8.8 Rear Axle
I'm putting in a 8.8 rear axle(yes i have a V6...no one really answered on how to rebuild it) but im going ot rebuild it while its out and put 4.10's in it. I was wondering what all is involved in rebuilding the axle??
does anyone know of a good website that shows you how to rebuild it and what to replace and what to do??
If you aren't first.....your last!
i would recommend taking it to a shop for the gear install, which will be most of the rebuild unless you wanna rebuild the carrier too.
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports. |
you going with stock axles? if so why not just put gears in your 7.7 and call it a day
i'm going to grab an 8.8 from a wrecked gt and try and rebuild the whole thing. I'm going ot have a professional install gears tho. what else is there to rebuild?
Proud American
Axles and bearings and to rebuild the T-loc!
so in order to rebuild it you pretty much jsut have to replace some bearings??? i think i'll leave the T-lok alone because my teachers dnt know what all this stuff is. haha...
Proud American
naw the t-loc is not hard! YOu just take off one of the spring thingys and then take out the spider gears and then replace the clutch disks! Its not to hard! To rebuild it you should do some upgraded axles and t-loc and new bearings and seals!
#8 | |
dude why you are in there why not put in a set of 31 spline axles and t lok out of a cobra?
ooh...a cobra..idk if i can find a used rear axle from a 99-04 cobra tho! What do you mean upgraded axles...whats the difference between a cobra axle and a gt axle?
yes but over time im planning on dropping a 4.2 into it. therefore i dont think the 7.5 will hold up. and i need something to do for this project for school. i
Proud American
Okay so the 99-04 cobra rear ends are IRS so that will not work!! But Upgraded axles and t-loc is more splines! The more the splines the more power it can handle! Personally unless that 4.2 has forced induction I dont think the 7.5 will have a problem, because the 4.2 is still a 6er correct?
um...i dont think the 4.2 is a 6er....im either thinking bout putting a 4.2 or 4.6. wait...the 4.2 is what the GTs have in them isn't it!? anyways i just need a project to do and i wnated to do it over my car. where do i get the upgraded axle and tloc?
my bad i meant a 4.6. sorry i was talking bout stroking the 3.8 earlier...my bad i meant putting a 4.6 in it
Proud American
Okay! here are some axle kits, but I am sure you could find better that took maybe 20 seconds to find!http://www.50resto.com/products.aspx...ory=MREARAXL16
And when you go with different spline axles stock are 28 you have to get a T-Loc that has the same spline as the new axles! If you have anymore questions just ask!
damn they want 500 dollars for the one i need!!! wow im pry goin to have to give out 200 for the axle at a salvage yrd..then another 500! plus my 4.10 gear install(which i have a manual). i figured if i want to change the gears again i always can...but i dont want to soo yeah.that will be 300...thers 1 grand! shit!
Proud American
I bet you might beable to do it cheaper! And anyways, if you are only going to have maybe 300-350 rwhp with out sometype of forced induction so the stock 28s will be fine for that! Let me know how much HP you plan on and how you will get it and then we can tell you what will be a better option!
um...i thought bout a 4.6 TT set up. that is in the wayyy future. or i might just leave it at 4.6 because this is going to be a daily driver and i plan on finding a wrecked cobra and fixing it up(im giong into autobody in the next few years)
Proud American
Yeah I think that staying with the 28 spline will be fine if you dont run any FI or high shot of nitrous!
Threads Similar to: 8.8 Rear Axle
| rear axle? wtf? | blakeasaurusrex | 96-98 | 6 | October 11th, 2007 01:10 PM |
| Rear axle | 00SlvrStang | 99-04 | 30 | September 7th, 2007 07:44 AM |
| Rear axle help | VIXEN_GT | 99-04 | 2 | July 27th, 2007 07:40 PM |
| Help With Rear Axle... | perfectspace1 | V6 Mustangs | 14 | February 11th, 2007 11:17 PM |
| Rear Rotors and Rear Axle | rondaw3g0410 | 99-04 | 1 | September 6th, 2006 10:00 PM |
