#21 |
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
it means you have to take your heads off and put them in. sorry no other way to do it
#22 |
wtf that's some bullshit man... why the hell don't they just include that shit with the heads god damn man
![]() 2004 GT Boosted by Vortech |
#23 |
read the comments about this product. Sounds like your experience...
Patriot Performance 4.6L/5.4L SOHC 2V Stage II Cylinder Heads (01-04 GT) at AmericanMuscle.com - Free Shipping! |
#24 |
2003 mustang v6 ;)
slow
#25 |
no I am missing plugs man I'ma have to call mmr and ask if they put the bottom plugs in man that's some bullshit I can understand if it's some fucking plugs you can reach outside the car but some shit you have to take the fucking heads off to fix that's fucked up man
#26 |
how the hell you put a head on the wrong side anyway? the exhaust and manifold wouldn't go on right
#27 |
i'd be happy its such a simple fix. You could have a lot worse problems..
#28 |
2003 mustang v6 ;)
slow
the heads are not driver/passenger specific thats why you may have messed them up.
#29 |
taking off the heads is a simple fix? Geez they should at least mention they don't include the oil plugs
#30 |
well I hope I did, taking off the cover and swapping the plugs would be a relief compared to taking off the heads
#31 |
2003 mustang v6 ;)
slow
you would still have to pull the heads cause the 2 plugs on the bottom of the head
#32 |
i thought you meant that maybe i put the heads on opposite so the plugs were just in the wrong holes? if that was true then the bottom ones would be in? i dunno why else you would mention that i maybe put them in wrong lol
#33 |
2003 Mustang GT
Damn sorry man, and I think thats an understatement saying its an easy fix. Fuck that who wants to deal with that bs after rebuilding the motor? Sorry man, but atleast you now know what it is. Thanks to the beastly MM crew.
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
#34 |
2003 mustang v6 ;)
slow
if you accidently put the wrong head on the wrong side you will have to take them off and flip them. there are 2 plugs per head, 1 under the head, 1 on what is supposed to be the back of the head. if you put them on the wrong sides that means you have plugs under your chain guides, and the plugs on the bottom of the heads are in the wrong spot which means your pluging a whole where oil is supposed to pass threw and letting oil out of a spot where oil is not. reguardless you have to take off your heads to make sure everything is wright. sure it sux putting the extra time to fix it but not doing it means you cant drive
#35 | |
#36 |
naw I'm positive I put the heads on right well, I examined the old heads and put them on exactly the way they were, examined them before i put them on just wasn't looking for the plugs... man that totally sucks
#37 |
2003 mustang v6 ;)
slow
there is no right or left head. ford does this and so does chevy, its so they only have to make 1 cast of the head. you may have put them on with out seeing that they did not install new plugs. or you may have put them on backwards. regaurdless the heads have to come off if this is your problem. hell you could have them on 100% right and messed up putting on the valve covers
#38 |
Bottom line is thats where your problem is so you need to tear into and hunt for mischief
Threads Similar to: massive oil leak after rebuild
| oil leak... | XXGREGXX | V6 Mustangs | 8 | September 5th, 2010 01:34 PM |
| Urgent Help Needed Massive Gas Leak!!!!! | Mr.Stang08 | 2005 - 2010 | 9 | May 1st, 2009 12:00 AM |
| oil leak under Oil filter | Genevieve! | 99-04 | 9 | February 19th, 2008 08:30 PM |
| Oil leak? | whtpny | 99-04 | 0 | November 16th, 2007 12:55 AM |
| 98 GT oil leak from the oil filter adapter??? | Nissanguy8 | 96-98 | 8 | February 9th, 2007 01:08 AM |
