Best Plenum and Throttle body for the money? - Page 2
Old November 11th, 2010, 01:38 PM   #21
2002 Mustang GT 4R70W
11.65@115.86 2V N/A
Yellow02GTauto will become famous soon enough
Stay with 410's, BBK 78mm combo, and up that stall to a 4000.....2200 is way to small.....4000 is the perfect match as you get into your full tq at that range off the line and at your shift points.....4000 is just as streetable as stock since our converter lock at part throttle....with everything else the converter to 4000 will knock your times down by 1/2 sec....
"ED"
"You gonna let an Automatic beat ya?"
2002 Zinc Yellow GT 355 HP/348 TQ N/A
TFS 44cc heads,Stage 3 cams, Forged-Aluminum block, 9.3 CR, full exhaust and bolt ons 11.65@115.86 so far
built to handle 1000hp....
Old November 11th, 2010, 01:46 PM   #22
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
look at all these "bbk" reps! lol.... Accufab is what i run. I will be swapping up my setup and could sell you my 75mm plenum for a good price. I will need to keep my TB though. Accufab >BBK IMO.... you get what you pay for.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old November 11th, 2010, 02:51 PM   #23
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
Accufab plenum/tb combo here. Bought it used a few years ago for $300.
2003 DSG Mustang GT 5spd
Full Bolt On's, Suspension, Built Rear, V1 S
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60'
Intercooled: 362/370
Old November 11th, 2010, 07:46 PM   #24
1999 GT 35th LE
99GT35thLE has a spectacular aura about99GT35thLE has a spectacular aura about
Is your typhoon intake manifold polished? If so that black BBK would not look good on a polished intake in my opinion. If your intake is polished go with the polished Accufab.
I've been replacing my BBK stuff, my BBK TB butterfly valve started scrapping the body, and then it would leak air when it was closed. So I replaced it along with my leaking BBK valve covers.
Drive it like you stole it
Old November 11th, 2010, 07:48 PM   #25
2VSouth's Avatar
2VSouth has a spectacular aura about2VSouth has a spectacular aura about
iTrader: 6 reviews
I have the C&L plenum with an SVO 70mm TB. It's a different combo, but works well.
Old November 11th, 2010, 08:01 PM   #26
GP-SE's Avatar
GP-SE is on a distinguished road
accufab if you can afford it, and 4.10's!
Old November 11th, 2010, 08:21 PM   #27
y2k02's Avatar
02 Mustang GT
9.91@133
y2k02 has a spectacular aura abouty2k02 has a spectacular aura abouty2k02 has a spectacular aura about
You gain very little hp with a aftermarket upper plenum.
My TB is a ford unit being 70mm.
2002 GT
PI heads
Twin 60mm turbos
Th400
6.34@114 1/8
9.99@137 1/4
http://i160.photobucket.com/albums/t...t/DSCF5654.jpg
http://i160.photobucket.com/albums/t...2gt/IMG060.jpg
Old November 12th, 2010, 12:00 PM   #28
11.463@121.50
saxmanJJ will become famous soon enoughsaxmanJJ will become famous soon enough
I have a FRPP 70mm throttle body with a BBK Plenum. My car makes over 400rwhp (Vortech/cammed). I wonder if switching to 75mm or 78mm throttle body would make any difference at all.
MM Bracket Racing Crew Member #5
Old November 12th, 2010, 12:35 PM   #29
moneygreenstang's Avatar
2001 Mustang GT
moneygreenstang will become famous soon enough
Dragon oval throttle body plenum
200
Then any bullit, marauder, 99-01 cobra throttle body ...
01 GT Vert - Triple Black - 2v 5.4 270/340
00 Lightning - Triple Black - 2v SC 5.4 400/500
Brand New Tubular UCA and LCA set for sale PM me
Slightly Used 05-09 Halo Headlights for sale PM me
Old November 12th, 2010, 12:36 PM   #30
2001 Mustang GT
Dragon 96-04 4.6 2V GT Oval Throttle Body Adapter: eBay Motors (item 260278697793 end time Dec-11-10 16:13:40 PST)
Old November 12th, 2010, 04:14 PM   #31
11.463@121.50
Neat!
Threads Similar to: Best Plenum and Throttle body for the money?
BBK 78mm Throttle Intake vs Accufab 75mm Throttle Body/Plenum andrewskaggs 99-04 19 June 11th, 2010 08:48 AM
C&L Plenum vs BBK 78mm throttle body/plenum rider4life350 99-04 29 October 25th, 2009 05:25 PM
Throttle Body and Plenum? trueblue02GT 99-04 54 May 14th, 2009 01:06 AM
Throttle body and plenum jem02 99-04 16 January 20th, 2009 08:23 AM
plenum/throttle body Jucostud 96-98 11 February 19th, 2008 12:19 AM
