noisy belt tensioner
hey guys, pretty sure my belt tensioner is going out so i guess time to replace it.
i know its only like 40 bucks and got a pretty decent knowledge of how to replace it but for some peace of mind does anyone got a write up?, pics?, or a quick text walk through? i would really appreciate it thanks guys |
remove belt, from tensioner, let it hang, undo the bolt, pull off tensioner, put new tensioner on, tighten bolt down put belt back on, drink a beer and bask in the glory of your work
the tensioner has an alignment tab so it puts it where it needs to be.
sounds easy enough, so just loosen tensioner, remove mounting bolts, remove tensioner, install new one?
how many bolts holds that sucker on? |
ONE! It's easy.
#5 | |
![]() iTrader: 1 reviews
Just don/t incredible Hulk it like I did. I was careless and tired, not thinking, I way over-tightened the new tensioner and the bolt snapped half way hanging out of the engine block. Doug (86er) and Tony (AZSonicSnake) came to my pitiful rescue. We live and we learn, adn in my case, I learned that using a torque wrench is always key.
2002 Mustang GT 4.6L
You can do this in the autozone/whatever parking lot. Only need a socket set and driver.
Slip off belt remove the "one bolt" reverse order done.
![]() Steeda UDP, K&N CAI, FlowMasters 40’s, Polly Mounts, Aluminum D/S, Chrome Moly Flywheel, Centerforce DF, MM (quad, cable, adj.), Lakewood LCA’s, MM FLSFC’s, Predator canned 93 tune. |
Threads Similar to: noisy belt tensioner
| Belt tensioner | bandity2k00 | 99-04 | 8 | June 30th, 2010 06:35 AM |
| belt tensioner | JLC_04GT | 99-04 | 16 | June 29th, 2010 03:15 PM |
| belt tensioner | Ryguy33 | 99-04 | 3 | November 24th, 2009 09:01 PM |
| Belt tensioner? | militant54 | 96-98 | 3 | October 8th, 2007 12:16 PM |
| Belt tensioner | troy1000rr | General Tech | 2 | March 17th, 2007 02:17 AM |
