Signs of a bad tensioner? Shredding belts - Forums at Modded Mustangs
post #1 of 73 Old November 2nd, 2010, 09:19 PM Thread Starter
Shaun13GT/CS's Avatar
iTrader: 27 reviews
The other day, Friday I was driving. Very casual, all of a sudden my belt shreds...wtf? I put it on like 2 weeks ago and it was fine. Before I was having an issue just tearing 1 rib off, now it shredded this one.
Had to pay for a tow truck because It was trafficy and had no power steering/brakes/water pump. That was $110. Fuckin rediculous.
Anyways latley when I start the car up, at idle, I can hear this squeaking sound or a chirping noise (no not the TOB lol) So could my tensioner be the cause to the belts ripping? Or tearing one rib off.
BTW, I ran a 107.38 belt, tore off a rib, then a 107.5 belt, tore off a rib (both closest to timing cover) then back to a 107.38 and this one shredded completley now I have a 107.5 again.
Anyone have any ideas? Pulley alignment seems dead on. Theres no shaft play on the blower. Im at a loss though.
14 Mustang GT M6 - TVS, Kooks Full Exhaust, AED Tune
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
09 Corvette Z06 - 11.7 @ 123.5 (stock)
13 Mustang GT Bolt Ons - 11.58 @ 122.13
03 Mustang GT Vortech - 11.98 @ 118.68
Shaun13GT/CS is online now
post #2 of 73 Old November 2nd, 2010, 09:23 PM
86er's Avatar
did the squeak/noise only happen on cold starts or any start, and did it go away or get worse when rpms were given to the engine?
Just a truck
86er is offline
post #3 of 73 Old November 2nd, 2010, 09:33 PM Thread Starter
iTrader: 27 reviews
More so when its cold, and it went away as the motor got warm. Or like 10 minutes after anyways
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #4 of 73 Old November 2nd, 2010, 09:44 PM
US Air Force (retired)
Eagle2000GT's Avatar
Damn, I thought you had that figured out. If all of the pulleys are aligned then something else is putting stress on the belt. A bad bearing in a pully might do that. Just a guess. Do all your pulleys spin freely?
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370.
USAF 1969-1996: Vietnam veteran. Aircraft maintenance. ICBM Operations. Research & Development.
Eagle2000GT is offline
post #5 of 73 Old November 2nd, 2010, 09:46 PM Thread Starter
iTrader: 27 reviews
Should the supercharger pulley spin freely too? Im gonna go check real quick
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #6 of 73 Old November 2nd, 2010, 09:50 PM
On mine there is a little resistance. It's self lubricated so its spinning oil as well as everything else. I don't know what a Vortech is suppose to do.
post #7 of 73 Old November 2nd, 2010, 09:59 PM
BakerFX4's Avatar
iTrader: 15 reviews
ive actually had the idler behind my blower catch on fire! The stock idler wore out and caught on fire. I had noticed some squeaking not long before too but didnt know WTF? Well.... i found out at a red light with smoke coming out from under the hood!
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
BakerFX4 is offline
post #8 of 73 Old November 2nd, 2010, 10:05 PM
86er's Avatar
start it up and then spray the tensioner pulley with like wd40, if it goes away, change the tensioner or just the pulley. If it still squeaks, spray the other pulleys until you find the one that stops squeaking when sprayed.
Just a truck
86er is offline
post #9 of 73 Old November 2nd, 2010, 10:06 PM Thread Starter
iTrader: 27 reviews
Thanks for the info. All my pulleys spin freely. Just checked. No resistence on them. Next time I start it up Ill have to see if its the tensioner. I may replace that just to be safe. Its only like $35
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #10 of 73 Old November 2nd, 2010, 10:07 PM Thread Starter
iTrader: 27 reviews
Originally Posted by 86er View Post
it sounds like the tensioner, take the belt off and see how much resistance the tensioner gives you when you move it
The belt is totally off now, so just see how hard it is to pull up on?
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #11 of 73 Old November 2nd, 2010, 10:12 PM
86er's Avatar
damn son, quick on the reply, lol even on the edit lol. This is tough to explain, but here I go. The tensioner should give a decent resistance, but nothing hulk mad strength to move, if it moves with very little effort, the springs starting to wear. But if its shredding belts, its prob gonna be the pulley on the tensioner and not so much the spring, but if the belts off, doesnt hurt to check
Just a truck
86er is offline
post #12 of 73 Old November 2nd, 2010, 10:15 PM Thread Starter
iTrader: 27 reviews
lmao. I know I hit the refresh button an saw your post.
I just tried, definatley some resistence there. Wasnt real easy to move. Idk...How else can I tell if the bearings on the idlers are gone? They spin freely. And like I said I can hear a faint squeak at startup, and goes away as I drive, but it doesnt get louder as I bring the RPMs up.
Sorry for all the questions, Im just lost at the moment
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #13 of 73 Old November 2nd, 2010, 10:20 PM
86er's Avatar
tensioner sounds good. Just b/c the pulley spins freely doesnt mean its good. Does it make any sound when you spin the idlers or tensioner pulley? If the bearings are good, it will spin smooth and silent. If its going/is bad youll hear noise or have some slop on the pulley.
or as stated in another post, put a belt on start it and spray the pulleys one at a time with wd 40, and the one that stops squeaking is the culprit.
Just a truck
86er is offline
post #14 of 73 Old November 2nd, 2010, 10:23 PM Thread Starter
iTrader: 27 reviews
They all are pretty silent. I dont hear anything coming from them.
When it does the squeaking shit, Ill hose it with WD40...other than that..I dont know? Maybe ill try shootin a load on the belt and see if that helps??
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #15 of 73 Old November 2nd, 2010, 10:26 PM
86er's Avatar
Um, Id stick to the WD 40, I wouldnt put my whooperdooter anywhere near a serp belt lol.
Just a truck
86er is offline
post #16 of 73 Old November 2nd, 2010, 10:26 PM
mell0's Avatar
Send a message via AIM to mell0
mine chirps on cold start ups as well. i've pinpointed it to the pulley on the tensioner itself. if i spray it with wd40 the squeaking stops. new pulley bearings are like $5 from ford, cheaper than the $35 tensioner.
2002 Procharged GT
12.503 @ 113.08
351rwhp 353rwtq
Car Videos: http://www.youtube.com/user/mell00ut5?feature=mhee
mell0 is offline
post #17 of 73 Old November 2nd, 2010, 10:29 PM Thread Starter
iTrader: 27 reviews
Lmao! yea no doubt. Thanks for the help man, reps for u
Cool good info, thanks man
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #18 of 73 Old November 2nd, 2010, 10:34 PM
tbirdscwd's Avatar
iTrader: -1 reviews
bad tensioner can definitely schred belts. Double check that the belt isn't making contact with the side of the tensioner itself while the car is running. Look at the side of it where the belt runs down across the side and see if there is any sign of rubbing from the belt. I know when I tried to switch to a shorter belt on my procharger setup, I put the new belt on and it just rested against the side of the tensioner
Fun: 2004 Mustang GT
DD: 1994 Ram 2500 Cummins 4x4
Borla "Stinger" Exhaust Vids
tbirdscwd is offline
post #19 of 73 Old November 2nd, 2010, 10:40 PM Thread Starter
iTrader: 27 reviews
Thanks, Ill definatley take a look. If it is rubbing, is that from the belt being to short? Or the tensioner being bad?
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #20 of 73 Old November 2nd, 2010, 10:45 PM
tbirdscwd's Avatar
iTrader: -1 reviews
I would replace the belt tensioner anyways if it is the stock one for sure......but aside from that, if the belt is too short, it will rub on the tensioner itself and eat through belts.
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/190508-signs-bad-tensioner-shredding-belts.html
Thread Signs of a bad tensioner? Shredding belts | Forums at Modded Mustangs | BoardReader This thread Refback February 7th, 2012 12:11 AM
Shredded Belt This thread Refback February 2nd, 2011 08:39 AM
Shredded Belt This thread Refback January 31st, 2011 10:48 AM
