Engine to Bellhousing bolt size - Forums at Modded Mustangs
post #1 of 9 Old November 3rd, 2010, 06:46 PM Thread Starter
brett22's Avatar
What size are the bolts that connect the bellhousing to the engine of a 98 cobra(pretty sure the bolts are the same for all 4.6's). I bought 10mm 1.5 pitch bolts and they sorta turn in but don't want to force them if they are not the right size. I am using them to bolt my engine to me engine stand. I was almost positive the size I said was right but it doesn't seem so.
Mechanical Engineer at Kondex Corporation
brett22 is offline
post #2 of 9 Old November 3rd, 2010, 08:21 PM
mm's nitrous mod
SWEET2KSTANG's Avatar
iTrader: 8 reviews
i am pretty sure that is the correct size. you may try running a tap thru the block to see if there is just some debris in the holes.
wagon burner built! track times coming soon!(04 lightning)
follow shop builds on facebook at: MP2 Performance
SWEET2KSTANG is offline
post #3 of 9 Old November 3rd, 2010, 08:48 PM
ndfrspd's Avatar
man i would just go up to your local ford dealership and order the bolts or call and order them over the phone, i wouldnt try and match them yourself or buy them at a hardware store....
ndfrspd is offline
post #4 of 9 Old November 3rd, 2010, 08:55 PM
UnixHH's Avatar
Send a message via Yahoo to UnixHH
Main cap bolts are the same size. I used 4 main bolts to bolt the engine to the stand.
480RWHP 450RWTQ 15psi @ 15* on 91 octane
UnixHH is offline
post #6 of 9 Old November 3rd, 2010, 09:06 PM
UnixHH's Avatar
its a M10 (10mm) size bolt (hes not talking about the bolt head, hes talking about the thickness of the threaded stock) i do not know the thread pitch though
UnixHH is offline
post #7 of 9 Old November 3rd, 2010, 11:42 PM Thread Starter
brett22's Avatar
Yeah I think I may have to do this, some of the 4 bolts turn in farther than the others so it is prolly the right size but just not clean threads. I didn't want to screw any threads up since the block is aluminum.
Ford=to expensive, plus these are just for holding it to the engine stand, I will buy all new bolts when I have to hook up my new tranny to this new engine I'm putting in.
Thanks but just looking for the 4 bolts for the engine stand
brett22 is offline
post #8 of 9 Old November 4th, 2010, 12:24 AM
mm's nitrous mod
iTrader: 8 reviews
i went and got mine from advanced.
post #9 of 9 Old November 4th, 2010, 05:09 PM Thread Starter
brett22's Avatar
cleaned the holes up with a tap and the bolts go in great now, will kept it on the stand sometime on friday
brett22 is offline
Human Verification
