Still F***D UP and getting worst
Old April 4th, 2007, 01:50 AM   #1
csyharper is on a distinguished road
Ok so a couple of weeks ago I posted a forum about my car missing and not running right and that i had replaced the plugs, fuel filter, and all coils where good. There has been like 12 tanks of fuel ran through it since it started and been to Ford dealer once. Ford says that the plugs I put in it was causing it so me being a complete frickin retard I let them put plugs in and only charge me 300 and they did three recals on it. So now to the problem when the car is first started and a little heat gets in the engine you get on it(50-100% throttle and doesnt start to miss until after 3500rpm) and the car will sometimes miss like literally feels like the whole engine just quits momentarily for a split second and then kicks back in instantly yanking your neck around like a rag doll, and sometimes it wont do that and it will bog down like the cats are clouged and wont go anywhere. After the car has been running a while(20 hwy miles) they car starts intermently missing in 5th cruising just under 2000rpm well as you continue driving it gets worst and sometimes it will get so bad the engine wont run at all and you clutch in and it will instantly die. After it dies you can turn key all the way OFF and then back on and start the car and it acts like it was before it died and barely runs and about after 20 seconds it clears up and quits and goes back to missing up around 3500rpm and on like it does when you first start the car. So saying all this it goes back to Ford tomorrow so the can give me some more bullshit and what not, but any help would be greatly appreciated!!!
Old April 4th, 2007, 08:29 AM   #2
Timber's Avatar
Timber is on a distinguished road
Sounds like a bad sensor but I don't have a clue which one. When one goes without throwing a code it is a PITA finding the problem. I had one go on my wife's car recently - it was hit or miss, it was either fine or about to die. The mechanic finally found it by tapping on the sensors. When he found the bad one he could kill the car at will by tapping it. Dumb luck. Let us know what the dealer says.
http://pic14.picturetrail.com/VOL534/828983/15628081/246397139.jpg
Old April 4th, 2007, 12:53 PM   #3
spero's Avatar
spero is on a distinguished road
Re: Still F***D UP and getting worst
its a ford cant expect to much
2000 black mustang GT W CAT BACK
Old April 4th, 2007, 12:59 PM   #4
02steedagt is on a distinguished road
Send a message via AIM to 02steedagt
spero... stop raggin on the fords. every car has problems man.
"America is all about speed. Hot, nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old April 4th, 2007, 01:05 PM   #5
barksdaleammo is on a distinguished road
seriously man...i am one of the biggest chevy fans you'll ever find and im even getting pissed about you saying all this shit.
Old April 4th, 2007, 02:00 PM   #6
StuTheMusicEngineer's Avatar
StuTheMusicEngineer is on a distinguished road
your on the wrong site to be talking so much $hit about fords...
2004 GT....4.10s, SCT X Cal2, BBK Lts, BBK O/R Xpipe, Flowmaster catback with Super 40 mufflers, BBK 75mm TB & Plenum, K&N Filter w/no silencer, Steeda UDP, Steeda TriAx, and Steeda G-Trac stages 1, 2, 3, and 4, blower is on the way!!!
Old April 4th, 2007, 06:27 PM   #7
ujslost's Avatar
have you tried cleaning the IAC or replacing the TPS? is your Mass air meter plugged up? Possibly the ECM is bad.
Old April 4th, 2007, 08:16 PM   #8
Ok just got it back from ford and they say that it is a fuell pump. They say that nothing electronic wise is wrong with car except the fuel pump so.... I have no clue I guess Ill change the pump and see what happens.
Old April 4th, 2007, 08:17 PM   #9
DrHolliday is on a distinguished road
Best of luck to ya man. If you have the tools and know how to do it yourself I would. I hate paying for labor.
Old April 8th, 2007, 06:20 PM   #10
OK, well after finding out that just the pump is a dealer item and you have to buy the whole assembly and just the pump from ford was more than the assembly so i bought the whole assemblie changed the pump and bitched for a few hours and before you know it no more miss thank god. So if anyone ever said fuel pump your guess was better than mine i knew it was fuel related just not what. Thanks for yalls help!!! PEACE!!
Old April 8th, 2007, 08:16 PM   #11
superbeef1000's Avatar
sounds like it couls be a problem with the computer
Threads Similar to: Still F***D UP and getting worst
Worst Mustang Experiences DOSBoot The Clubhouse 56 September 22nd, 2007 09:24 PM
50 Worst Cars of all Time 2000Mustang The Clubhouse 31 September 9th, 2007 10:14 PM
The worst rally car corner ever! 03 R Code Videos 11 August 19th, 2007 02:04 AM
ahhhhhh the worst thing burin_rubber The Clubhouse 37 April 10th, 2007 02:03 AM
Why at the worst times?? cobraetti 5.0 Mustangs 1 March 25th, 2007 02:14 AM
