Rear Axles Upgrade?
Old April 5th, 2007, 09:04 PM   #1
zkid01 is on a distinguished road
Rear Axles Upgrade?
Whats up guys, ive been reading up on this site for about a month now , and i like the mustang community more and more. To be honest i hated Mustangs until my buddy finally convinced me to drive his 99 Cobra. Needless to say i bought my 02 GT the next day. So enough bs and on to the qs.. Im finally getting the chance to start my build i want to aim around 350RWHP. I like to build cars from the rear to the front, so with a lower HP # do you think its worth it to upgrade to 31 spline axles? Im going to be running 3.73's, if that even matters..... Thanks ahead for the input
Old April 5th, 2007, 09:12 PM   #2
Proud American
MustangMatt96GT's Avatar
Well personally I think with that power level you will be fine on street tires. Now if you plan on running anytype of drag radial or slick then definatly upgrade. The better hooking the tires the more you have to worry about rear end strength. And lets see this Stang!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old April 5th, 2007, 09:18 PM   #3
Baneful's Avatar
Baneful is on a distinguished road
Send a message via Yahoo to Baneful
I was also wondering how much hp the axels and diff can handle.
Another thing I was wondering about is the cobra traction lock diff a good upgrade compaired to ones like the Eaton posi? I ask because the cobra one is about half the price of the ohers.
http://dagostinoracing.com/index.php...ducts_id=11331
Old April 5th, 2007, 09:22 PM   #4
Proud American
The only difference between that T-loc and a stock GT one is that it has carbon fiber clutch disks in it. So you can just take your t-loc and put in the disks to make it the same as the cobra differental. Here is the link to the disks.
http://www.buyfordracing.com/shop/pr...roducts_id=609
And then you still have only a 28 spline t-loc!
Old April 5th, 2007, 09:30 PM   #5
Baneful's Avatar
Ahh, so to be safe it is better to just upgrade both.
Thanks
Old April 5th, 2007, 09:43 PM   #6
Thanks for the input guys
Work Hard....Play Harder.
Old April 5th, 2007, 09:44 PM   #7
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
you could just upgrade to 28spline mosers and be just fine with that power level
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old April 5th, 2007, 09:47 PM   #8
Proud American
Why upgrade to the same spline when you could go to 31 spline for only the cost of a new t-loc? Wont the moser 28 hold the same amount as stock 28 or are they of a hardend steel?
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old April 5th, 2007, 09:53 PM   #9
I was actually going to ask about the 28 moser's but forgot when i was writing the post. I think ill be going with that. If i ever decide to aim at a higher hp # ill just upgrade.
Old April 5th, 2007, 10:50 PM   #10
ujslost's Avatar
I dont think there is a base number on how much a stock axle can take. I have seen stock cars break axles and I have seen some running 12s with stock axles, so its one of those things you have to make a choice about how you want to upgrade or take a chance.
If you order aftermarket axles like mosers, make sure you get hardened wheel studs also. Wheel studs can break also.
I personally think the 8.8 is one of the best differentials made, they can take alot of power.
Old April 6th, 2007, 03:03 AM   #11
neckbonekat's Avatar
2005 Cadillac STS V8
You will decide to aim higher in the not so distant future. Everbody does eventually. I also wonder why you would upgrade to the same spline when you could go to 31 spline for only the cost of a new t-loc?
ITEMS FOR SALE!
4.10 GEARS + BEARING KIT
Old April 6th, 2007, 03:46 PM   #12
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
i am running the stock 28 spline and stock diff w/ 3.55's. i was launching at 4800 rpm on slicks n/a and leaving around 3k on slicks and the bottle. i dont know how long it would last, but i am ordering a 31 spline set up right now. most cars wont benefit from a 31 spline upgrade, but some will. it all depends on how much abuse your car will see.
Old April 6th, 2007, 08:09 PM   #13
zerofx150's Avatar
2003 GT
13.6 @ 101
zerofx150 is on a distinguished road
Send a message via AIM to zerofx150 Send a message via Yahoo to zerofx150
not to jack the thread but it is on topic q i have is : can you use the same carrier and just swap the spider gear set in them to ake a 31splne axle and then rebuild the unit with the CF clutches and and 31 spline spiders and then get the moser 31 spline axles.
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports.
Threads Similar to: Rear Axles Upgrade?
Best Axles? 01GT 99-04 26 June 6th, 2007 02:03 AM
Will I have to upgrade the rear? YearOne 2005 - 2010 4 May 18th, 2007 12:39 PM
Rear Axles GT529 96-98 1 February 18th, 2007 09:06 PM
rear disk upgrade in fox ? 92_fox 5.0 Mustangs 0 December 15th, 2006 07:51 PM
removing axles from limited slip 7.5" rear end!??? Darrellx14 V6 Mustangs 0 December 4th, 2006 05:02 PM
