Has anyone ever heard of this???
Old April 6th, 2007, 01:41 PM   #1
brent_cosenza's Avatar
brent_cosenza is on a distinguished road
ok if you seen my other post then you seen what my car was doin if not check it out and let me know what you think....anyhow this is what i was asking have any of you guys heard of oil pressure going below 6psi causing the engine to not have compression? a mechanic at a ford dealer told me this but i didnt know if he was full of shit or not...please let me know
2002 Redfire Metallic Ford Mustang GT - 5.4 2V, Steeda CAI, Bassani X-pipe, 24lb. inj., 4.10 gears, 75mm TB, UDP's, Ported Plenum, AWAITING DYNO NUMBERS AND TUNE!!!!!
Old April 6th, 2007, 02:50 PM   #2
DrHolliday is on a distinguished road
It would still have compression, but I know most gm cars have an oil pressure safety switch. If the pressure gets too low it turns off the fuel. I don't know if ford has the same thing though.
Mustangless atm
2006 2500 HD Diesel. Built allison trans and other goodies
Old April 6th, 2007, 08:54 PM   #3
zkid01 is on a distinguished road
I dont know about that one... you should still have compression even with out oil pressure... but that is some low oil pressure, need to look into that.
Work Hard....Play Harder.
Old April 6th, 2007, 09:08 PM   #4
Baneful's Avatar
Baneful is on a distinguished road
Send a message via Yahoo to Baneful
Weird. Maybe the rings got damaged from no oil getting to them and caused a loss of compression. I have heard of putting a little oil down the plug hole between compression tests and if it rises with the oil, the rings are bad.
I would ask the mechanic if it's ok to try that before you do though.
Old April 7th, 2007, 01:17 AM   #5
KhaosGT's Avatar
KhaosGT is on a distinguished road
Oil pressure is generated by a oil pressure regulating valve and your oil pump...compression is created when your pistons cycle inside the cylinders...the two have nothing to do with each other
2004 Black Mustang Gt
When I see a 5.0...I respect my elders.
Threads Similar to: Has anyone ever heard of this???
anybody heard of this guy? VSR13 The Clubhouse 32 September 19th, 2007 06:49 PM
anyone ever heard of these?? droppedbass87 96-98 1 September 6th, 2007 09:19 AM
Has anyone heard this? rugbyman00 2005 - 2010 5 August 20th, 2007 08:38 PM
anybody heard of BrightWhite98GT 96-98 7 August 3rd, 2007 07:12 PM
Ever heard of this? Onemanzu V6 Mustangs 14 May 24th, 2007 09:09 PM
