Car bucks and jumps forward
Old November 9th, 2010, 05:49 PM   #1
sstang02's Avatar
2002 Mustang Gt
13.4
sstang02 is on a distinguished road
Hey everyone i had a thread on here before but now i cant find it so this is an update. My car recently had cams installed and a custom tune and now from about 35-42mph with the gas be held steadily at any of those MPHs my car jumps and jerks forward it feels like its bucking forward and it shakes and i have no idea what could be wrong. The only thing that i know is wrong is that the CEL light is on and its a cam sensor. Any ideas would be appreciated. Thanks
Old November 9th, 2010, 05:54 PM   #2
Baker Jr.
bandity2k00's Avatar
Coming after build!!
bandity2k00 is a jewel in the roughbandity2k00 is a jewel in the roughbandity2k00 is a jewel in the rough
Send a message via AIM to bandity2k00
Try changing the cam position sensor
MMR-Modular Mustang Racing
Phils Machining-For your ABS Module Delete Manifold!
American Muscle-www.Americanmuscle.com
HorsePower By Hermonn-TUNER
THANKS TO ALL SPONSORS,READY FOR THIS 2012 RACING SEASON!
Old November 9th, 2010, 06:03 PM   #3
sstang02's Avatar
2002 Mustang Gt
13.4
Any idea where the location of the sensor is?
Old November 9th, 2010, 06:22 PM   #4
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
driver side of the motor under the power steering resivoir
You need to take that braket off to get to it
410rwhp 520rwtq @ 12.9 psi
Old November 10th, 2010, 12:01 AM   #5
sstang02's Avatar
2002 Mustang Gt
13.4
alright thanks guy, ill try this an update tommorow.
Old November 10th, 2010, 12:32 AM   #6
K_Boss01GT's Avatar
2012 5.0
N/A
K_Boss01GT is on a distinguished road
not trying to jack his thread but do u need to change out the sensor when you get cams done?? im about to have that happen shortly and i want to have everything done once the right way
2012 Black GT, 3.73, bassani axel backs, MGW shifter ordered!!!
MFE - If Engines can't fix it, your're f#@ked
http://www.wpclipart.com/armed_services/airplanes/airplanes_2/EC-130H_Compass_Call.jpg
Old November 10th, 2010, 12:50 AM   #7
1_nice_03_gt's Avatar
2003 ford mustang gt
13.9 stock
1_nice_03_gt has a spectacular aura about1_nice_03_gt has a spectacular aura about
see if ur maf is connected right mines wasnt n it did this lol i know im an idiot lol
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
Old November 10th, 2010, 07:20 AM   #8
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
if it just happened when you installed the cams then likely that its not back together like it came off...not likely that it would go out RIGHT after you install the cams...possible though...
and if it did it would probably be the actual cam syncro and not the sensor itself...my buddies car just did this and it would almost throw you in the windshield feeling like the engine was about to lock up lol...if its the sncro though, you usually have a very noticeable chirping sound...
cams + 150 shot
Old November 10th, 2010, 11:08 AM   #9
sstang02's Avatar
2002 Mustang Gt
13.4
How was it not connected right? because i didnt even take my MAF off i took off the whole intake from the throttle body and didnt take it apart.
Old November 10th, 2010, 11:09 AM   #10
sstang02's Avatar
2002 Mustang Gt
13.4
There is no chirping noise at all though....and mine doesnt feel like that hard of jerk, its just a pretty good shaking at those speeds and idk what it is!!!
Old November 10th, 2010, 11:09 AM   #11
sstang02's Avatar
2002 Mustang Gt
13.4
UPDATE: i changed out the cam position sensor and nothing happened still jerks and shakes around 38-40mph....ughhh.. the only good thing is that the CEL light went off
Old November 10th, 2010, 11:13 AM   #12
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
what rpms is this happening at and what cams?
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old November 10th, 2010, 11:17 AM   #13
sstang02's Avatar
2002 Mustang Gt
13.4
pretty sure around 1200-1500rpms with comp cams xe268h.....someone was telling me maybe in my tune i got done the load is adjusted wrong?
Old November 10th, 2010, 11:18 AM   #14
sstang02's Avatar
2002 Mustang Gt
13.4
ALSO if i turn off overdrive it stops but i think thats just because it eliminates 4th gear and the rpms go up so could this possibly be my 4:10s or tranny problems?
Old November 10th, 2010, 11:19 AM   #15
BakerFX4's Avatar
iTrader: 14 reviews
well, how bad does it buck and jump? thats pretty low rpms to try and cruise at with a cammed car. Mine doesnt like that low of rpms for sure!
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old November 10th, 2010, 11:20 AM   #16
sstang02's Avatar
2002 Mustang Gt
13.4
its pretty noticeable but the weird thing is that at any other speed at that rpms its doesnt do it
Old November 10th, 2010, 11:39 AM   #17
2005 Mustang GT
blally89 is on a distinguished road
honestly even with stock cams I believe you could experience some sort of bucking and jerking with the 4.10 gears at such low rpms.. I experience it somewhat when im in 1st and 2nd gear if my rpms are very low at around 1100rpms and it probably makes it even worse with the cams you have and also depending on the tune that you got with it. Why don't you try to get another tune?
Old November 10th, 2010, 12:03 PM   #18
sstang02's Avatar
2002 Mustang Gt
13.4
well i just got this tune done about a month ago and im in college so i really dont have an extra 350
Old November 10th, 2010, 12:41 PM   #19
BakerFX4's Avatar
iTrader: 14 reviews
Im thinking its the same for everyone. Mine is noticeable too but i understand that i have cams and cant drive at 1000-1400 rpms and it be too pleasant.
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old November 15th, 2010, 08:27 PM   #20
sstang02's Avatar
2002 Mustang Gt
13.4
bump...any other opinions?
Threads Similar to: Car bucks and jumps forward
Car feels like pulling forward sstang02 99-04 27 October 27th, 2010 10:47 PM
car jumps DFW toll booth graystang01 The Clubhouse 9 June 4th, 2010 08:19 PM
RPM jumps? bloodusmc V6 Mustangs 24 May 23rd, 2009 12:29 PM
car bucks at high rpms...whats wrong????????????????????????????????????????????? ???? random hero 5.0 Mustangs 7 June 12th, 2008 05:52 PM
Car Bucks shadow98gt 96-98 20 June 19th, 2007 02:57 PM
