Rich in Bank 1 & 2 - Forums at Modded Mustangs
post #1 of 12 Old September 30th, 2010, 12:51 AM Thread Starter
Shaun13GT/CS's Avatar
iTrader: 27 reviews
Rich in Bank 1 & 2
Okay, gay first of all. Because my CEL is on again. BUT, its really not that big of a deal. I threw a code for Rich in bank 1 and 2, I forget the acual codes.
The other day it threw it for Bank 1, and the P0190 (fuel rail sensor) cleared it, then came back on and just Rich in bank 1 and 2.
Possible vacuum leak somewhere? I know some lines can cause it to run rich, but most would be lean. So which ones can I check? My intercooler piping seems fine, no leaks.
Could it acually be my fuel rail sensor? Ill have to view live data to see what my fuel pressure looks like to see if its bouncing around like crazy, or steady.
Sorry for posting another thread, Im bored, Its late out so I figured Id ask you guys and see whatsup before I go look for leaks.
14 Mustang GT M6 - TVS, Kooks Full Exhaust, AED Tune
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
09 Corvette Z06 - 11.7 @ 123.5 (stock)
13 Mustang GT Bolt Ons - 11.58 @ 122.13
03 Mustang GT Vortech - 11.98 @ 118.68
Shaun13GT/CS is online now
post #2 of 12 Old September 30th, 2010, 12:56 AM
MM Official Sammich Maker
Roos's Avatar
could be vaccum leak that's what caused mine to run rich, try looking at the hoses around the plenum.
KASE Racing
72 Chevelle 500hp 11.4@118mph on motor
74 Comet 500+hp and spray 11.1@121 on motor
99 Mustang GT bolt on's and 93 tune Sold
1995 RZS TT 6 speed Supra
Roos is offline
post #3 of 12 Old September 30th, 2010, 12:57 AM Thread Starter
iTrader: 27 reviews
Yea right before I read that I was just thinking...maybe the hose on the back of the plenum? Im goin to check now
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #4 of 12 Old September 30th, 2010, 01:00 AM
Roos's Avatar
that's usually one of the first places i check
KASE Racing
Roos is offline
post #5 of 12 Old September 30th, 2010, 01:04 AM Thread Starter
iTrader: 27 reviews
It was dark out, it looked like it wasnt on all the way, but I didnt get a good enough look at it before I pulled it off. But its on there now.
What other lines are there around the plenum that would cause it ro run rich? Basically any that go in after the throttle body right? But idk what else
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #6 of 12 Old September 30th, 2010, 02:14 AM Thread Starter
iTrader: 27 reviews
Anyone else have any other ideas? What other vacuum lines can I check? Im glad its rich and not lean though lol. This happend after I fixed my O2 sensor (wire was unplugged from harness) so I was working on top of the motor. So something had to have happend there, unless my fuel rail pressure sensor is shot. But its only threw the code for it once. Thanks guys
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #7 of 12 Old September 30th, 2010, 03:05 AM
86er's Avatar
you said you can view live data, check and see what temp the coolant temp sensor is giving off. If that is going out, it will slowly start causing a rich concern
Just a truck
86er is offline
post #8 of 12 Old September 30th, 2010, 03:20 AM
Roos's Avatar
i just thought of something, im not sure what set up your running for your supercharger but could maybe one of your line's be off somewhere around it?
Not too sure if that will make it run rich but you never know.
KASE Racing
Roos is offline
post #9 of 12 Old September 30th, 2010, 03:50 AM
Danderson's Avatar
i know mine was leaking by the iac hoses had to clamp them with blow thru set up.
2004 Mystichrome Cobra - stiegemeier ported blower, acufab mono blade throttle body, 2.80 pulley, snub and idler pulleys, bassani mid lengths, bassani or x and bassani catback with baffles removed, k & N drop in.
Danderson is offline
post #10 of 12 Old September 30th, 2010, 05:00 AM
limited's Avatar
are you blow thru? is so check down stream maf piping
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
limited is offline
post #11 of 12 Old September 30th, 2010, 11:27 AM Thread Starter
iTrader: 27 reviews
Cool thanks guys, Ill check that stuff out after work.
86er I have an SCT so I can datalog, but I think I can check the coolant temp sensor.
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #12 of 12 Old September 30th, 2010, 09:59 PM Thread Starter
iTrader: 27 reviews
bumpys!!!!!!
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
Human Verification
