Help. Removal of the coolant cross over tube.
Old October 16th, 2010, 07:44 PM   #1
2000 mustang Gt
Project_Mustang is on a distinguished road
Send a message via MSN to Project_Mustang
how do you remove the coolant cross over tube? on the 4v or 96 Mark Viii.
theres two screws under it holding the intake manifold.
Old October 16th, 2010, 08:15 PM   #2
gdl
99 Cobra, 03 Mach1, 07 CS
gdl has a spectacular aura aboutgdl has a spectacular aura about
I'm not sure how similar the 96 would be to my 99 Cobra but when I pulled mine there were two bolts and then the tube is just pressed in with one o-ring on each side. I just used a long ratchet extension and wedged it under the tube in order to lever it out of the holes. I levered it up a little on each side, a little at a time in order to keep it from binding.
2007 Redfire California Special
http://i183.photobucket.com/albums/x...n/2007GTCS.jpg
2003 Dark Shadow Grey Mach 1
http://i183.photobucket.com/albums/x...born/Mach1.jpg
1999 Black Cobra Vert
Old October 16th, 2010, 08:26 PM   #3
2000 mustang Gt
i think they are same. gonna look into that in the morning thanks
Old October 17th, 2010, 03:24 PM   #4
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
LGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the rough
iTrader: 10 reviews
its gonna take some brute force probably.
once you take out the 2 bolts on either side, all thats holding it in are the 2 o-rings. mine was a royal PITA to get off. it took a base ball bat and alot of weight to get it to pop out. when you put it back in, make sure to clean up the bottom of the tube and where it slides in. also, i used a bit of silicone grease on mine and it went back on almost effortlessly.
BSD 100MPH Club
YMR #8975
4v Swap and a little Purple Bottle
MM Nitrous Club #7
MM Cobra Club #87
Threads Similar to: Help. Removal of the coolant cross over tube.
Coolant tube Woes.. blkragtop 99-04 11 July 5th, 2010 10:29 AM
coolant tube! mr. mopar 96-98 9 October 19th, 2007 01:21 PM
PI coolant tube AnglicoGT98 96-98 18 May 26th, 2007 02:03 PM
Help with PI Swap!!! Coolant tube!!! 96gt226410 96-98 6 April 9th, 2007 08:34 AM
