditions.
yea its just the vt stage 2 cams kick in around 2000 right. so should i just not worry about the stall.
mm's nitrous mod
2000 mustang gt
a stall is always a good idea. the cams may start to kick in at 2k but the main thing you want is to hurry up and get to peak power, that is what the stall is for. if all you want is to get at the beginning of the powerband then dont worry about stall. if you want the most speed, best possible launches, and are concerned about times at the track then a stall is ideal.
Threads Similar to: torque converter
| torque converter problem? | 95stangvert | 94-95 | 12 | January 17th, 2008 01:17 AM |
| Torque converter shutter. | Hudstang | 96-98 | 0 | August 12th, 2007 07:25 PM |
| torque converter | 06Stanger | 2005 - 2010 | 0 | July 29th, 2007 12:16 PM |
| HOW TO FILL UP TORQUE CONVERTER? | oasr87 | V6 Mustangs | 3 | July 10th, 2007 05:58 PM |
| Torque Converter ? | BraggStang | General Tech | 5 | August 11th, 2006 07:57 AM |
