diablo question
Old November 8th, 2010, 01:03 AM   #1
MM's most Hated
twinmill's Avatar
2001 Mustang GT
twinmill is infamous around these partstwinmill is infamous around these partstwinmill is infamous around these partstwinmill is infamous around these partstwinmill is infamous around these partstwinmill is infamous around these partstwinmill is infamous around these partstwinmill is infamous around these parts
diablo question
so i picked up the tuner from la today.
plugged it in, well i got to the screen where i can pick the options.
Well all i saw was an 87 performance tune, 93 octane tune, modify stock tune, and i think a back up tune option
... i thought their was supposed to be a 91 ocatane tune??? should i just load the 93 octane tune if i run 91?
sry all i got was the box and tuners. I didnt get any directions
MM's Most Hated
Old November 8th, 2010, 01:23 AM   #2
tbirdscwd's Avatar
12.88 @ 109.45 N/A
tbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to all
iTrader: -1 reviews
Run the 93 octane tune with 91. Listen for any signs of detonation, but I ran it on my car with 91 and never had an issue. I know a few guys that have done the same with no problems.
Fun: 2004 Mustang GT
DD: 1994 Ram 2500 Cummins 4x4
Borla "Stinger" Exhaust Vids
Old November 8th, 2010, 01:35 AM   #3
MM's most Hated
twinmill's Avatar
2001 Mustang GT
listin for detonation? how can i tell? how much mor beneficial is the 93 over 87?
MM's Most Hated
Old November 8th, 2010, 01:41 AM   #4
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
sometimes it is hard to hear knock/ping on mod motors. ford had to do away with the knock sensor due to so much engine noise. if it sounds like beans in a can get off the gas and go with the other tune. to be honest i have not heard anything of the sort on a mod motor. it is common on the early 5.0 push rod motors to hear ping. i would pay the 50 dollars and get a 91 octane tune to be safe
Old November 8th, 2010, 01:45 AM   #5
tbirdscwd's Avatar
12.88 @ 109.45 N/A
iTrader: -1 reviews
There really isn't a whole lot between the two tunes. Basically the 93 tune just has a couple extra degrees of timing added to it.
Detonation sounds like a ping or loud pop coming from the engine and in most cases will happen under hard acceleration. If your exhaust is really loud it can be a little hard to hear. So, try to listen with the windows up and when driving on a smooth road to minimize other noises from interfering
Old November 8th, 2010, 02:26 AM   #6
MM's most Hated
twinmill's Avatar
2001 Mustang GT
where can i pay and get the 91 tune? i dont have a cable to dl it to the device???
would it be smarter just swapping to 87 gas and runnin that. Or actually buying the 91 tune and running that?
MM's Most Hated
Old November 8th, 2010, 02:28 AM   #7
stal94gt's Avatar
2003 mustang v6 ;)
slow
i would run 87 for now and order a tune. the cable should be a standard printer cable usb. back in the day i ordered a tune off americanmuscle
Old November 8th, 2010, 02:32 AM   #8
MM's most Hated
twinmill's Avatar
2001 Mustang GT
how much different is the 87 and 91 tune.
i work at bb so hopefully we have the cable
MM's Most Hated
Old November 8th, 2010, 02:39 AM   #9
stal94gt's Avatar
2003 mustang v6 ;)
slow
even if you dont have the cable you can pick one up at walmart for about 6-10 dollars. and yes there is a diff with the lower octane tunes. they have lower timing and you wont be as fast but for 50 dollars and a email tune you will fix that. its not worth running a tune your not sure about and wont be able to tell if your causing damage
Old November 8th, 2010, 02:46 AM   #10
MM's most Hated
twinmill's Avatar
2001 Mustang GT
dang is it a waste spending the 50$'s for a tune now? i dont have to many after market parts.if i get gears or an intake manifold, wouldnt i have to get another tune?
MM's Most Hated
Old November 8th, 2010, 02:50 AM   #11
stal94gt's Avatar
2003 mustang v6 ;)
slow
why would you get a manifold? yes you need another tune for gears but you can tell the guy which gears you want to put in and they will send you a seperate tune for them for free
Old November 8th, 2010, 02:55 AM   #12
MM's most Hated
twinmill's Avatar
2001 Mustang GT
wait how does the tunes work from bama since i bought my device else where?
do i pay the 150?
get a 91 street, performance, and race???? and then theyll update them for free.? or do i gotta pay 50$ everytime
and the reason is im definitly thinking about slappin a bottle on.
MM's Most Hated
Old November 8th, 2010, 03:00 AM   #13
stal94gt's Avatar
2003 mustang v6 ;)
slow
im not sure my car has to go on a dyno everytime for a retune. last time i bought tunes online was 2 years ago and i payed 50 dollars for 3 tunes.
Old November 8th, 2010, 03:15 AM   #14
MM's most Hated
twinmill's Avatar
2001 Mustang GT
any1 wanna enlightin me where i can get the best reasonably tunes from?
MM's Most Hated
Old November 8th, 2010, 04:32 PM   #15
MM's most Hated
twinmill's Avatar
2001 Mustang GT
bump
MM's Most Hated
Old November 8th, 2010, 04:59 PM   #16
PhxMustang's Avatar
2002 Mustang GT 4.6L
PhxMustang is on a distinguished road
Directly from the manual for states such as California and Arizona where they sell 91 octane as premium retard the spark timing by 10% on both rpm ranges. 0-4k and 4k-7k
Steeda UDP, K&N CAI, FlowMasters 40’s, Polly Mounts, Aluminum D/S, Chrome Moly Flywheel, Centerforce DF, MM (quad, cable, adj.), Lakewood LCA’s, MM FLSFC’s, Predator canned 93 tune.
Old November 8th, 2010, 05:15 PM   #17
Baker Jr.
bandity2k00's Avatar
Coming after build!!
bandity2k00 is a jewel in the roughbandity2k00 is a jewel in the roughbandity2k00 is a jewel in the rough
Send a message via AIM to bandity2k00
trick tuners
MMR-Modular Mustang Racing
Phils Machining-For your ABS Module Delete Manifold!
American Muscle-www.Americanmuscle.com
HorsePower By Hermonn-TUNER
THANKS TO ALL SPONSORS,READY FOR THIS 2012 RACING SEASON!
Old November 8th, 2010, 05:16 PM   #18
Authorized Vendor
AMChrisRose's Avatar
2007 Mustang GT
AMChrisRose will become famous soon enoughAMChrisRose will become famous soon enough
do i pay the 150?
$150 for 3 tunes - you'll get a Performance, Street and Race tune. After that, you'll get free tune adjustments down the road on anything that you need up until heavily modified F/I applications.
Chris Rose | AmericanMuscle.com
Toll Free: 866.727.1266 | M-F 9AM-9PM EST | Sat 10AM-4PM EST
Bama Hotline: 888.226.9764 | M-F 9AM-5:30PM EST | Sat 10AM-4PM EST
Need Help? PM AMShaneLesky for immediate assistance!
Old November 8th, 2010, 10:17 PM   #19
Bajis's Avatar
Bajis is on a distinguished road
^ Thats a good deal. I think thats what I'll do when I pick up a predator.
White Knuckle Autosports
Old November 8th, 2010, 11:24 PM   #20
MM's most Hated
twinmill's Avatar
2001 Mustang GT
hey its bajis.
cough cough now bajis need to stop leaving his stang at home eveytime he hits the streets with me
MM's Most Hated
Threads Similar to: diablo question
Diablo question? 93HatchsBFF 99-04 23 August 2nd, 2008 11:19 AM
Diablo question? 93HatchsBFF The Clubhouse 1 July 26th, 2008 12:28 AM
Diablo preditor Question? RyanHNT 2005 - 2010 4 March 9th, 2008 12:42 PM
Diablo/computer question! RyanGT 99-04 5 January 5th, 2008 06:14 PM
Diablo Tuner Question sikdogs Audio/Video 13 February 28th, 2007 06:49 PM
