Test fuction on trip reset- make sticky if answered
I found out that there is a whole lot of info available if you
1) Car off, push and hold down trip reset button 2) Start car with button held down until test / gage reads 3) With car running, repeat hitting trip reset button There is about 20-30 different readings that will appear. I can figure out about 6 or so of these readings. Any ford Mechanic or anyone who can tell us what all of these mean should receive some serious reps and be made a sticky. I looked on Alldata and none of this is listed. I have a feeling that this is a wealth of knowledge to be found on our cars.
2004 2v GT--3.90's, t3650, H&R SS, 78mm TB, K&N CAI, steeda bump stop kit, HP Blues shocks and struts, soon to have a rear seat delete, light weight driveshaft. |
12.73@111.36
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. Last edited by Eagle2000GT; November 14th, 2010 at 09:43 PM. |
Supersized Salami Swallower
00 GT
14.043@99.03
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
fancy
this is well know..
![]() 99 Mustang GT V8 5 Speed. Too many mods to list.. |
Yeah alot of people have seen it. Its not really all that useful IMO
12.73@111.36
I would say that most of the time for the average driver it wouldn't be useful. But the previous owner of my car put on a reverse glow overlay on the instrument cluster. He also put the speedometer needle on in the wrong place. The digital speedometer was very helpful in troubleshooting and fixing the problem. Just in case you didn't know, zero on the speedometer isn't zero. It's seven miles per hour. In order to put the needle back on in the correct place the rear tires have to be turning.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
1999 Mustang GT
I too found this VERY handy for the same reason as the above poster. I was able to determine that when the Previous Owner of my car put the junky looking white face gauges in, he didn't center the needles properly either. Using the digital speedometer, and the digital tach, I was also able to determine I am running 3.43:1 rear gears, instead of the more common 3.55 or 3.73 gears.
2003 ford mustang gt
13.9 stock
3.43 gears?
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
As a fairly new mustang owner I did not know this. I just ran thru the diagnostics on my car and it popped up dtc 5284 which is a bad oil pressure sending unit. How reliable is this? My gauge appears to be normal when driving and such.
1999 Mustang GT
2001 Gt
It is probably correct. The oil pressure gauge in out car is a dummy gauge from what I hear and either reads normal or 0 if it has under 7psi. My car runs at 15psi when it's warm and at idle
Threads Similar to: Test fuction on trip reset- make sticky if answered
| How much difference does a cutout make on turbo car answered... | WhiteMamba | 5.0 Mustangs | 20 | October 26th, 2010 09:23 PM |
| How to get out of a speeding ticket, insider info, maybe make sticky!!! | cedsks | The Clubhouse | 24 | September 14th, 2010 05:11 PM |
| Tire Size Recommendations *Help make this a sticky!* | mrsinister2424 | 99-04 | 8 | May 8th, 2009 01:05 PM |
| could you make the trip to mars? | streetracer | The Clubhouse | 7 | June 2nd, 2008 01:18 PM |
| would someone write this up and make it a damn sticky?! | obdnanr | V6 Mustangs | 6 | May 26th, 2008 01:32 AM |
