Infamous Lincoln Mark VIII engine swap thread. - Page 3
LinkBack (16) Thread Tools
Old November 4th, 2010, 03:22 PM   #41
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
I stickied this and also asked an editor to get ahold of you and work this into a how to article for the site...
Facebook
Google+
Old November 4th, 2010, 05:55 PM   #42
CSTANG01's Avatar
2001 Mustang GT
CSTANG01 is on a distinguished road
What pulleys and accessories do you use? I have a 94 Mark 8 4.6 going into a 01 GT. I also vote in favor of making this subject as a great tool for future people doing this conversion.
Old November 4th, 2010, 06:03 PM   #43
Captain Opinionated!
HurrycaneStang's Avatar
01' Cobra Vert
When life throws you a curve, downshift and take it vigorously.
HurrycaneStang is a jewel in the roughHurrycaneStang is a jewel in the roughHurrycaneStang is a jewel in the rough
Send a message via Yahoo to HurrycaneStang
maybe a list of all the extra components needed, or little tweaks that need to be done, that would make it easier for people compiling a to-do/to-buy list.....
Old November 4th, 2010, 06:34 PM   #44
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
LGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the rough
iTrader: 10 reviews
you will use the stock mark viii pullies and alternator. your 2v power steering pump and ac compressor will swap directly over so there is no need to completely remove and drain those. i left both of those hang when i pulled the motor (with the exception of the ac because i chose to delete that completely)
BSD 100MPH Club
YMR #8975
4v Swap and a little Purple Bottle
MM Nitrous Club #7
MM Cobra Club #87
Old November 4th, 2010, 06:43 PM   #45
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
iTrader: 10 reviews
awesome man!!
sounds good to me!
BSD 100MPH Club
YMR #8975
MM Nitrous Club #7
MM Cobra Club #87
Old November 4th, 2010, 06:56 PM   #46
4valvegt's Avatar
03 Cobra
4valvegt is on a distinguished road
Awesome! I did an almost identicle swap into my 01 GT, the b heads respond really well under boost unfortunetly for me my timing chain crawled and destroyed just about everything. Maybe it should be known that there needs to be a pilot bearing put in the crankshaft aswell since the mark 8 was auto if its goin into a manual. A buddy of mine forgot in a swap he did had some nasty vibrations without it.
MM Cobra Club #86
2003 Mineral Grey Cobra
2004 True Blue F-150 FX4
Old November 4th, 2010, 07:02 PM   #47
4valvegt's Avatar
03 Cobra
Did you have clearance issues with your heater core lines hitting the passenger valve cover? I actually had to slightly bend the piping up to clear it.
MM Cobra Club #86
Old November 4th, 2010, 07:06 PM   #48
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
iTrader: 10 reviews
no i actually didnt. i had alot of trouble getting the motor in because of how tight it is at the back of the motor and the firewall. there is no room back there at all (that really is an understatement) i'm real glad i cut the lines off down low and let the hoses hang before putting the motor in, otherwise i dont think i would have gotten them on. its a must to cut the lines before the motor goes in though as i'm sure you know lol.
BSD 100MPH Club
YMR #8975
MM Nitrous Club #7
MM Cobra Club #87
Old November 4th, 2010, 07:28 PM   #49
4valvegt's Avatar
03 Cobra
Yes haha i figured this out after I bolted the motor in, i had to take a cut off wheel to the heater hoses and do some custom work lol.
MM Cobra Club #86
Old November 4th, 2010, 07:33 PM   #50
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
iTrader: 10 reviews
haha yeahhh if i remember rightly i asked you what you did about the heater hoses
actually i'm 100% sure you did. you sent me some pictures too and i gave you some reps for it. i tried the 2v coils like you did with the 4v boots and springs and that failed miserably for me. still cant figure that one out. once i went to 4v stuff, everything worked. maybe the 4v coils produce more voltage or ??
BSD 100MPH Club
YMR #8975
MM Nitrous Club #7
MM Cobra Club #87
Old November 4th, 2010, 07:47 PM   #51
4valvegt's Avatar
03 Cobra
Yes sir that was me I remember you asking, glad to see you were successful. Mine ran great i actually ground all the tabs off my gt accel coils so they would fit in the valve covers and bought the cobra boots and springs. It was a crappy way of doin it but got low on funds at that point. I loved the car sucks that the motor had to self destruct, I put the stock motor back in and sold it.
MM Cobra Club #86
Old November 5th, 2010, 12:29 AM   #52
01' Cobra Vert
Quick question, what size injectors come in the 97-98 Mark VIII? Are those the 24lbs or 19lbs?
Old November 5th, 2010, 12:51 AM   #53
brett22's Avatar
2004 Mustang V6
heart of a 4V
brett22 will become famous soon enough
19lb/hr are on 2v engines and 24lb/hr are on 4.6 4v's from 93-98, The termi has 39lb/hr injectors and the lightning uses 42lb/hr injectors
Turboed 4.6 4V build in progress
Milwaukee School of Engineering
Class of 2015, BA in Mechanical Engineering
2004 Terminator 100% Stock 5000 Miles
Red 2004 V6 (swapping in a turboed 4.6)
Old November 5th, 2010, 01:02 AM   #54
brett22's Avatar
2004 Mustang V6
heart of a 4V
Injector size----------Max engine hp
19-------------------304
24-------------------384
39-------------------624
42-------------------672
83-------------------1328
for 45psi fuel rail pressure and 90% injector duty cycle
numbers may be off a little bit but should be within +/-10hp
Old November 5th, 2010, 01:48 AM   #55
01' Cobra Vert
Cool, thanks alot man
Old November 5th, 2010, 08:46 AM   #56
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Is that crank or wheel?
39's and 42's I have never seen on a car making over 500rwhp...
Facebook
Google+
Old November 6th, 2010, 09:32 PM   #57
01' Cobra Vert
Will a 99-04 cobra intake manifold still fit a 98 Mark VIII engine? or would I be better off with a 96-98 intake mani? Thanks guys, sorry im gonna be asking alot of questions, presently acquiring all the parts I need...
Edit: Will all parts interchange between the 96-98 and 99-04 cobra engines, im referring mostly to the throttle cable, headers, EGR Tube and such, thanks again
Old November 6th, 2010, 09:43 PM   #58
CSTANG01's Avatar
2001 Mustang GT
96-98 B Heads are different than the 99 and up C heads. 97 -98 Lincoln Mark 8 Intake isnt bad but im sure the 96-98 Cobra is better but by how much who knows.
Old November 6th, 2010, 10:21 PM   #59
01' Cobra Vert
Cool, does that go for the throttle cable too, only a 96-98 will work?
Old November 6th, 2010, 10:46 PM   #60
Joeking316's Avatar
1999 Mustang GT
Joeking316 is on a distinguished road
Great piece LGHTNG05GT I needed this 3 months ago lol Thanks 4 ur help AGAIN!! If u use the 96-98 Cobra intake yes it throttle cable works best but if u use the mark VIII use its cable the cobra's little short (found that out hard way) I have herd of the 99& up cobra may work cant confirm it tho
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/190648-infamous-lincoln-mark-viii-engine-swap-thread.html
Mark Viii heads/intake swap on my NPI shortblock...why not?? This thread Refback February 22nd, 2012 06:46 PM
Finally decided mark 8 swap - SVTPerformance This thread Pingback January 26th, 2012 08:15 PM
Mark Viii heads/intake swap on my NPI shortblock...why not?? This thread Refback January 4th, 2012 06:48 PM
a lil help needed | Mustang Forums at StangNet This thread Refback December 31st, 2011 04:18 PM
Blew my engine... What to do now? Your opinions & ideas - MustangForums.com This thread Refback December 27th, 2011 10:15 PM
a lil help needed - Mustang Forums at StangNet This thread Pingback October 31st, 2011 02:57 PM
Need advise for my 4v mark viii swap and drivetrain questions - Ford Mustang Forums : Corral.net Mustang Forum This thread Pingback October 24th, 2011 10:20 PM
98 mark 8 in 03 gt, do i need to swap the cop`s polarity ? - Ford Mustang Forums This thread Refback September 15th, 2011 05:58 PM
First post.........(nervous) lots of pictures - Page 3 - SVTPerformance This thread Pingback August 9th, 2011 02:13 PM
Thread Mark VIII 4v Swap? | Ford Mustang News: Review, Preview. Owners, Racing, Wheels, Repairs - MustangForums.com | BoardReader This thread Refback January 10th, 2011 08:27 AM
Mark Viii heads/intake swap on my NPI shortblock...why not?? - GrandMarq.NET - Panther Headquarters This thread Refback December 22nd, 2010 07:15 AM
Mark Viii heads/intake swap on my NPI shortblock...why not?? - GrandMarq.NET - Panther Headquarters This thread Refback December 22nd, 2010 05:54 AM
Another Markv111 swap thread This thread Refback November 23rd, 2010 12:15 PM
while i was away - YMR This thread Refback November 23rd, 2010 11:10 AM
mark VIII swap - MustangForums.com This thread Refback November 19th, 2010 09:38 PM
while i was away - YMR This thread Refback November 18th, 2010 10:40 PM
Threads Similar to: Infamous Lincoln Mark VIII engine swap thread.
Lincoln Mark VIII Motor Swap? 98FireyGT! 96-98 13 April 13th, 2012 01:02 AM
99-04: The Infamous Lincoln Mark VIII engine swap thread. LGHTNG02GT Articles - Engine, Other 0 November 3rd, 2010 06:29 PM
engine swap from 99 v6 - 1993 lincoln mark viii v8 4.6 ? Horseyxpowered V6 Mustangs 6 June 21st, 2010 11:10 PM
4.6 from a lincoln mark viii in a foxbody swap? rusty2407 5.0 Mustangs 4 November 20th, 2008 10:27 PM
Lincoln Mark VIII to 04 GT swap Straits15204 99-04 7 June 17th, 2008 05:04 AM
