LinkBack (3) | Thread Tools |
#41 |
Captain Opinionated!
#42 |
1996 Mustang Gt
Get yourself a GOOD set of micrometers...Im talking 0.0001in range.
From the info Ive gotten its a forged crank in the 5.4(year dependent i believe). Also from what I have found, the bore in the 4.6 and 5.4 is the same at 3.552in(depending on year, unsure of major changes, didnt look that far into it yet), but the stroke is a decent bit longer at 4.165in compared to the 4.6, 3.543in. The connecting rods are 0.724in longer than the 4.6 too so a good bore to stroke ratio already. I also assume that if the 4.6 used hypereutectic pistons then the 5.4 must have too. The best things in difference Ive seen so far is the piston to deck height is taller compared to the 5.0's, yet as Ive said, this is too my knowledge. As for heads with the money people talk on spending for trickflow, check out TEA or Total Engine Airflow. For one, I like the price. The flow charts look good too and for what the heads come with depending on stage, why not ya know? As for bottom end I believe the cobra's crank is forged and will bolt in the Romeo or Windsor 4.6(timing cover can tell your a lot about your block as there were many different castings on the 4.6), my only concerns would be a good main bearing, I would go with crush but who knows. When building I would definitely get away from hypereutectic pistons. Manley has a nice set for around 700 dollars, rods I havent looked into as much as i should have but soon will. I have yet to find it but my biggest thing I would like to change on my 4.6 would be chain to belt driven, due to the increase of harmonics from the chains compared to belts. |
#43 |
KB'd GT
Smog legal would require a gt500 swap and a blower with an EO#. If you don't care about smog, then go turbo for sure. If you want to run on pump gas you will need to drop the compression down to 8.0 to 8.5.
#44 |
2001 Mustang GT
![]() iTrader: 2 reviews
2v 5.4 will bolt right in no wiring problems maybe extend two wires. nothing else
2v 5.4 out of another Ford 500$ - lightning short block lower compression forged crank 800$ Stage 3 or 4 Blower Cams 600$ MHS Valve Springs 200$ Centri Blower Kit 1800$ Injectors 200$ HPS Intake 600$ or lightning lower with custom lower FTP Longtubes and 3 inch x pipe 1000$ MISC guides or timing chain gaskets - 500 Tune 500 I estimate 430 hp A 5500 rpm - 490 tq @ 4200 rpm add ported heads another 1000 but add another 30 Hp and more efficient boost just some estimates and guesses but it can be done
01 GT Vert - Triple Black - 2v 5.4 270/340 00 Lightning - Triple Black - 2v SC 5.4 400/500 Brand New Tubular UCA and LCA set for sale PM me Slightly Used 05-09 Halo Headlights for sale PM me
#45 |
12.88 @ 109.45 N/A
![]() ![]() ![]() ![]() ![]() ![]() iTrader: -1 reviews
:thread_zombie: Although not too dead and gone, but nice first post LOL
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/187945-help-lay-out-engine-build-4-6-2v.html
| Hard Core Skull Motor | This thread | Refback | October 25th, 2010 02:08 AM | |
| Hard Core Skull Motor | This thread | Refback | October 16th, 2010 04:25 PM | |
| Black Forged Bracket 12 Inch | This thread | Refback | October 15th, 2010 05:52 PM | |
Threads Similar to: help lay out an engine build 4.6 2v
| Lay 'n Decals | BoeBastang | General Tech | 2 | January 7th, 2010 03:26 PM |
| As I Lay Dying | 707Stang | The Clubhouse | 26 | March 10th, 2009 11:27 PM |
| Lay off the Hoff! | JakeM | The Clubhouse | 24 | December 25th, 2008 02:15 AM |
| Engine Build Up or Engine Replacement... | OcOnnor220 | 99-04 | 8 | July 27th, 2008 03:54 PM |
| As I Lay Dying | Nameless122 | The Clubhouse | 3 | August 20th, 2007 03:56 PM |
