Bad night for me - Page 2
Old October 15th, 2010, 03:54 PM   #21
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Thanks man, yea some kid at Autozone told me about them, turned out to be real good. $8 and having it made done in 5 minutes owns $35 shipped and 4-5 days of wait time
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old October 15th, 2010, 04:42 PM   #22
Jobra's Avatar
2004 Cobra
7.4@97 Eaton
Jobra has a spectacular aura aboutJobra has a spectacular aura about
Should turn out to be a good fix. And thanks for letting me drive it yesterday!
NEW NUMBERS: 609/543
Old October 15th, 2010, 05:06 PM   #23
PhillyStyle's Avatar
2012 Brembo Mustang GT
PhillyStyle will become famous soon enough
Originally Posted by Shaun03GT View Post
Good news, went to a parts store, they made me a new line with the brass fittings. 4" longer, and 250psi line for only $8. Thats $16 cheaper than superchargers online, plus $12 for shipping. And it took them literally 5 minutes to make it.
I could have got stainless steel, but Im goin to put some sort of metal tubing around the hose to protect it. Chances are this wont happen again, it was more of a freak accident to be honest. But car will be running tonight. Im more than positive I didnt do any harm to the motor/supercharger but that thought is still in the back of my mind.
Wish me luck
Nice... what's the new line made of? For $8 you'll need to post details if it holds up.
I dug out my copper hard line to send you but unfortunately it was bent and kinked.
2001 GT Supercharged and Intercooled....387RWHP - SOLD
2012 Brembo GT
Old October 15th, 2010, 08:33 PM   #24
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
No doubt. And yea man no problem
Its made of the same material but holds 250psi. Im gonna put somthing around it to protect it, but I really dont see that happening again.
And its all good, thanks though I apprceate it
Old October 15th, 2010, 09:01 PM   #25
mystang0673's Avatar
6.82@100mph 1.45 60'
mystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura about
what bov do you have shaun?
Old October 15th, 2010, 09:04 PM   #26
Assistant to the Manager
Smoothgrandmama's Avatar
12 GT
8.46@88 1/8
Smoothgrandmama is just really niceSmoothgrandmama is just really niceSmoothgrandmama is just really niceSmoothgrandmama is just really nice
iTrader: 6 reviews
Send a message via AIM to Smoothgrandmama Send a message via Yahoo to Smoothgrandmama
I hate that feeling when something goes wrong....The not again feeling...the is this it for this motor feeling....eh...bad memories.
Hope it stays together now.
Join The MM Facebook:
Modded Mustangs Facebook
Vote For Modded Mustangs Ride of the Month
Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal, 101Fng
Old October 15th, 2010, 09:58 PM   #27
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Thanks for the kind words man!
The BOV is a knock off Greddy BOV, but it sounds mean. I like it a lot. No compressor surge between that and the Bosch BPV
Old October 16th, 2010, 04:02 PM   #28
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Got the car running today. I used some Purple Power degreaser and hosed the oil down from everywhere....literally everywhere. Midpipe, K-Member, front brakes, motor etc....
Replaced my oil feed line, took out my oil drain fitting, cleaned it and re-sealed it with some Copper RTV, put some T-Clamps on. Starter her up, burnt off some excess oil.
Took it out for a ride, seems fine. Just need to put my new belt on.
I think when your purposley listening for stuff, you think you hear other things. My exhaust has a tiny leak and you can hear it under a load, like 4th gear going around a turn. And I kept thinking motor? But nah, just the exhaust....
So thank god its okay. My motor takes a beaten. 3 or 4 times from 3rd to 2nd at WOT (missed 4th) gas pedal got stuck and bounced off my 6,800 rev limiter for a couple seconds, then losing a good 3qts of oil. And still runs good. Although I lost alot of the oil after it had been shut off. If anything it would have hurt the supercharger the most.
Old October 16th, 2010, 04:12 PM   #29
naza's Avatar
00 gt
naza will become famous soon enough
Good to hear that everything turned out good man!!
Red Pony Crew Member Mods in garage. Waiting on dyno numbers
Old October 16th, 2010, 07:02 PM   #30
BaznastyDave's Avatar
2004 Mustang
BaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to all
The connections are the weak point not the hose, i had a hard rubber hose from Autozone rated to 200psi that went from my motor to my oil pressure gauge and when it got hot it went soft and started squirting oil out in between the inside of the hose and outside of the brass fitting with a worm gear clamp on it. You need a hydraulic hose with hydraulic pressed on fittings and you wont ever have that problem again. I learned that by experience. And for the BOV hose you could get someone to Knurl the metal with a lathe so the soft hose has something to grab on to.
305/333 WHP/WTQ with CMS Stage II cams
440/552 WHP/WTQ on Spray
7.86 @ 89.1mph, 1.61 60 foot N/A
7.20 @ 98.8MPH 1.55 60 foot on spray
Stock Longblock with Cams
Old October 16th, 2010, 07:26 PM   #31
naza's Avatar
00 gt
I just found an oil leak on my feed hose =(
Old October 17th, 2010, 12:14 AM   #32
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Id rather the fitting be brass, rather then harder metal an strip the oil pan. Fuck that
Old October 17th, 2010, 02:02 PM   #33
man, the best tool i have found for a supercharged 4.6 is a stethoscope... you can get them at autozone for less than 20 bucks. What makes them so nice is that you can isolate a noise very easily. When my passenger lash adjusters lost prime it sounded just like an exhaust leak from inside the car. i got a stethoscope and listened to the whole motor and could hear a louder noise coming from the pass side head. Took the valve cover off and found the problem.
Threads Similar to: Bad night for me
A really bad night.... Breakout The Clubhouse 19 February 12th, 2010 04:21 PM
bad night.. moosenuk17 The Clubhouse 12 September 10th, 2009 07:05 PM
Bad Night moosenuk17 The Clubhouse 9 February 28th, 2009 01:11 AM
Bad night DarkDoug 99-04 14 January 13th, 2009 08:52 PM
