2001 GT Mustang Dyno Tune :(
Ok two things.
1, Need to put some high flow cats on the bbk xpip ooo wow way to loud. 2, Had a dyno tune done this weekend, and was a little sad, the best he was able to get out of the car was 235-RWHP and 275-RW Torque, I know they come stock 260 horse power and 302 pounds-feet of torque, but that is not at the rear wheel. Just thought with the mods it would have helped out more Mods: 2001 Mustang GT Auto Mods I have on now are: Cold Air Intake BBK 75mm TB BBK Plenum BBK XPIP no Cat Flow Master 40 Series 410's gears |
Sounds about right for what you have I would of expected somewhere around 240-245rwp but yeah the thing about the TB and plenum is you dont necessarily get any good gains from them without heads and cams also a 75mm has been proven to be too large for our cars when they are basically stock sometimes losing HP if not losing Hp only getting small gains compared to what you would get running a 70mm TB. The next thing I would do if you plan on adding more to your car is getting a set of headers many people have said this before you want the most air you can get coming in and at the same time going out headers would open it up and you should see some nice gains with your setup.
RIDE: 2000GT- MODS: 2007 3 VALVE ENGINE AND MORE...... |
cool thanks will check into the header. but i really need to get some high flow cats. i know when i get up monday morning at 4am and get ready for work, ooo everyone is going to hate me.
dose sound good but to much. i have not had a chance to try the car out next to another mustang, would really like to see how the 410 do, i can feel the extra push and feels good
#4 | |
1998 Z28
Unknown
is this an auto or 5 speed?
You do realize that even with the cats, once you get the LT headers it's going to open the sound up a bit more, right? Sometimes you just gotta tell the neighbors to deal with it. :wink
2001 Mustang GT
14.51
heh yeah
i work 4AM-1PM Monday through friday, which means I'm outside at 3:30 starting the car to let it warm up. i live in an OLD neighborhood with almost all seniors lol so it pisses them off. I've been caught by them several times wlakin in the house after work and getting "So, I heard that nice car of yours jsut sitting in the driveway this morning what were u doing?!" im like, "ehh, bitch i work, get off my loudness!"
#8 | |
#9 | |
1998 Z28
Unknown
sorry for the late response, but yes my 2001 gt is an Auto, but yes thought if i put on some high flow cats, not sure if there is any difference in high flow from one to another. but thought if i did get the headers next they would help out some, and might just bring it back to where it is now,but then i would have more power
also.... since you have 4.10 gears, i believe that the readings you get will be slightly lower than what they would be with stock gears, since you are "gearing down" the rear wheels
"America is all about speed. Hot, nasty, bad ass speed." Eleanor Roosevelt, 1936
so i robed myself of power by dropping down the gears?
NOOOO.... you def. didn't rob power, I'm saying the NUMBERS are lower on the dyno.... I'm not exactly sure how it works, but I read it somewhere.... I'm saying with 3.27 gears, you may have had numbers a little higher (like 240-45), but that JUST A NUMBER.
the gears helped you more in acceleration than any other mod you've got.... I dropped .4 in my 1/4 mile with 3.73's, so your going to be a little better still with the 4.10's.
o ok cool i understand now. i have been riding around some to try and go up next to another mustang just to see how the 410's would do. i can tell when i get on it now, it pushes pretty good, put a smile on my face
and i can still drive down the highway, not as fast but i can still do 6 with out getting the rpms up to high. i did get some rear suspension stuff upper and lower trailing arms added to the rear to help out with the tire spinning.
#15 | |
#16 | |
o yes i was able to tell the difference, from the stock 327 to the 410, now for gas, mmm still testing that one out. before i did the diablo tune and the gears. i was doing like 70mph at about 1800 to 2000 rpm, and getting an avg of 285 miles per tank. now after the tune and the gears i am doing about 56mpr at 2000rpms. but for gas, i can see i am using more, this is still a test tank, because the frist two i was out playing around some
. but just guessing i might hit about 250. not sure why since i am driving at the same rpms as i did before i did the tune and changed out the gears. but in a few days i can repost and give you more info on what i got out of this tank. hope that helps some. Mods: 2001 Mustang GT Auto Cold Air Intake BBK 75mm TB BBK Plenum BBK X PIPE no Cat MagnaFlow Cat Back 410's gears New Rear Upper/lower Control Arms |
Threads Similar to: 2001 GT Mustang Dyno Tune :(
| dyno tune | xedubx | 99-04 | 3 | July 16th, 2007 12:16 AM |
| dyno tune & flash tune | miafan | 2005 - 2010 | 4 | May 31st, 2007 05:05 AM |
| Dyno Tune? | justinsstang | V6 Mustangs | 26 | February 26th, 2007 11:49 PM |
| 2001 Mustang GT Dyno..... HELP | bnicholl | Modular Mustangs | 10 | February 15th, 2007 11:31 PM |
| Dyno Tune | miafan | 2005 - 2010 | 6 | January 22nd, 2007 05:45 PM |
