Nitrous Question: Nozzle vs TB Plate
I have a 99 Mustang GT that I'm looking to add a bit of Nitrous to. My dilema is which way to deliver the nitrous, via a throttle body plate or via a nozzle in the air intake tube before the tb.
I'm planning a wet system. From what I've read the more atomized and mixed the NO2 is with the Fuel the better. My question is which system provides a better mix or does it even make a difference? Is one vs the other better at resisting puddling? Thanks for any insight. And if this has been discussed and I missed it in my search, sorry for the repeat. |
MM's nicest mod, :)
the plate kit will prevent puddling a little bit better but anything under a 200 shot you really don't have to worry about anyways if you go a good fuel pump. I am looking for a plate to replace my nozzle so i can run a 200 shot since i am going to have a seperate fuel system for it.
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
+1
Work Hard....Play Harder.
Good info.
Thanks! Have you seen these plates? Not sure how well they work, but the price isn't bad. |
i'm getting the NX plate conversion for my car
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports. |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
i have the n/x plate on mine, no problems here. i am in the process of getting larger nitrous jets which will get me up to a 120-125 shot.
NX plate FTW .. never had problems ...
Car For Sale on Autotrader.com 04 Silver GT 32K Miles
Parts 4 Sale: 18" Wheels SSR GT3 replicas w/ tires Steeda Tri-Ax 10lb N20 Bottle w. gauge (2) Kirkey Racing Seats w/ RCI 5 Pt. belts Steeda & Momo shift knobs SB GT Spoiler |
Sweet.
I spent most of the weekend drooling over various nitrous kits. The main battle was between NX plate kit ($$) and building my own kit from using DynoTune Nitrous parts. (small $$) Just means I'll be patient and save the extra cash and get the right kit the first time. :-) It funny how once you start modding these cars, you can't stop. I'm going to have to get a few extra jobs to support my habit. Thanks for the advise all! |
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
You could grind down your EGR port, weld the hole up, drill and tap a port, and install your nozzle in the back side of the TB.
#11 | |
11.21@123 -150 shot
![]() iTrader: 1 reviews
Ok.Thanks for the heads up.
![]() ______________________________ 1999 Mustang GT Convertible 2001 F150 Harley Edition 2004 R6 |
Threads Similar to: Nitrous Question: Nozzle vs TB Plate
| nitrous works plate kit | 92sspnotchback | 5.0 Mustangs | 1 | September 28th, 2007 08:13 PM |
| nitrous express plate system | Modern_Muscle | 2005 - 2010 | 6 | September 26th, 2007 12:35 AM |
| Nitrous throttle body plate | 95StangSVT | 94-95 | 0 | July 17th, 2007 07:06 PM |
| 3v 4.6L Nitrous Plate... | 1FastFox | 2005 - 2010 | 0 | April 5th, 2007 05:30 PM |
| Nitrous nozzle throttle body screwed | 89Domindart | 5.0 Mustangs | 23 | January 31st, 2007 02:49 AM |
