#21 |
2001 Mustang GT
![]() iTrader: 2 reviews
cruise at higher rpms
01 GT Vert - Triple Black - 2v 5.4 270/340 00 Lightning - Triple Black - 2v SC 5.4 400/500 Brand New Tubular UCA and LCA set for sale PM me Slightly Used 05-09 Halo Headlights for sale PM me
#22 |
Hooo Ha Ha
If your cars an auto they all do that....
mine does it..
![]() 410rwhp 520rwtq @ 12.9 psi |
#23 |
2000 Jeep Grand Cherokee
![]() ![]() iTrader: 2 reviews
Try cruising at higher rpm's. I know some cams don't like cruising at low rpm's at all and will buck pretty good until you give it some gas. My old Mustang was like that. If I was trying to cruise in 3rd at about 30 mph and low rpm it would buck like crazy. I'd either give it some gas and bump up to about 35 or go to 2nd gear and just cruise at a higher rpm.
Cammed '99 Mustang V6 -- Sold Supercharged '89 Hatch -- Sold Looking for a project Stang now... MILITARY CREW - TERMINAL LANCE - MARINE CORPS. INFANTRY www.wotmustangs.com |
#24 |
KB'd GT
A mild shuffle could be normal at those low rpms, but if its bucking where the nose of the car will rise or dip, then its probably the tune. There is a lot that you can do in the tune to make the car drive smoother, even with huge cams.
#25 |
^This. Have your tuner bump the load a little. Mine would do it in 5th gear on the highway at around 1500rpms. It's cause your foot is just lightly on the pedal and the injectors shut on and off really quickly causing a jerk. Have your tuner bump the load up a little in the tune and see if it corrects the issue.
![]() 2003 DSG Mustang GT 5spd Full Bolt On's, Suspension, Built Rear, V1 S N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60' Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60' Intercooled: 362/370 |
#26 |
2002 Mustang Gt
13.4
UPDATE: Hey everyone i took my car out of storage for the winter recently and i changed my fuel filter, cleaned my MAF, cleaned my throttle body, and cleaned the IAC. The car still bucks pretty hard at around 1400rpms. I plugged in my predator handheld and i didnt see an option for load. I noticed though he did change spark advance and fuel. Someone said to me i try changing plugs and injectors but before i do i was wondering if anyone knew how i could bump up the load a little. Thanks
2002 Mustang Gt Comp Cams XE268H, Accufab Throttle Body, Accufab Upper Plenium, Steeda UP Pullies, K&N Cold Air Intake, 4:10 Gears, HHR Drag Launch Springs, BBK O/R X Pipe to Magnaflow exhaust, Tuned By: Dyno TuneMP. ~274RWHP 296TQ~
#27 | |
Threads Similar to: Car bucks and jumps forward
| Car feels like pulling forward | sstang02 | 99-04 | 27 | October 27th, 2010 10:47 PM |
| car jumps DFW toll booth | graystang01 | The Clubhouse | 9 | June 4th, 2010 08:19 PM |
| RPM jumps? | bloodusmc | V6 Mustangs | 24 | May 23rd, 2009 12:29 PM |
| car bucks at high rpms...whats wrong????????????????????????????????????????????? ???? | random hero | 5.0 Mustangs | 7 | June 12th, 2008 05:52 PM |
| Car Bucks | shadow98gt | 96-98 | 20 | June 19th, 2007 02:57 PM |
