Can I run my fuel return back to sump?
Im finishing up a fuel system on my car I have a -12 an supply and a -8 return, can I run the return back into the sump?
1999 GT 35th LE
Why would you be using a -12 hose for a supply hose, that's a big hose?
![]() Drive it like you stole it |
because thats what the bung is and the eliminator pump uses a -12 inlet, so can the return be ran into the sump?
dont think you want to run it back to the sump..but i wouldnt know...damnit big ass pump whast your power goals?
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
KB'd GT
No, you want the return as far away from the pickup as possible to minimize bubbles and heat.
what if it was ran to the sump and a line inside the tank where the return comes in, and ran the fuel away fromt he supply?
Yea I know what is needed for e85....whats ur setup?
KB'd GT
Sure, It doesn't matter where the return line enters the tank as much as where it dumps the returned fuel.
10.5:1 compression, vortech YSi pullied for 20-25 psi, trick flow heads, custom grind blower cams, fox lake intake manifold, return fuel system, fore precision rails. I'm sure I am leaving stuff out but thats most of the big stuff.
Threads Similar to: Can I run my fuel return back to sump?
| Fuel Tank Sump Questions?????? | Mike Johnson | 5.0 Mustangs | 17 | August 28th, 2009 02:46 PM |
| New Fuel Tank Sump Setup | 330CubeGt | Visual | 0 | August 17th, 2009 11:04 PM |
| Fuel sump | 90mustang | 5.0 Mustangs | 1 | July 2nd, 2009 09:05 PM |
| Benifits of return fuel to non return fuel??? | JONJON | 5.0 Mustangs | 4 | October 21st, 2007 03:11 PM |
| fuel sump kits? | 99mustang232 | 99-04 | 9 | December 3rd, 2005 05:29 PM |
