Functional Hood Scoop Debate
Old November 11th, 2010, 10:45 AM   #1
IrishGT's Avatar
2003 Mustang GT
13.5
IrishGT is on a distinguished road
OK so i have this.. Predicament
last night my room mate and i got in a long debate over weather a hood scoop with a hole in the hood at the back of the scoop would be more likely to lift off than if you simply left the scoop on with no hole in the hood... (the scoop has no grill)
on one side of the argument (my roommates side) if i leave the hood sealed there will be a small amount of air pressure built up but after that all of the air movement at say 80mph around it will have enough pressure to keep the hood on... he thinks that if i were to cut a hole in the hood at the back of the scoop there would be enough air movement under the scoop to try and lift it off even further...
i disagree, i think that by cutting the hole in the hood it'll equalize the pressure on top and bottom of the scoop and i'm trouble free!
now, i bought the car with the hood scoop detached. its missing the facory scoop grill and there is nowhere online to buy a new on without getting a whole new scoop. it was my bright idea to just glue the scoop back on thinking i could just get the grill on ebay. all of the 6 studs had been ripped of so i used amazing goop to put it back on its a silicone type of super glue. i scored/sanded both the surfaces of the scoop and the hood before gluing for better adhesion. that being said the scoop is not as strong so it would be with the 6 factory bolts holding it onto the hood, But the glue worked incredibly well.
i've been lucky enough to only do city driving to where theres not much pull on the scoop but i have to make a trip friday night and hit the highway so i need to make a decision by then! or i can just let the highway decide if i keep my scoop hahah
Please give any input or suggestions you have if youve made your scoop funcional how well does it perform? i need to figure somethin out help me please!!
03 GT
Mods: bbk cai, bbk 75mm tbs, steeda underdrive, custom x-pipe, flowmaster super44's, 3.73s, Eibach lowering, steeda tri-ax, Centerforce Dual Friction Clutch.
Pony's sittin on 17" chome cobra FR500's 10.5 backs 9 fronts (she HOOKS)
Old November 11th, 2010, 10:56 AM   #2
1999cobra92's Avatar
1999 mustang cobra
1999cobra92 will become famous soon enough
Honestly I don't think it would make a difference but it's up to you if you want to make a whole in your hood.
Black and White Crew
Crew Member # 5
Check garage for mods and pics
if you Los Angeles and want to ride send me a text (323) 270-6827
0% Wheel hop, 0% broken parts, 100% wheel spin
Old November 11th, 2010, 11:02 AM   #3
want2bescrewedGT's Avatar
2001 Mustang GT
want2bescrewedGT is on a distinguished road
I highly doubt your hood would tear off going highway speeds with or without a hole. Those scoops create lift even with the cover on your can see it moving at decent speeds. Also the fake grille is set back an inch or so so there is always some drag there.
Old November 11th, 2010, 11:43 AM   #4
LAWNDART02's Avatar
02 GT
LAWNDART02 is on a distinguished road
Sounds like the recipie for making a lot of wind noise (cutting hole)
02 2v 5sp-
9lb KB 2.1L I/C, 90MAF, 75mmStack TB, FLSFC's, Magnaflow C/B, NT555R's, MGW shift, Black Sabbath
Old November 11th, 2010, 11:48 AM   #5
cedsks's Avatar
cedsks will become famous soon enoughcedsks will become famous soon enough
if you watch the testing videos in the air tunnel, the air just flows right over it until it gets well past 100 mph, thats why the ram air effect on cars like
WS6 only starts around 100, I know the mustang wind tunnel video is on utube somewhere, I have watched it before....
2004 2v GT--3.90's, t3650, H&R SS, 78mm TB, K&N CAI, steeda bump stop kit, HP Blues shocks and struts, soon to have a rear seat delete, light weight driveshaft.
Old November 11th, 2010, 11:58 AM   #6
IrishGT's Avatar
2003 Mustang GT
13.5
good idea ced I'll look into that. And I'm talkin abouth the scoop tearing off not the hood...
03 GT
Old November 11th, 2010, 12:42 PM   #7
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
cutting a hole will reduce the force wanting to tear the scoop off and won't be any noiser. Mine is rock steady at all speeds.
The only draw back to cutting hole is water intrusion and the water seems to find it's way to the spark plug wells causing a missfire.If by some chance i have to drive my car in rain I just tape up the hole
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old November 11th, 2010, 12:50 PM   #8
BaznastyDave's Avatar
2004 Mustang
BaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to all
Making hood scoop functional?
functional scoop and grill delete
305/333 WHP/WTQ with CMS Stage II cams
440/552 WHP/WTQ on Spray
7.86 @ 89.1mph, 1.61 60 foot N/A
7.20 @ 98.8MPH 1.55 60 foot on spray
Stock Longblock with Cams
Old November 11th, 2010, 12:56 PM   #9
97 cobra/94 integra
Kimo will become famous soon enough
Im not sure about lift, but i know on my hood the vents are on the back of the scoop. and this made a WORLD of difference in cooling the car! the air flows through the bumper/radiatior and right out of the back of the hood-
The Integra V8 build on Facebook!!
V8 Integra- Mus-tegra | Facebook
Old November 11th, 2010, 02:58 PM   #10
Ryguy33's Avatar
2002 Mustang Gt
3 seconds......flat
Ryguy33 will become famous soon enough
Send a message via AIM to Ryguy33
just be carefull when you do it. i cut out the holes in my black honeycomb grill and didnt cut out a hole in the hood and it flew off at about 80
Mods = stuff to make me take corner faster
Old November 11th, 2010, 03:02 PM   #11
I'm going On A Manhunt!
kyle2002stang!'s Avatar
2002 true blue GT
speed of time @ 88mph
kyle2002stang! is a jewel in the roughkyle2002stang! is a jewel in the roughkyle2002stang! is a jewel in the roughkyle2002stang! is a jewel in the rough
i heard that the only time water would get in is when your washing the car. F8L has a functional scoop i believe, maybe hell chime in here
mac lt's, mac O/R H pipe, spintech super prostreets, JLT RAI, 14"antenna, mach 1 chin spoiler, two 12" kickers.
Old November 11th, 2010, 03:09 PM   #12
IrishGT's Avatar
2003 Mustang GT
13.5
yea i've seen the way he did his scoop with that bar on there anyone know what he did or used to make that support?
03 GT
Old November 11th, 2010, 03:16 PM   #13
Thunderscrash's Avatar
2000 GT
N/A
Thunderscrash is on a distinguished road
Theres a guy selling that grill piece in jersey on craigslist for 10 bucks if you want to go that route. I'm sure you could work something out with him for shipping.
Heres the link
1999 2004 mustang parts
Old November 11th, 2010, 03:43 PM   #14
2001 mustang gt
kevin01gt is on a distinguished road
Bro! That is a sick ass vid as well as your car
Old November 11th, 2010, 03:46 PM   #15
IrishGT's Avatar
2003 Mustang GT
13.5
that looks like the grill for the v6 insert.. Are you sure it's the scoop grill?
03 GT
Old November 11th, 2010, 04:07 PM   #16
2001 mustang gt
Ya thats gotta be for the v6
Old November 11th, 2010, 04:21 PM   #17
2000 GT
N/A
Yea sorry I think your right. I didnt think about it. My Gt has that hood.
Old November 11th, 2010, 05:33 PM   #18
IrishGT's Avatar
2003 Mustang GT
13.5
I'm new to forums how would I go about messaging f8l about how he did his support on the scoop?
03 GT
Old November 11th, 2010, 05:40 PM   #19
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
Im not sure if this was said but you drill it out and leave 1.3 of the hood part. Cut the top 2/3s ..
If you get that at all
It will not fly off if it is screwed on.. Also I believe F8L has a bar in the middle of the scoop as a support
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old November 11th, 2010, 05:43 PM   #20
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Even if you cut a hole in the hood and air is flowing through it, what function is that providing? You're not pushing fresh air anywhere useful. If anything, you could be screwing up the airflow dynamics that help pull air through your radiator and cause your engine temps to increase. You'd be better off figuring out a way to let air escape out the back of the hood then trying to cram air in from the top.
O o
/¯/______________________
\_\
Threads Similar to: Functional Hood Scoop Debate
How to convert Normal Hood Scoop to Functional Hood Scoop Nameless 2005 - 2010 20 June 8th, 2011 12:36 PM
Functional Hood Scoop fastopaquezebra 2005 - 2010 18 January 20th, 2009 07:25 AM
Functional GT hood scoop SilverFreakGT 99-04 40 November 18th, 2008 10:19 PM
Functional Hood scoop... puppynut5 Classic Mustangs 5 August 12th, 2008 04:52 PM
Functional Hood Scoop? sgtadam Visual 7 September 30th, 2007 07:42 PM
