Loosing Tire Pressure
Old November 10th, 2010, 12:30 PM   #1
02GTConvert's Avatar
02GTConvert is on a distinguished road
I drive my '02 GT Convertible about once per week. I have the stock wheels and tires (Dunlop Eagle GT, i believe). Every time I pull the car out I notice the LF and LR tires have lost 10 -12 pounds of pressure. At first, it was only the LF, but I rotated it to the rear and now both tires are loosing pressure. I took it to my local shop, they submersed it and could not find a leak anywhere. Does anyone have any ideas what the problem might be? Or has anyone had this problem before?
Old November 10th, 2010, 12:48 PM   #2
2003 GT
Cowboy is on a distinguished road
You got a leak. Thats about the end of it. You proboly have a slow leak that will leak under the cars weight so removing it and subersing it wont find it. Id spray some soapy water on the edge of the wheels and tires when its on the car and look for bubbles. Find it, marke it and take it to the shop. It could be because you have a bent wheel that isnt sealing.
Old November 10th, 2010, 12:48 PM   #3
2001 Mustang GT
markj7 is on a distinguished road
Have them break the tire down and reseal it. You may be loosing air around that seal only when driving. Tires loose some pressure in cold weather but not that much.Tighten your valve stems as well. Good luck.
License and registration Please
Rides;2001 GT Performance Red , 2004 Limited Explorer,Black (off duty supervisor's ride)
Old November 10th, 2010, 12:50 PM   #4
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
I lost pressure out of my tires at about the same rate. It was a bad bead seal and the tire company just had to reseal the tires.
Old November 19th, 2010, 05:23 PM   #5
Sorry, I have been away from the Board for a little while.
Anyway, Thanks for the help! I will try the soapy water technique and try to find the leak.
Thanks Again!
Old November 19th, 2010, 05:33 PM   #6
moneygreenstang's Avatar
2001 Mustang GT
moneygreenstang will become famous soon enough
I have a bent rim on my taurus that can only be seen when the tire is off... so after a week or two you can see the tire getting low
But wherever its coming from its a leak..
01 GT Vert - Triple Black - 2v 5.4 270/340
00 Lightning - Triple Black - 2v SC 5.4 400/500
Brand New Tubular UCA and LCA set for sale PM me
Slightly Used 05-09 Halo Headlights for sale PM me
Old November 19th, 2010, 05:37 PM   #7
rotten's Avatar
SA XD40
rotten is on a distinguished road
valve stems ? I've had 2 good bad on mine .
09 crf450x super motard.
06 f250 powerstroke
04 cbr1000rr
03 rsx-s
Old November 19th, 2010, 05:38 PM   #8
rotten's Avatar
SA XD40
I bent the front rim on my rr when i wrecked an it went end over end a few times , but it still holds air and balances just fine .
06 f250 powerstroke
04 cbr1000rr
03 rsx-s
Old November 19th, 2010, 08:11 PM   #9
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
You pretty much have to over inflate a tire to find a small leak. Sometimes all you see is a bubble form on the surface of the tire instead of the steady stream of bubble most people look for. There are only four things it can be: small hole, valve stem, bead, or a small crack in the wheel. It is most likely one of the first three. Unless you have a lot of nails laying around, since it is more than one wheel I suspect the bead. If nothing else have them break it down, reseat it and put a new valve stem in it.
Edit: I've seen tires that have a big nail completely through them not leak very much because the nail seals the hole. I'm assuming you did a complete visual inspection including the sidewalls.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old November 19th, 2010, 09:02 PM   #10
2001 Mustang GT
you got real lucky you'er still okay and the tire sand wheels are great, my taurus rim on the other hand didn't come out so good
Old November 19th, 2010, 09:53 PM   #11
WonfastGT's Avatar
2000 GT
WonfastGT is on a distinguished road
Send a message via AIM to WonfastGT
^^^ what they said
Old November 19th, 2010, 10:08 PM   #12
chiefsmustang20's Avatar
'02 VERT
13.08@106.11
chiefsmustang20 will become famous soon enough
+1 try the valve stem 1st pour some soapy water on it
CMS STAGE II
FRPP 4.10s
LTS, O/R H, FLOWMASTER WELD ONS
EDELBROCK INTAKE
MHS 6061 ELBOW
NX PLATE 100 SHOT
SCT X3
TUNED BY JOE MANSFIELD AT ABOVE AND BEYOND PERFORMANCE
Threads Similar to: Loosing Tire Pressure
Tire Pressure? DarkCandy08GT 2005 - 2010 5 April 9th, 2009 04:42 PM
NEED HELP!!! Tire Tire Pressure Sensor Fault!! On Mr.Stang08 2005 - 2010 7 March 7th, 2009 12:14 PM
Tire pressure? DickH 99-04 2 July 4th, 2008 08:54 AM
Tire Pressure? Timm10221 5.0 Mustangs 7 June 6th, 2008 09:02 AM
Tire pressure 2000Mustang Drag 10 March 25th, 2007 07:15 AM
