Discussing Fuel injectors in the 99-04 Forum. Curious, had stage 2 heads and and comp 270 cams done at Steen Racing and ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Fuel injectors |
14.631@93.51 @ 5800 FT
Yes you will need a new tune, but at your numbers you are definatly not maxing out stock injectors! They can go up to 400+!
#3 | |
Your stock injectors should be able to handle more power than that.
2001 YUGO GT
Hey they are in the business to sell and install parts. Have them cleaned, and they should go to about 400/450. Also change your fuel filter. I'm assuming you haven't done these things yet.
![]() I don't care if you lick windows, take the special bus or occasionally pee on yourself.. You hang in there sunshine, you're special. |
Threads Similar to: Fuel injectors
| Fuel Injectors | Mach Boy | 99-04 | 3 | November 7th, 2007 08:32 AM |
| Fuel Injectors/fuel pressure | 00silvergt | 99-04 | 4 | August 2nd, 2007 09:54 AM |
| Fuel Injectors | Euroeater95 | 94-95 | 5 | June 21st, 2007 11:02 AM |
| Fuel injectors | ssdell3 | 99-04 | 36 | June 20th, 2007 10:56 PM |
| fuel injectors | scubasteve041186 | V6 Mustangs | 7 | January 24th, 2007 02:44 AM |
