Stalling problem- please help
Old November 9th, 2010, 10:32 AM   #1
derekirhodes's Avatar
2001 Mustang GT
derekirhodes is on a distinguished road
I'm at my wits end with my 01 GT. For the last couple of weeks, it has been stalling out on me with no warning signs. I would turn off the ignition, turn it back on, and be good to go. My first thought was fuel filter, so I changed it. It didn't fix the problem. I then changed the fuel pump, and to my suprise, it is still stalling out on me. When it stalls, the odometer shows dashes. a few times the check fuel cap has come on when i would try to restart it. I have a K&N, and serviced it as well, so that's likely not the problem. I checked my pcv valve, and I'm getting suction so it seems to be ok.
I also bought a code scanner, and the only code it has brought up has been the catalyst threshold out of limits, but i am figuring that this is due to my off-road x-pipe. I'm concerned that it's the computer.
Has anyone had a similar problem and can offer any words of wisdom? I also would like to say that these forums are better than any service manual you can buy at the auto parts store.
Old November 9th, 2010, 10:34 AM   #2
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Have you tried cleaning the IAC? I'd start there.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old November 9th, 2010, 10:44 AM   #3
2001 Mustang GT
I'll try that. Thanks
Old November 9th, 2010, 11:51 AM   #4
2001 Mustang GT
I cleaned it using electrical cleaner and ran it for about 15 minutes. The idle was high the 5 minutes it took me to drive back from the store. I let it idle for 10 minutes, and it was slowly coming down to the normal range, but was still erratic. I have a 90 mile commute home from work, so I'll have to see what happens then. It stalled a few times this morning on me, but started back up every time. Any other thoughts?
Old November 9th, 2010, 11:55 AM   #5
2004burns can only hope to improve
dose it sputter before it dies
Old November 9th, 2010, 12:01 PM   #6
Tang Stang's Avatar
Remove the IAC from the plenum. Spray throttle body cleaner in the open ports of the IAC liberally. Reinstall.
If that doesn't solve the problem, it sounds like either the rubber bellow in the IAC is torn, or the actuator in the IAC is sticking.
Old November 9th, 2010, 12:06 PM   #7
2001 Mustang GT
Will do.
Old November 9th, 2010, 12:08 PM   #8
2001 Mustang GT
It doesn't give much warning when it stalls. Not much sputtering.
Old November 9th, 2010, 02:39 PM   #9
2001 Mustang GT
I removed it the first time when I used electrical cleaner. I removed it again and used intake cleaner this time. Idle is still high, but hasn't stalled yet....crossing fingers.
Old November 9th, 2010, 04:11 PM   #10
2001 Mustang GT
Ran diagnostics and got these codes:
P0430 - catalyst efficiency below threshold-bank 2( have no cats)
P1157 - lack of ho2s22 switches- sensor indicates lean
P0122 - throttle/pedal position sensor a circuit low input
Could it be the tps causing my problems?
Old November 9th, 2010, 05:37 PM   #11
stealth_02gt's Avatar
stealth_02gt is on a distinguished road
its possible.
Old November 9th, 2010, 08:18 PM   #12
2001 Mustang GT
Made the commute home(90 miles-all interstate), and it never stalled. My idle was very high(2000-2700) when I'd push in the clutch. Other than the idle, it ran ok and accelerated normal when I got on it. I unplugged the tps before I made my commute home and it dropped to almost normal idle after a few seconds.
Old November 10th, 2010, 09:28 AM   #13
2001 Mustang GT
Left the house this morning. Stalled a few times in the first 10-15 minutes of driving drove for an hour and half to work with no problems...Replace IAC and TPS? From the code I got yesterday about low input to the TPS, will replacing the sensor help or is this a further underlying problem?
Old November 10th, 2010, 10:10 AM   #14
Tang Stang's Avatar
It could be the TPS, or it could be the IAC. Without being there in person, that's the best diagnosis I can give you.
Old November 19th, 2010, 02:02 PM   #15
2001 Mustang GT
I have come to the conclusion that my car is possessed. It is still stalling out on me. Here are some of the instances:
Most common- Car stalls, odometer displays dashes, and fan kicks on.I cycle the ignition until the dashes go away and numbers return then the car usually starts
Car stalls, the ani theft light flashes( sometimes with check fuel cap light on). I have to cycle the ignition more than above scenario, and it starts back up.
Yesterday my fuel light was on for most of the day, but my car never stalled while it was on the 180 miles i drove it yesterday. It bucked a couple of times, but that was it.
Today i drove about 5 miles with no stalling, but about 4 miles into my trip, I could hear my fan running. It's cool( about 50) outside and I wasn't running it hard. My gauge indicated normal temp. I arrive at my destination and turn the car off. I get back in a few minutes later and when I try to start it, it just turns over and I notice the anti theft light flashing. after cycling the ignition about 15 times, the anti theft goes away, and the car starts. I drive home and notice when i come to stops the idle drops to 500 and almost dies. I get home, turn it off and smell radiator fluid. The engine is not cooking hot, but definitely above normal which the gauge indicates. Now i guess the coolant temp sending unit is bad.
I have changed my fuel filter, fuel pump, tps, cleaned my iac, and checked voltages on them as well. I'm at a loss for words. If anyone has any ideas, I would GREATLY appreciate it.
Old November 19th, 2010, 05:55 PM   #16
2001 Mustang GT
I started it up to see what it would do. I noticed a little white smoke and water coming out of the exhaust.It died a couple of times, but started right back up.
Old November 19th, 2010, 06:54 PM   #17
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
maybe you have a short to your computer causing it to go in and out at times. Have you checked the wiring?
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old November 19th, 2010, 07:47 PM   #18
1_nice_03_gt's Avatar
2003 ford mustang gt
13.9 stock
1_nice_03_gt has a spectacular aura about1_nice_03_gt has a spectacular aura about
do u have mil elimantors for ur catless xpipe? also check the maf sensor see if by any chance something flew in there n also check if its connected right in the sensor on the maf were the 6 pins are at did it to me when i forgot to plug it back in
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
Old November 19th, 2010, 09:58 PM   #19
2001 Mustang GT
I will be checking the wiring to the computer and on the maf. I am not sure if I have mil eliminators-the x-pipe was on the car when I bought it 6 years ago. The check engine light has been on since I had the car, so would that mean I probably don't have them? The car has run like a clock until recently it just decided to act up.
Old November 19th, 2010, 10:18 PM   #20
13.9 stock
most likely ou dont have it buy sum ur just hurtin the motor, but my guess would be the maf sensor did u mess with the intake system?
Threads Similar to: Stalling problem- please help
stalling problem i need help greengoblin 99-04 31 April 8th, 2009 09:42 PM
Stalling problem joecool108 2.3 Mustangs 2 November 23rd, 2008 04:55 PM
stalling problem harrylee 5.0 Mustangs 11 June 3rd, 2008 06:38 PM
'01 Stalling problem LanceD V6 Mustangs 11 March 5th, 2007 01:15 AM
Stalling Problem Mustang8719 5.0 Mustangs 12 July 27th, 2006 11:42 PM
