It's Seized motor week!!!!!!!!!!!!!!!WOOT!!!!
well was on I-4 doing about 80 when i felt motor vibration, exited shortly after watching my gauges and listening carefully to weird engine noises, then i notice my oil pressure drop suddenly with more motor shake, i push the clutch down and sway to the right to pull over quick as possible but before i make it the car stalls and turns off, try to start and the starter clicks with little oil pressure(note not none but very low).. as i wait for the tow truck i pull out TWO spark plugs and with a half inch ratchet (only tools int he truck) i try to turn the motor wouldn't budge. never really tried again but i was thinking maybe i needed more leverage since i didnt have a breaker bar and/or all the spark plugs out started looking for a 5.4. Is there a possibility it could be something else? sucks right now cause i cant find any 4.6 motors[complete] in the central Florida area.
88 LX automatic-non stroked 302 with iron heads 01 GT manual-h-pipe bullets dumped-125shot 97 GT automatic-SOLD |
2001 Mustang GT
![]() iTrader: 2 reviews
dont know anything about siezed motors and what to do buy I do know about 5.4 swaps
Complete 5.4 Modular Headshop Cams HPS intake If you have the money ported heads and intake longtubes too and you will have a nice 360 hp 400 tq n/a ride
01 GT Vert - Triple Black - 2v 5.4 270/340 00 Lightning - Triple Black - 2v SC 5.4 400/500 Brand New Tubular UCA and LCA set for sale PM me Slightly Used 05-09 Halo Headlights for sale PM me
seems to be a rash of these "seized motor" threads this week...
sucks, keep your chin high. from what you describe it doesnt sound good
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences 02' GT ~ Twin Screwed 469hp/493tq |
x2
2003 gt
5.4 32v on the way
Don't get your hopes up on a cammed 2v 5.4 making 360 to the wheels, at least not without a lot of money dumped into it. it would probably be much easier for you to swap in a 4v motor, look for one from an aviator.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
2001 Mustang GT
R3dn3ck the starter of the 300+ plage 5.4 swap thread on mustang boards who is also on here got 330 to the wheels with off the shelf Comp 278s and the HPS intake
Ported Heads and A cam ground specific for the 5.4 and a little port of the HPS intake which HPS offers will get you there.
2003 Mustang GT
that sucks man, sorry for the bad luck. Just gives you a reason to swap now!
for your search look for 99 and up trucks, just need your intake and also 01 and up grand marquis, town cars and crown vics. EXACTLY the same motor as in your car
also contact nick at the modular head shop, be surprised what he has layin around and who/what he knows of in the area
oooor be a good/cool time to put a PI swap motor in your car. Find a pre 99 motor put your top end on it, pick up a good 40hp over stock
#10 | |
as of the 5.4 thing i would just drop that in pull out all the seats drop in kirkey's in the front, pull out ac, welds big and skinnies full bolt ons hps cam and nitrous. I would be very happy with that should b a good 12.0xx car easy. i was running high 12's with exhaust and nitrous nothing else when i am ready will certainly contact nick I'm sure he has some motors laying around
#11 | |
2001 Mustang GT
one can only hope, but we'll see i'd rather do the 4.6 just cause i will have more spending money at the beginning of the build
2001 Mustang GT
swap in a stock 5.4 with jus the hps the 5.4 will run you the same as the 4.6 and 600 on the intake
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
it sounds to me people are having their oil pumps crap out. if the first thing you saw was your oil pressure drop and then it died. the reason your motor died is your followers ran out of pressure and your valves stopped opening. the short period the motor had no oil made the motor freeze it sucks man sorry to hear it. i have a mmr oil pump and its just a modified cobra pump, cryo treated, teflon coated, and the cobra pump gears are 1 or 2mm thicker
2003 Mustang Gt
Slow
just happened to my friend too, oil pump went out
409rwhp at 4500 rpms.Vortech V1 Intercooled,kurgan motorsports powerpipe, 3.12 pulley, all Mac Exhaust,Sct Tuner,Bolt Ons,Cobra Brakes,MM cc plates,Vis 2000 cobra r hood,MGW shifter,Strange 31 Spline axles,Eaton Possi |
#16 | |
2003 Mustang GT
Not Banned
quick buy sharkbaits hps intake
2003 mustang v6 ;)
slow
modular mustangs have always been bad about the gears breaking. the number 1 cause of pump fail is running a piggy back underdrive pulley/incorrectly seating the underdrive pulley puts harmonics on the pump and will vibrate the gears causing them to chip and fail. second reason is detonation, the shock to the shaft causes vibrations and jurking on the gears due to the speed changes of the crank. another reason is swaping out flywheels and not getting it balanced. some fail due to the sump sucking shit up
#19 | |
2003 Mustang GT
2003 mustang v6 ;)
slow
the only problem with some peoples install on a good sfi approved crank pulley is people dont seat them down all the way. i boil my pulley to expand it. on a cold motor the pulley slips on easy. there is also a right way to install the big washer and that is the flat side to the pulley. after im done i stick my finger in the crank shaft position sensor hole to make sure there is no play left in the trigger wheel. the nut has to be torqued down to about 90 lbs and i put lock tight on the nut so it does not back out.
Threads Similar to: It's Seized motor week!!!!!!!!!!!!!!!WOOT!!!!
| I Think My Motor Seized Up | 281SLEEPER2v | 99-04 | 55 | November 18th, 2010 10:12 PM |
| Seized motor options | Monsterint | 99-04 | 2 | September 19th, 2010 09:44 PM |
| motor seized | gooberhead320 | The Clubhouse | 144 | October 31st, 2008 02:36 AM |
| Possibly Seized motor | Kaane | 96-98 | 8 | April 30th, 2007 11:35 AM |
| seized motor | 83five0 | 5.0 Mustangs | 9 | December 18th, 2006 04:23 PM |
