Antifreeze smell and smoke through vent
My 2000 mustang gt busted a housing to the hose coming out of the back of the manifold and into my firewall. Its the housing right behind the throttle body. I tried plenty of times to put it back on with a clamp but there wasnt enough pipe to catch. So i just ended up putting jb weld on it then a clamp. The antifreeze I lost i just filled it up with water instead of coolant. But since then I have antifreeze smell in my car. At first i thought it was just a smell from the antifreeze that sprayed on my motor burning up from the heat of the engine. Then yesterday when I was driving the smell became more obvious and smoke came through my vents for a couple of minutes then it stopped after I pulled over and hasnt happened again. However it still smells like antifreeze. Any ideas what it might be and what I should do?
2002 Mustagg GT
1/4 - We'll see soon
Replace it correctly
" Drive Fast - Take Risks " LawlessRebel ![]() SOLD - My 02 Supercharged. Got a 95 5.0 for a few weeks till I sell or trade it!
the only way to replace it is to buy a whole new manifold...... or else I would
All Homo All The Time
2003 Mustang GT
Whatever you run plus 5 seconds
You could try replaceing the heater core but if it was busted you would have coolent in you passanger side floor board.
BLACK STANG CREW MEMBER #30
any other ideas what it might be or what I can do?
bump
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
a manifold is cheap and easy to replace, you can pick up a used one on a site for about a hundred dollars or a new one for 180. a heater core is not that hard of a job to do and it cost 40 bucks.
i also have a 2000 mustang and mine blew last month, i replaced the whole manifold, u can buy a new one off of amazon for $165, and everything is fine now. Make sure u get one with the aluminum crossover!
#9 | |
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
what are you nuts? you have to take EVERYTHING out of the car to change a heatercore. Dashboard, center console, seats, steering wheel, steering column. its a pain in THE ASS.
2000 Mustang GT Built 4V Motor with Sullivan Single Plane Intake Custom 66MM BB TT kit Borla XR-1 Dumped before rear Moser built 9" Rear 35 spline WaveTrac Diff with 3.75s 35 spline Moser axles 14PT roll cage and minitubbed
2003 mustang v6 ;)
slow
you talk to me like i have not done this before, sure its time consuming but i did it with out even having to pull my ac system.
no, im talking to you like your giving misleading information to people. Clearly from your pictures its certainly obvious that its more than "not that hard" Ive pulled 7 of these out before and it takes a LONG time.
na, dash out in an hour tops, 45 min with a beer break to swap the heater core and an hour to put the dash back in
Threads Similar to: Antifreeze smell and smoke through vent
| antifreeze? | wannabeimportkiller | 96-98 | 19 | May 14th, 2010 04:09 PM |
| I smell exhaust when I put my a/c, vent, or heat on... | 00mustangv6 | V6 Mustangs | 8 | October 30th, 2009 04:46 PM |
| Faint smoke and bad smell....help | blakehunter316 | 5.0 Mustangs | 17 | March 9th, 2009 03:06 AM |
| I smell smoke | McMillin | 2005 - 2010 | 4 | January 28th, 2008 12:53 PM |
| smell of antifreeze | tkwhitestang | 94-95 | 9 | January 3rd, 2008 12:52 PM |
