what are the max R.P.M.s for a stock 4.6 liter
Old November 12th, 2010, 12:15 AM   #1
2000 gt
Everett will become famous soon enoughEverett will become famous soon enough
k so i tried the search and it came up empty so i ask you knowledgeable people.I have slightly better than stock 2000 gt and am getting a tuner and i want to know how high i can turn up the rev limiter and not blow it up.Or has ford got it pretty much perfect.Thank you.
Black and White Crew
Crew Member # 3
centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie
Old November 12th, 2010, 12:20 AM   #2
00mustang00's Avatar
2011 Caddy cts, 09 Jag XJ
00mustang00 has a spectacular aura about00mustang00 has a spectacular aura about
fords got it pretty much on the ball. your still n/a so most of your power will drop past 5500 rpm's anyways.
2000 GT- Gone but not forgotten
Old November 12th, 2010, 12:20 AM   #3
maxgst's Avatar
maxgst has a spectacular aura aboutmaxgst has a spectacular aura aboutmaxgst has a spectacular aura about
well the max HP is at 5250 rpms so thats where I would shift...
.............................2000 GT Vert.............................
How To Cut/Remove springs
Old November 12th, 2010, 12:27 AM   #4
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
im not sure anyone knows that answer for sure, you should pull your limiter off and stomp on it till it makes a funny noise, then back off a bit. im jk! stock parts and valve train can handle about 6500 rpm's safely. now whether or not you make power thats a diff story
Old November 12th, 2010, 12:28 AM   #5
Sheep
OutKast09's Avatar
13.324 @ 103.80
OutKast09 is on a distinguished road
iTrader: 7 reviews
Send a message via AIM to OutKast09 Send a message via MSN to OutKast09 Send a message via Yahoo to OutKast09
you can take it up to 6000 rpms.
Mineral Gray Club Member #9
Old November 12th, 2010, 12:36 AM   #6
2000 gt
k thanks guys.I am glad this forum is here.I woulda turned er up 500 rpm and spun something.Thanks guys
Crew Member # 3
Old November 12th, 2010, 12:39 AM   #7
stal94gt's Avatar
2003 mustang v6 ;)
slow
like i said you can turn 6500 rpm's but you dont make much power up there.
Old November 12th, 2010, 01:23 AM   #8
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
You can go higher but if it makes a noise that sounds like a tick or a knock afterward.
Please do not make a thread.
410rwhp 520rwtq @ 12.9 psi
Old November 12th, 2010, 01:45 AM   #9
stal94gt's Avatar
2003 mustang v6 ;)
slow
i pulled my stock motor 6500 rpm's all day with a blower and it took it fine. dont confuse the fact that my motor blew on me because of rpm's. it blew bc i swaped my pulley from a 3.6 to a 3.125 with out a tune. sure it sounds dumb but i had finished my new motor and i was not about to pull a perfectly good motor out of my car.
Old November 12th, 2010, 01:48 AM   #10
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
iTrader: 10 reviews
Think of it this way though.
When i blew mine at 6300
When she went...she went hard
12psi non-ic @ 142mph on a npi 4.6.... poor little sucker had it coming
Threads Similar to: what are the max R.P.M.s for a stock 4.6 liter
Max power through a stock GT box Lazyracer 2005 - 2010 13 November 12th, 2010 09:46 AM
Max Hp for stock 1987 5.0 block Bettsie 5.0 Mustangs 3 October 28th, 2010 09:42 PM
Max H.P for a stock 2V engine? Josh2J 99-04 40 July 14th, 2010 11:09 AM
max hp for stock pi mustang pistons? white03mach1 4V / SVT 3 January 29th, 2010 03:34 AM
Max PSI On Stock Motor? Haggis13 General Tech 13 September 30th, 2006 09:05 AM
