LinkBack (3) | Thread Tools |
#1
DIY COP Tester
I apologise, as an older fellow dealing with some annoying health issues I get "snippy" at times...
Here is the post: I have been pondering ways to make a practical device for testing COPs, under actual operating conditions, for some time; and a couple weeks ago while looking at a sales flyer from an electronics supplier I have dealt with I ran across the perfect core component. I had seen this device in the past but as it is decidedly "old-hat" it had slipped my mind (gimme a break, I'm old). Here's a photo of the complete set-up, and a WMV video of it in action--I will provide details below: Click here to watch the WMV (if you can't see the sparks download and play the file, your internet connection bit-rate may be too slow to see them). The core component, with the heat sink in the center of it all, is a Velleman Electronics K2543 CDI (Capacitive Discharge Ignition) driver module that can be had as a kit from Arcade Electronics for $20.31 (currently on sale). This kit is designed to retrofit a classic Kettering (points/condensor/coil) ignition system to a CDI driver, however it can also serve here to drive a COP when a simple normally open momentary contact switch is used to simulate the distributor points. I have also used an Am-Pro T71240 adjustable spark tester that I picked up someplace several years ago for less than $10. Any similar unit would work. Shown in the photo and video is one of my five remaining good Accel COPs, none of the 3 bad ones will fire at all even though they all check out OK with a low voltage Ohmmeter. If anyone is interested I will draw up an interconnect schematic, it works quite nicely to test an individual COP, or to compare a set.
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
what? you lost me with big words
Hooo Ha Ha
Can you just pull it out and stick the spark plug in it and set it on something metal. Then just crank the car?
![]() 410rwhp 520rwtq @ 12.9 psi |
Sorry to bother you with this "overly complex" mechanism/method to gauge a COPs maximum potential output...
never mind? i was gettin into that
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences 02' GT ~ Twin Screwed 469hp/493tq |
Hooo Ha Ha
I find it interesting just a tad more complex then it needs to be though
#7 | |
I have a set of Accel COPs, of which 3 failed within 15k miles and within a period of two weeks. Of those that failed all test out OK using the typical low-voltage Ohmmeter tests (0.8 to 2.0Ω primary, 6k to 8kΩ secondary), however one will not fire at all with the DIY tester and the other two will not fire at more than a 0.1" gap with the adjustable tester. A good OEM COP will fire a 3/4" gap on the adjustable tester. This setup wrings out a COP, and can in fact burn one out in short order if you make it fire 20-30 times in rapid succession with en very wide gap. If a COP can fire a 1/2" or more gap then it is OK. if not then even though it can fire a normally gapped plug, and passes low voltage resistance tests, it is toast.
i dont find it complex at all, its rather simple when you break it down. I like this, i may make one myself.
What are you using for the power source? the way you have it set up, with the adjustable spark tester, you could probably compare the actuall strength of the spark that is put out by the coil, in theory proving and aftermarket coil to be stronger vs a stock coil and vise versa? right? EDIT: i gotta say i like this write up. not many people talk about coils, perhaps the boost-a-spark system, but thats about it
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences 02' GT ~ Twin Screwed 469hp/493tq Last edited by FoxHoss; November 9th, 2010 at 11:28 PM. |
#9 | |
The tester described test the COPs at levels that are 200% to 300% of typical duty cycles, in fact as I said before it's easy to burn one up using this tester. This is why 50+% of the COPs returned to Ford, under warranty repairs, have nothing wrong with them. There's a TSB to this effect...
#10 | |||
One caution however, as COPs never in real use fire at their "potential" (15kV to 20kV is the probable max) it is quite possible to burn out even the best COP by making it fire at it's full potential more than 5 or 6 times every 10 minutes or so. In fact I burned out one of my remaining Accel COPs doing just that with this test device.
I had a question on another forum as to the voltage being generated in the video. The breakdown voltage of air at STP is around 33kV/cm, and in the video above the gap is about 0.55", or 1.4cm.
So the voltage being demanded of the COP is 46kV or so--this was just about the maximum the Accel COP could deliver consistently.
KB'd GT
I applaud your creativity, but there is a much easier way to test a COP if you have a datalogger. Simply watch the fuel trims while you unplug one at a time. Or you could watch the missfire counters at WOT. There is one problem with your device, it should be under pressure. Its much harder for a spark to jump when there is a lot of air pressure around it. I'm not sure if this math is correct, but assuming 100% VE and 14.7 psi with 9:1 compression it would need to fire under 132 psi (at WOT). But you could "simulate" the pressure by extending the gap.
Have you had a chance to test other coils for comparison? ie, a FoMoCo coil?
Granted you don't really want to be burning them out. I agree about the spark being under pressure. The pressure adds resistance which is being delivered via the adjustable spark tester, if you could equate the distance the spark travels to a pressure equivilant value
#14 | ||
In the video the gap has been extended to 15mm. In air at STP it requires 33kV/cm to ionise the gap between pointed electrodes--so the output of the COP in the video is approximately 33kV * 1.5 = 50kV. ---------------------------------------------- Just to add some background info so we can dispense with the condescension, I hold a MME (MIT '73) and among many other assignments worked with HV ignition systems in industrial thermal deposition and heating applications for several years in the mid 70's.
#15 | |
Not doing so can damage the DUT, so just don't do that. In my posting above I added that ionisation of an air gap at STP requires approximately 33kV/cm, and that with the 15mm gap used in the filmed test this indicates an output of at least 50kV. As I had adjusted the gap to just below that at which the coil would not "fire", this is a\n acceptably close indication of the COP's maximum output. The pressure issue, as you and others have suggested, is largely irrelevant for bench testing the coils to determine their maximum potential; because as long as the test conditions are maintained the only effect would be to shift the absolute magnitude of the observed value (in this case the maximum gap across which the DUT can spark). The comparative relationships would remain effectively unaltered.
2000 Mustang GT Super'ed
Great work!
![]() Saleen Series II 377whp/390wtq, Chicane I/C, Mosaleen Pulley, Fidanza FW, Spec Stage 2, Alum Driveshaft, BBK Headers, Steeda Exhaust, TruTrac 31 Spline, 3.55s, 315s, MM FLSCs, Rear LCAs, MGW Shifter, Eibach Pro, X2 Balljoints, Cobra Brakes, SS Lines. |
#17 | |
KB'd GT
#18 | |
I only have six (still working) Accel COPS (<20k miles), and the stock COPs from my '03 GT with 80+k miles on them. Temp and humidity are easy as I do the testing in my climate controlled electronics lab (see photos below), 72°F (+/- 1.5°) 50% to 55% RH. I tested four of the Accel COPs, and four OEM units (the driver's side as they are the easiest to pull, here is what I found: ![]() If I run into other COPs I will test them (or if anyone has any they'd like to have tested--let me know). I went through two sets of Weapon X COPS in less than 5k miles in July and August. They had serious issues with long drives (50+ miles) where they would misfire badly once they got heat soaked. When attempting to start the engine after a short stop, after a run on the highway, they would not fire at all and I had to wait 15-20 minutes for them to cool. The Weapon X people were great to deal with--after the first set failed they sent me another, after that failed they provided a full refund. I have had no such problems with the stock coils. Here are a couple photos of my lab: North end: ![]() South end:
KB'd GT
Great info! Thanks for sharing. I'll keep on telling people that the stock COPs are better then most aftermarket COPs. (until you prove me wrong
Most all, maybe all, COPs that look like the OEM units are made by a company named Micro-Tech. The Ford stock COPs (I disagree with their assertion of a "high failure rate") are made by them, as are Granatelli's.
Also though I have no links to verify this, the body of the Accel COPs, other than being yellow, is identical in every way to the OEM coils--if they were not made in the same molds, then the molds were dead ringers of those used to make the OEM units. These are all made to the ordering vendor's specs of course, with regard to price point, and other factors--I am certain that if I wished to order a significant quantity I could get them in green...
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/191470-diy-cop-tester.html
| Fourtitude.com - 2.0T ignition update | This thread | Refback | December 15th, 2011 05:56 PM | |
| VWVortex.com - 2.0T ignition update | This thread | Refback | October 21st, 2011 02:36 PM | |
| VWVortex.com - 2.0T ignition update | This thread | Refback | October 21st, 2011 10:44 AM | |
Threads Similar to: DIY COP Tester
| Circuit Tester ? Test Light? | Youngin | The Clubhouse | 12 | February 5th, 2009 05:33 PM |
| DIY Set-Up??? | 87StangLX | General Tech | 5 | February 21st, 2008 06:30 PM |
| Good Cop, Bad cop | HMUSN | The Clubhouse | 4 | June 27th, 2007 01:01 PM |
