#22 |
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
ya I thinkin about it too
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
#23 |
I gutted the pvc and ran 2 hoses from the valve covers to a tee and from that to the tank. I just hosed clamped to the tank. The tank has a place on the back that's threaded with 2 bolts. I took a L clamp and bolted it to the extra length of bolt on one of the T-bolt clamps.
Plugged up the bung on your plenum that used to go to the pvc. Then pluged the bung off on the inlet pipe that used to go to the drives side valve cover your done. I use to have 2 L brackets together and had it mounted to the power steering bracket, but had to move it to make room for the TFS intake since the alternator is inverted.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
#25 |
Plus my filter is rigged on right now because I broke off when I was changing it over.
Threads Similar to: Breather Filler Cap
| oil out of breather | nasty92LX | 5.0 Mustangs | 1 | August 14th, 2007 03:13 PM |
| gas filler neck | DragonFreak | 96-98 | 5 | May 21st, 2007 09:25 PM |
| Gas Filler-Tube Grommet Replacement? | firewire | V6 Mustangs | 2 | September 19th, 2006 11:57 PM |
| oil filler breather cap question | cobralini | 5.0 Mustangs | 1 | June 28th, 2006 04:25 PM |
| filler neck gasket-owned | mustang_montana | 96-98 | 2 | April 30th, 2006 05:51 PM |
