Getting Re-Tune This Afternoon
Old October 14th, 2010, 10:05 AM   #1
aluv4speed's Avatar
2002 Mustagg GT
1/4 - We'll see soon
aluv4speed will become famous soon enough
As some of you may know or have read about my build. I have a NOVI 1500, blow through, 2 core procharger i/c, svt pump with BAP, 38 LB inj ect, long tubes, o/r pipe.
I went to get it tuned two weeks ago after my build and only made barily 5 PSI on a RR 3.1 pulley. I only made 306/321 on a Dynojet Didn't even make enough psi to utilize my wastegate. bummer.
I know I was getting a leak in two places: 1 off my intake pipe b4 my TB where my IAC went in & 2 on my boost hose that went to my wastegagte.
I fixed those two leaks & installed a 2.75 pulley with a 107 1/8 belt. I can def notice a difference in pick up but I really haven't gotten on it but once. I noticed my wideband jumps to like 10 a/f which is pretty rich b/c it was hovering around 12. something when it was tuned before. I FN hope I boost at least 8 psi!
I want you all to Guess --
Where do you think my power will be at later today?
Reps to the two closest! haha
If you have any ideas on why else I wouldn't be boosting so much let me know, thanks!
Some pics:
" Drive Fast - Take Risks " LawlessRebel
SOLD - My 02 Supercharged. Got a 95 5.0 for a few weeks till I sell or trade it!
Old October 14th, 2010, 10:20 AM   #2
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
looks good dude
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old October 14th, 2010, 10:24 AM   #3
aluv4speed's Avatar
2002 Mustagg GT
Originally Posted by zinc-vert02 View Post
looks good dude
Thanks bro -- I B in Machesney Park at around 4:30.
Old October 14th, 2010, 10:50 AM   #4
2002 mustang gt
12.2 at 117
text or call me and let me know how it goes!! i have to wrok untill 5 then gotta help set up for a party, then get my truck ready for the mud drags on saturday then drop my truck off there lol... ( Im a busy mofo!)
best of luck by the way
Old October 14th, 2010, 10:59 AM   #5
aluv4speed's Avatar
2002 Mustagg GT
Nice man -- Mud Drags Where is that at?
Old October 14th, 2010, 11:02 AM   #6
2002 mustang gt
12.2 at 117
just a little north of edgerton right by coachmans golf course, call me if you want directions
Old October 14th, 2010, 11:06 AM   #7
slow02gt's Avatar
2002 mustang gt
11.38@119
slow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the rough
Send a message via AIM to slow02gt
why is your filter so damn big? and intercooler so small? that loooks like the k&n high boost filter cobras use lol...acutally im pretty damn sure it is.. and you only made 5 lbs with a 3.1 pulley? seems like you must have some restriction in that little bitty intercooler..could have been made worse by painting it...
unless your spinning the blower to make like 15lbs dont see where the wastegate is going to be neccesary if your not makeing enough boost for the springs in it to bleed off the extra...
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
Old October 14th, 2010, 11:23 AM   #8
aluv4speed's Avatar
2002 Mustagg GT
Do you think the big filter hurts anything? I have it b/c it is what I had already. I figured why buy a filter if I had one you know.
The intercooler is a procharger 2 core and those are supposed to be good to 550 HP so I didn't think that was the issue. I put a real light coat of spray on it so I doub't that has any effect on flow. Do you really think that the procharger 2 core would be that restrictive to prevent over 10 PSI?
Old October 14th, 2010, 11:31 AM   #9
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
Nothing wrong with a big air filter. And nothing wrong with a smaller intercooler, at least he has something. Lots of people run around here without an IC.
The lack of boost was from the two leaks he described, not from a restriction in the intercooler. The only thing painting does is make the outside airflow through the fins less effective, making the intercooler a little less effective at cooling. It has no effect on how the boosted air goes through then intercooler.
Wastegates have a couple of advantages. You can put a 15 lb pulley on and set your wategate to 8 psi and you'll only make 8 psi on the top end, but you'll make it a lot sooner than if you just had an 8 psi pulley on. You get more power in lower RPMs doing it that way, and you get to peak power earlier in the RPM range
Do the Right Thing, Cook. ~Zip.
Old October 14th, 2010, 11:41 AM   #10
slow02gt's Avatar
2002 mustang gt
11.38@119
yeah i know what the wastegate does but if he doesnt make enough boost to peak where it supposed to bleed off the excess boost then its one more thing in the way..i didnt say anything was wwrong with the filter just that it was big as shit lol..and on a 3.1 pulley even intercooled he should have seen at least 10lbs even with the leaks unless they where just that damn bad...
Old October 14th, 2010, 11:48 AM   #11
1999 Mustang GT
hardhitter has a spectacular aura abouthardhitter has a spectacular aura abouthardhitter has a spectacular aura about
Send a message via AIM to hardhitter
I had that same filter but it was even bigger.. It went down past the bottom of the bumper and stuck out under my car.. I think it was 12" long haha
Vortech V2 Si
Old October 14th, 2010, 12:06 PM   #12
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Looks nice man. My guess
9psi @ 358rwhp/360rwtq
11psi @ 376rwhp/372rwtq
Im lost on the boost because you said you had leaks that you fixed, and you went with a smaller pulley.
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old October 14th, 2010, 12:33 PM   #13
aluv4speed's Avatar
2002 Mustagg GT
Shit man!!! That was a MONSTER! I was afraid of sucking water so I gut my intake pipe a bit and moved it up just enough haha. I just figure why buy a new one if that one works.
Old October 14th, 2010, 12:35 PM   #14
slow02gt's Avatar
2002 mustang gt
11.38@119
its the same filter thats in the jlt high boost kit..yes its a 12" filter..thats want cobras run when they have a whipple or kb..it big enough to where you need a tune for it lol..
Old October 14th, 2010, 12:35 PM   #15
aluv4speed's Avatar
2002 Mustagg GT
Right well the idea was to make enough boost to be able to bleed off what I don't need and then I went to the tuner with a 3.1 and had shit for boost so I hope this time it will yield at least 8-10 then I'll be happy. Then next spring I will work on trying to get more boost and utilizing the wastegate.
Old October 14th, 2010, 12:40 PM   #16
aluv4speed's Avatar
2002 Mustagg GT
First guess! haha. No one said you get 2 JK but man I hope to get 10 PSI & 385 / 380 but I'll prob get dissapointed again. haha
Old October 14th, 2010, 01:29 PM   #17
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Dont be disapointed. Its a lot more power then ur GT without a blower... lol. If you do happen to get dissapointed, theres so many things to do to make it faster. Bigger intercooler, powerpipe, smaller pulley (again) I would say longtubes, but you have that. Youll make good power. Just depends on how much boost.
Old October 14th, 2010, 01:38 PM   #18
kingbdub's Avatar
2003 MUSTANG GT
9.0@78.01 w/ a shit 2.02 60ft, in 1/8 mile on street tires, spun thru 1st & 2nd all the way down! =(
kingbdub can only hope to improve
Originally Posted by shaun03gt View Post
dont be disapointed. Its a lot more power then ur gt without a blower... Lol. If you do happen to get dissapointed, theres so many things to do to make it faster. Bigger intercooler, powerpipe, smaller pulley (again) i would say longtubes, but you have that. Youll make good power. Just depends on how much boost.
^^YES! progress is progress!!
Leaks = poo cheese boost!
Im guessing 374rwhp@10psi
THE CHICK CHASER; GIVIN OUT RIDES TO ALL BUT THE FAT CHICKS!
Old October 14th, 2010, 01:45 PM   #19
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
Il guess 360rwhp
By the way anyone who thinks you need a tune for a filter...needs to really be taught a lesson
410rwhp 520rwtq @ 12.9 psi
Old October 14th, 2010, 02:01 PM   #20
aluv4speed's Avatar
2002 Mustagg GT
I got my K&N tune last week! yeah yeah. haha. jkjk.....Yeah hope all the leaks are gone!!! I am leaving work at 3pm today to head over there so I'll try and post some #'s tonight but most likely tomorrow.
Threads Similar to: Getting Re-Tune This Afternoon
Good Afternoon!!! futureMACH1racer The Clubhouse 65 August 23rd, 2010 06:27 PM
afternoon laugh :) Rich11 The Clubhouse 7 December 29th, 2009 01:34 PM
Expensive afternoon vastang757 The Clubhouse 29 November 13th, 2009 11:17 AM
So this afternoon weems The Clubhouse 13 August 6th, 2009 02:29 PM
afternoon storms...... whiteboycustom The Clubhouse 4 July 22nd, 2009 10:01 PM
