massive oil leak after rebuild
Old November 17th, 2010, 07:44 PM   #1
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
so I rebuilt my whole engine and got it all back together my first time ever rebuilding an engine and there's a massive oil leak when I first turned it over, all my oil went all over the garage floor, is it possible it's a head gasket leak? I torqued them down to specs for the ARP bolts man this shit is so depressing... any clues would be appreciated
2004 GT Boosted by Vortech
Old November 17th, 2010, 07:48 PM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
did you put your heads on the right side? you have oil plugs on the back which block the ports the chain guides go to. also did you remember the rear main seal? a leak that bad would would be forgetting something big.
Old November 17th, 2010, 07:49 PM   #3
stal94gt's Avatar
2003 mustang v6 ;)
slow
i would crawl under there and see where the oil is pouring out of
Old November 17th, 2010, 07:51 PM   #4
stal94gt's Avatar
2003 mustang v6 ;)
slow
it could be something simple as forgetting to put a oil filter on
Old November 17th, 2010, 07:56 PM   #5
maxgst's Avatar
maxgst has a spectacular aura aboutmaxgst has a spectacular aura aboutmaxgst has a spectacular aura about
yeah, try to look and see where its coming from, should be pretty obvious...
.............................2000 GT Vert.............................
How To Cut/Remove springs
Old November 17th, 2010, 08:13 PM   #6
fmxona500's Avatar
1996 Mustang
I take myself way too seriously.
fmxona500 will become famous soon enough
HA!
Old November 17th, 2010, 08:29 PM   #7
turbosilverstang206's Avatar
2000 mustang GT
turbosilverstang206 is on a distinguished road
valve cover gasket could have gotten pinched in the back its happend to me
1000hp 2v?
Old November 17th, 2010, 10:03 PM   #8
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
WhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really nice
Send a message via AIM to WhiteVenom
Did you put new heads on? Ive seen people forget to put the oil galley plugs in. Ive seen people forget to take them out of there old heads or whatever etc.
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old November 17th, 2010, 10:08 PM   #9
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
Oil galley plugs
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old November 17th, 2010, 10:17 PM   #10
Garhfer's Avatar
Yeah I got new heads but I think they were all plugged up? they looked the same as the old heads where are the exact locations of the oil valley plugs? just on the back of the heads? I think it might be the back driver's side valve cover gasket but would it leak that much from a valve cover gasket? it only leaks under pressure, and it was only like 30 seconds or so... I was thinking about putting in more oil and seeing where it comes from this time because oil is splattered everywhere!
Old November 17th, 2010, 10:21 PM   #11
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
If you bought new patriot heads etc they dont come the LIFTERS, ROCKER ARMS, and OIL GALLEY PLUGS. apparently when they say fully assembled, all components of the valvetrain aren't included..
your cams wont get oil when those are not pluged i believe and yes not plugging the holes will result in massive oil leaks.
thats a 4.6 i know but it might be from a crown vic.
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old November 17th, 2010, 10:22 PM   #12
UnixHH's Avatar
2003 Saleen S281
UnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of light
Send a message via Yahoo to UnixHH
+111 that will cause it to literally pour oil out the back of the valve cover.
480RWHP 450RWTQ 15psi @ 15* on 91 octane
Old November 17th, 2010, 10:23 PM   #13
stal94gt's Avatar
2003 mustang v6 ;)
slow
this plug
and this plug
Old November 17th, 2010, 10:26 PM   #14
Garhfer's Avatar
they're outside the heads? because in that picture it looks like they were inside the valve covers? I got MMR stage 2 heads if you know anything about those lol
Old November 17th, 2010, 10:27 PM   #15
Garhfer's Avatar
this plug
and this plug
Ah that's a lot clearer lemme go look
Old November 17th, 2010, 10:27 PM   #16
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
yeah but im pretty sure this would be completely obvious and he wouldnt be asking..
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old November 17th, 2010, 10:28 PM   #17
UnixHH's Avatar
2003 Saleen S281
the only "aftermarket" head in design is the trick flow head. all other company's rework factory pieces. sooo if its not a trick flow head they are all the same (2v heads that is...)
Old November 17th, 2010, 10:29 PM   #18
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
If you didnt take them out of your old heads or bought new ones they more than likely they are not pluged.
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old November 17th, 2010, 10:31 PM   #19
stal94gt's Avatar
2003 mustang v6 ;)
slow
the one is under the head. i have mmr heads but they ported/repaired my oem heads so i got mine with the plugs in it.
Old November 17th, 2010, 10:44 PM   #20
Garhfer's Avatar
hmm, well the driver's side one looks like it's not plugged outside the head, the passenger side one is underneath the head?? geez what will happen if I don't put that one in if it doesn't have it?
Threads Similar to: massive oil leak after rebuild
oil leak... XXGREGXX V6 Mustangs 8 September 5th, 2010 01:34 PM
Urgent Help Needed Massive Gas Leak!!!!! Mr.Stang08 2005 - 2010 9 May 1st, 2009 12:00 AM
oil leak under Oil filter Genevieve! 99-04 9 February 19th, 2008 08:30 PM
Oil leak? whtpny 99-04 0 November 16th, 2007 12:55 AM
98 GT oil leak from the oil filter adapter??? Nissanguy8 96-98 8 February 9th, 2007 01:08 AM
